Tally-I/O
Author Topic: opinions on 10hp electric  (Read 1071 times)
Offline brdmkr
  • I need to slow down...
« on: June 09, 2011, 03:20:53 PM »
I am going to look at a bandmill this weekend that I MAY purchase.  It has a 10hp single-phase electric motor on it.  I am not even sure of the manufacturer as a friend heard about the mill and will be taking me to see it.  All he could tell me about it was that it is a manual band mill without a trailer and that it has a 10hp single phase electric motor on it.  I know that several forumites have mills with 10hp electric motors.  Do they perform OK?
Offline sst04
Re: opinions on 10hp electric
« Reply #1 on: June 09, 2011, 05:31:38 PM »
I like mine, although I am no expert, I just bought it.  It seems to cut large pines well without bogging down. And  it is fairly quite.
What part of georgia are you going to look?
Offline Ianab
« Reply #2 on: June 09, 2011, 05:46:54 PM »
A 10hp electric engine should perform similar to a 20hp gas engine on a sawmill. And 20hp gas is considered sensible for a manual bandmill.
Reason is that the torque curve of an electric motor is different. When you start loading down an electric motor the torque actually increases, so you keep cutting (basically until an overload or over-temp trips). With a gas engine, as it looses revs, it looses torque, and you either need to slow down, or it stalls totally.
Definitely worth checking it out if you have the power available to use it. Electric is generally cheaper to run, quieter and more reliable.
Offline jim blodgett
« Reply #3 on: June 09, 2011, 11:13:48 PM »
I have a manual bandmill with a 10hp electric motor and it works great for me.
There are pros and cons to electric or internal combustion power plants (portability, maintenence, noise, fumes...others that don't spring to mind).
I don't rely on sawing to generate income, but I have milled several thousand bf with that little mill and the only thing I'd really like to add is hydraulic log handling.  The electric motor is one case where I think I made the right decision the first time around.
10hp electric or 20hp gas?
Started by hackberry jake on Sawmills and Milling
Last post December 22, 2014, 08:59:08 AM
by hackberry jake
Opinions on how an 18 hp gas compares with a 10 hp electric (single phase)
Started by fishpharmer on Sawmills and Milling
Last post January 08, 2009, 06:05:03 AM
by fishpharmer
Any opinions on the Granberg electric chain sharpener?
Started by ksks on Chainsaws
Last post January 02, 2019, 12:46:54 PM
by ksks
One 10HP motor, or 2-5hp motors
Started by nathandcasey on Sawmills and Milling
Last post September 26, 2019, 10:20:43 PM
by Randy88
