MM uses a hydraulic cylinder for the setworks.The valving is such that when the valve is closed the the cylinder is locked from both hydraulic lines.The challenge I found with the Mighty Mite was manually stopping one the scale. In this type of manual setworks there is a minimum time the valve will open and hence minimum step size versus cylinder speed. The slower the speed the smaller the minimum step size. To control this issue I adjusted the hydraulic flow rate in the cylinder with two flow control valves.The advantage of this system is the matching lifting force on the sawhead, with a minimum of parts.
Started by shortlogger on Sawmills and Milling
Started by jrokusek on Sawmills and Milling
Started by Kwill on Sawmills and Milling
Started by brdmkr on Sawmills and Milling
