Author Topic: Equipment Security  (Read 2355 times)
Offline Brad_bb
    • My timberframe blog
Equipment Security
« on: September 29, 2011, 01:05:19 AM »
Does anyone here do any GPS tracking of equipment?  When I go to buy my first mill, I can keep it indoors, but it can still be stolen as the building doesn't have an alarm or security other than door locks.  I could have an alarm installed, but that would probably cost as much as a tracking device I'm thinking.  I also have other equipment that I could GPS track too if it's cost effective.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
Re: Equipment Security
« Reply #1 on: September 29, 2011, 01:58:22 AM »
You might want to check out AC Global Systems (www.acglobalsystems.com).
I haven't bothered. To steal my mill you will have to find the hitch first, then find the bolts, then dismantle the outfeed table and move all the slab racks.
It's easier to drive down the road and steal John's mill instead ;D.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Ironwood
    • http://www.branchandburl.com
« Reply #2 on: September 29, 2011, 06:16:09 AM »
Interesting idea, what does it cost?
 You could always just put a sign up "caution equipment on this site has GPS tracking devices" ;D Thieves welcome to the digital age.
 Would only cost you the sign and may make someone think twice.
 Ironwood
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: September 29, 2011, 07:29:53 AM »
I figure that anyone lazy enough to be a thief will not want to saw logs.  I guess that it could be chopped up and sold for scrap iron.   :-\
I do like the idea of the sign.  It also will be interesting to see cost figures Brad.
Offline D Hagens
« Reply #4 on: September 29, 2011, 11:12:43 AM »
  :D :D :D That's a good way of thinking MM :D :D :D
Offline Taylortractornut
« Reply #5 on: September 29, 2011, 06:14:04 PM »
Low jack  works good if your in a coverage zone.   I had welder stolen on a job I was working on.  I kinda knew the culprit but couldnt prove it.    Called Low  Jack and we  found it in his basement.    A friend in that ame  part of the county had it on a baler ontime  when scrap went up and found his  bale in the next town   at a scrap yard.
My overload permit starts after sunset
Offline 123maxbars
    • www.outofthewoodsforestry.com
« Reply #6 on: September 29, 2011, 06:37:01 PM »
Well here is my two cents on the cost of a gps device for your mill. I am a police officer who has been an undercover narcotics agent for the past three years. We have a very neat device called a tracker that is placed on vehicles (device has magnets that attach to the frame) that we use to track suspect vehicles. It is a very good device that will even alert you via text message if the vehicle is on moves. However this device cost around 5k and and additional 1k a year for the tracking/gps. And believe me we researched for a long time, there are cheaper models around, but they failed. This is neat technology but its very expensive for the general public who are wanting to protect there equipment. Been a cop for ten years and I can recall one instance a few years back where a mobile mill was stolen. I did some research today on that case, and found out it was never recovered, it was a timberking. Just my two cents.
Sawyer/woodworker/logger
W/M LT35HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #7 on: September 29, 2011, 07:09:19 PM »
my security is about 80.00 a month for food and I even give them a bed to sleep on. I wonder if you could use a pet chip if that would also track equipment.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline Woodwalker
  • Old, ugly, rude, cude and sociability un-acceptable.
« Reply #8 on: September 29, 2011, 07:34:41 PM »
My thought is that while a GPS unit will track its position, what about the guy that kicks the door in and takes your battery, siphons the gas out of the mill and grabs the pretty blue cant hook as he heads out the door?
Get the GPS if it fits your situation. Lock up and secure everything you can. Make everything worth taking hard to take.
Just cause your head's pointed, don't mean you are sharp.
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
« Reply #9 on: September 29, 2011, 07:59:31 PM »
Redbeard that is one large dog or a smallish bed. bg
Offline Brad_bb
« Reply #10 on: September 30, 2011, 04:45:05 AM »
123maxbars, it doesn't make sense why they would have to make a reliable system so expensive.  I'm guessing because they must have some exclusive rights to a satellite or something...A few years ago I considered LoJack, but it became clear that they range was a problem.  They need only drive 30-45 minutes from me to be in a non-coverage area.  Just think how much crime we could reduce if GPS tracking were cost effective.
Offline pineywoods
« Reply #11 on: September 30, 2011, 10:19:48 AM »
I like my video surveilance setup. It's not perfect, but it's cheap and  works 2 ways. Mount one set of cameras where they are highly visible, serves as a deterent. Another set hidden, just in case..
Offline JP135
« Reply #12 on: October 02, 2011, 10:49:30 AM »
Kinda long - please forgive me.
Saw this thread earlier, started to reply but got called away for some reason.
Retired auto theft detective here. I retired in 2005, so I'm out of the loop now on the latest/greatest new equipment.
123maxbars is right - reliable technology is not cheap. I worked in the Dallas/Ft Worth metro-mess - LoJack works great there. Outlying areas are hit and miss. Plus it gets spendy real quick.
GPS tracking is good, but if the crook puts your piece of equipment in a shed, the GPS signal gets interrupted. Example: When I was in patrol we had GPS tracking on our patrol cars - we'd mess with the dispatchers by having everybody on the shift wrap the GPS antenna in tin foil at a pre-determined time. 4am, everything is quiet. Suddenly every patrol car drops off the dispatcher's GPS screen. Chaos and laughter follow.
Cellular coverage is effective. I'm aware of a couple of instances where motorcycle owners put a pay-as-you-go cellphone somewhere inconspicuous, wire the charger to the battery so that the phone is always charged, then turn off the ringer. Scooter gets stolen, call the cellphone. Cellular towers triangulate the signal from the cellphone, so when the cellphone goes active, the signal is triangulated and narrowed down to a specific area on the map. Google cellphone tracking for better/more accurate info and free apps.
Harden the garage space where you store your equipment. You're never gonna make a thief quit stealing; The best you can hope for is to make your place just difficult enough to discourage him (or her) which forces them to go steal somewhere else. To that end:
*Lock the doors. Take the keys. Can't tell you how many times I've seen major thefts/burglaries enabled by the owner leaving doors unlocked/keys in equipment.
*Cameras (even non-working ones) mounted on the exterior of the building are effective.
*If you have a concrete floor, consider drilling and setting an anchor into the concrete, then chain and padlock your equipment to it. Paint the chain bright orange so even an idiot will see it.
*Large, noisy dogs are awesome. Nothing stands the hair on end more than rattling a door and hearing a huge dog go nuts on the other side of the door.
Question: What's black and tan and looks good on a burglar?
Answer: A Rottweiler.
Most thieves are target-of-opportunity folks - they see something and think they can take it without too much effort or too much chance of getting caught and then sell/trade it for something they want. Discouraging the casual thief is the best bang for the buck.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #13 on: October 02, 2011, 02:33:47 PM »
There are certain areas where each of us can tighten our defenses, thanks.
Security
Started by Engineer on General Board
Last post November 03, 2006, 07:10:52 PM
by Don P
Security Systems
Started by WV Sawmiller on General Board
Last post April 25, 2015, 08:46:13 PM
by POSTON WIDEHEAD
Social Security
Started by DouginUtah on General Board
Last post November 01, 2011, 08:21:00 PM
by Al_Smith
Garden security?
Started by drobertson on General Board
Last post April 26, 2014, 05:46:38 AM
by Ron Wenrich
