Tally-I/O
Author Topic: "Bucket Filtering" used oils / lubricants for diesel fuel  (Read 6452 times)
Offline Jasperfield
« on: September 12, 2011, 08:41:49 PM »
I've read the posts re biofuel, vegetable oil, and etc., for diesel; and am interested if any have used some of the bucket-filter systems like "Green Fold Filters" to filter used motor oils / lubricants, and so forth, for use as diesel fuel.
The fellow who developed this system lives near me and uses only this fuel in his diesel vehicles.
If any of you have actual experience with filtering oils & lubricants for use as a fuel for diesel engines, please respond.
These things will also filter cooking oils.
Offline woodyone.john
Re: "Bucket Filtering" used oils / lubricants for diesel fuel
« Reply #1 on: September 17, 2011, 07:30:07 PM »
i would love any information on this subject to!cheers
Saw millers are just carpenters with bigger bits of wood
Offline Gary_C
  • Sunrise on the Prairie
« Reply #2 on: September 18, 2011, 10:44:55 PM »
I am not a great fan of using either used cooking oils or used motor oils in diesel engines.
My son does use cooking oils in an auto diesel, but he bought a special heated tank for the grease and has to start on regular diesel and get the engine up to operating temp before switching over to the grease. Same thing on shutdown when he has to clear the grease out of the fuel system before shutting down. You have to do this to avoid the carbon and coke buildup on the rings which can destroy a diesel engine. You can run the same kind or risk and shorten the engine life when burning used motor oils.
So in my opinion, those diesel engines are just to complex and expensive to risk a major overhaul. There just has to be a better and safer use for these waste products.
Offline Jasperfield
« Reply #3 on: September 19, 2011, 09:11:32 PM »
Thanks for the replies, fellows.
Gary C,
I've heard some of the same complaints about heating the fuel, and so forth. I've decided that, at this point, it's not worth the trouble for me to do.
Offline Al_Smith
« Reply #4 on: September 20, 2011, 09:58:14 AM »
Over the years there have been countless experimentations of recycling old crankcase oils or cooking oils into usable fuel .
The most amusing was a gent from the NYC area who gathered up old cooking oil from resterants to reuse as bio diesel in a VW Rabbit .It worked,didn't start well in cold weather but instead of belching nastey diesel smoke it smelled  like McDonalds French fries .
From my personal perspective I subscribe to the theory the stuff would better serve as fuel for a waste oil burner .Get the usable heat from it and call it a day .
Offline billyO
« Reply #5 on: September 23, 2011, 10:56:49 AM »
Hello all.  I thought I'd add my 2 cents worth (and taking inflation into consideration, I realize that it may be relatively worthless...)
I've been using waste vegetable oil in my '93 dodge 3/4 ton for about 3-4 years now with probably over 150K miles of veggie oil miles (I've got 325K miles on the truck).  The only major problem I've encountered so far is running my tank empty when I was using a 55 gal barrel as my second tank for the first 2 years (I've since replaced that with an 80 gal in-bed tank with a sending unit and fuel level gauge).  My filtering method is cold-upflow filtering followed by a 10 micron and then 5 micron filter.
I have read a bulliten put out by Cummins a while back that said that you can add 5% used motor oil to your tank of diesel (see http://old.pnwis.org/2004%20Events/ULSD2005/ULSD%202005%20Rudisill.pdf), but I've been reluctant to try this yet.
Offline shelbycharger400
  • m14/04 0
« Reply #6 on: September 23, 2011, 09:46:47 PM »
http://journeytoforever.org/biofuel_library/ethanol_motherearth/me11.html
i have another one, where the guy uses waste oil as a blast furnace to melt aluminum
backyardmetalcasting.com
Offline Jasperfield
« Reply #7 on: September 23, 2011, 10:09:33 PM »
At this point, I'm quasi-enthused. Nevertheless, I am certain there are benefits for those willing to pursue.
Here's a contact: greengoldfilters.com
The fellow's name is Tom Healy. I met with him and discussed his product extensively. He's a straight-shooter. Thhealy@gmail.com
Offline badbird347
« Reply #8 on: September 26, 2011, 12:37:53 PM »
I know i may be beating a dead horse here since you have allready writen off the idea, but me and two other friends run our 7.3l fords on used ATF filtered through two in line filters then into the tank (5 micron, then 3 micron NAPA had them). most of the summer I use 40% ATF per tank and back it down to 20% in the winter. one of my buddies runs 100% in the summer and 50% in the winter, no problems with drivabilty, or durablity. I don't run the 100% because there is a hase of smoke at idle and I can't seem to gather that much ATF. The biggest thing with this method is selection of fluid don't run ATF that had metal in it try get it from a flush machine (they have internal filters) :)
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #9 on: September 26, 2011, 04:12:43 PM »
I had a guy tell me he was putting filtered used motor oil in his offroad dyed diesel to cover up the red dye and was running it on over the road.  The black oil apparently covers up the red dye  ???  Sounds like trouble to me  :)
Offline Reddog
  • Forest & Urban woody plant management
« Reply #10 on: September 26, 2011, 07:22:06 PM »
Nothing covers up the dye when they analyze for it in the lab.
Offline Al_Smith
« Reply #11 on: September 26, 2011, 09:57:40 PM »
Pretty good dye I think a little barrel being 35 gallons would do an entire bulk storage tank at the local refinery .
Those stinkers would go around at one time to farm auctions and places like the Ohio farm science review and snoop in peoples tanks to see if they were running ag diesel .Caught a few too .
Offline Jasperfield
« Reply #12 on: September 26, 2011, 09:58:39 PM »
I've had several people tell me that ATF is probably the ideal fluid to use.
Offline badbird347
« Reply #13 on: October 09, 2011, 07:34:39 PM »
it's ideal in the fact that it's a lubicant (and it's free for me) which is why I started to use it when ULSD came out, 7.3l injectors are expensive. but the last several posts brought up a good point if your caught with non taxed fuel on the road the fine is heavy :(. but they don't seem to bother with pick-up's
Offline Taylortractornut
« Reply #14 on: October 23, 2011, 06:15:38 AM »
My 94 Dodge company truck started running badl after the ULSD came out.        I put a  quart of  atf or clean motor oil in the tank each fill  up.  Even te  older machines at work do better on it.
My overload permit starts after sunset
100 low lead or as we refer to it "rocket fuel"
Started by PB Logging on Chainsaws
Last post April 22, 2007, 10:20:36 PM
by arojay
1- Twisted Sister or "Walnutz!" and 2- "Pre-Bent" or "Saw Mill Nightmare?
Started by MbfVA on Sawmills and Milling
Last post September 08, 2017, 12:33:17 PM
by MbfVA
Where I live, "YORK COUNTY" S.C. is home of the "WORLD'S HOTTEST" CHILI PEPPER.
Started by POSTON WIDEHEAD on FOOD! FOOD! FOOD!
Last post January 24, 2014, 01:26:38 AM
by LeeB
What we can do about fuel prices " not "
Started by Buzz-sawyer on General Board
Last post May 22, 2004, 11:12:15 PM
by Stan
