Author Topic: New projects  (Read 5390 times)
Offline Kevin
New projects
« on: January 16, 2004, 04:35:56 PM »
I have a couple of new projects coming up just as soon as the weather changes...
A Black Spruce along side the Trans Canada highway
A White Birch between two cottage buildings ...
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Re: New projects
« Reply #1 on: January 16, 2004, 06:29:58 PM »
That first one is an easy fix. Just tilt the camera a little to the right.
Offline Kevin
Re: New projects
« Reply #2 on: January 16, 2004, 06:33:42 PM »
I was hoping it might stand itself back up in the Spring.
Online Jeff
  • Fearless Leader
Re: New projects
« Reply #3 on: January 16, 2004, 06:43:50 PM »
Is that the one with the roots up in the air?
Offline Kevin
Re: New projects
« Reply #4 on: January 16, 2004, 07:02:16 PM »
That's it.
Maybe I could just paint it blue.  :D
Online Jeff
  • Fearless Leader
Re: New projects
« Reply #5 on: January 16, 2004, 08:03:43 PM »
I wonder if you could pull it back straight with a come along and then pin it down with some steel fence posts.
Offline Kevin
Re: New projects
« Reply #6 on: January 16, 2004, 08:43:46 PM »
It's a jungle out there.  :D
Here's a bigger picture --Photos MUST be in the Forestry Forum gallery!!!!!--.com/photo/26601181/111756663ywSASn
*hit the normal size button.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: New projects
« Reply #7 on: January 16, 2004, 09:22:11 PM »
  It be alot easyer ifin that line wasn't there.
 You got it figured out yet hows you gonna take it down, all that calculating give you any ideas...
   Marcel
Offline chet
Re: New projects
« Reply #8 on: January 17, 2004, 05:20:31 AM »
Here's where ya get out yur throw bag to set yur rope or ropes. Those black spruce are purty tough and usually pull purty easy. But yur rope needs lots of height.
Sometimes when faced with a tree like that, that I don't know will HANG on I will use two ropes in it, each pulling at a 30 to 45 degree angle.
Or....... ya could always climb it and jump the top over the cable.  ;D
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline Kevin
Re: New projects
« Reply #9 on: January 17, 2004, 06:21:32 AM »
There's a few  ways to tackle this one that I see.
Two as Chet described and a third where I partialy cut the butt and let the top rest gently on the strand then go up trim the top off close to the cable and come back down, finish the cut and let the tree drop to the ground.
Offline Bro. Noble
Re: New projects
« Reply #10 on: January 17, 2004, 06:53:14 AM »
Jeeze Kevin,
You're overlooking the obvious and easy way to do it.  I'd tell you but you always make fun of my brilliance ::)  Anyway it would take a helper.  Can you get anyone to work with you?
Offline Kevin
Re: New projects
« Reply #11 on: January 17, 2004, 07:14:03 AM »
Bro; helpers aren't in our budget.  :D
What's your suggestion?
They won't let me burn it down or blow it up.  :D
... and I'm not dropping the cable.
Offline chet
Re: New projects
« Reply #12 on: January 17, 2004, 07:38:18 AM »
Kevin, yur option wouldn't work for me. The folks I work for frown on the idea of resting trees on high voltage lines. Seems to always blow power.  :-/  They also aren't as tough as dem big fat Com cables.
Offline Kevin
Re: New projects
« Reply #13 on: January 17, 2004, 07:38:54 AM »
Here's a shot from my office yesterday --Photos MUST be in the Forestry Forum gallery!!!!!--.com/photo/26601181/111838517pkJIsw
Offline Bro. Noble
Re: New projects
« Reply #14 on: January 17, 2004, 09:38:18 AM »
Kevin,
Well never mind then,  I figgered I was wasting my time :-/
Offline Wes
  • when is a hole not a hole?
Re: New projects
« Reply #15 on: January 17, 2004, 11:15:57 AM »
 Looks like a bucket truck job, or possibly a crane.
Or if you get a good heavy snow it may come down by itself, then it will be an easy one.
Offline Kevin
Re: New projects
« Reply #16 on: January 17, 2004, 12:00:27 PM »
It's going to be a climb the rope and saw job.  :D
Re: New projects
« Reply #17 on: January 17, 2004, 03:57:23 PM »
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
Re: New projects
« Reply #18 on: January 17, 2004, 07:02:23 PM »
Get a 1010 John Deere with loader bucket.  Raise it as high as it will go and push the tree back into the woods.
Offline Stan
Re: New projects
« Reply #19 on: January 17, 2004, 07:29:30 PM »
Have the phone company come out and lay the cable on the ground. No harm no foul, this don't work with electric lines.  :-/
I may have been born on a turnip truck, but I didn't just fall off.
Other Projects
Started by Phorester on General Woodworking
Last post February 02, 2009, 10:35:05 AM
by Phorester
Our projects
Started by biziedizie on General Board
Last post September 10, 2003, 09:50:06 PM
by biziedizie
ERC Projects.
Started by Bill Gaiche on General Woodworking
Last post June 30, 2012, 03:07:06 PM
by jamesamd
projects
Started by steve phillips on Sawmills and Milling
Last post August 13, 2013, 01:39:10 PM
by dboyt
