Author Topic: A solution for bowing cants  (Read 1653 times)
Offline kelLOGg
« on: October 02, 2011, 07:08:36 PM »
This has probably been done before but I don't recall having seen it.
Saw to the clamp, install a 2nd one w/ a spacer under it to prevent binding the blade, remove the 1st one. Saw more and repeat if necessary. Example shown is with sweet gum. I suppose for larger cants you could use a pip clamp on each side.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
Re: A solution for bowing cants
« Reply #1 on: October 02, 2011, 07:35:05 PM »
I have bolted a mount on end of bowed cant so i could get a ratchet strap to help bring it down, and also put some weight on top with another cant.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline kelLOGg
« Reply #2 on: October 02, 2011, 08:52:54 PM »
Redbeard, I like that. For a cant w/ ends bowed up your method doesn't require removing anything.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: October 02, 2011, 09:19:21 PM »
 smiley_idea  I thank both of you for the ideas.   :)
With a center hump bowed, I only need to hold it down until I get it clamped.   smiley_thumbsup
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #4 on: October 03, 2011, 02:37:45 AM »
And for a small bow -- say 1/4" in 16', I put the hump up, clamp it ever so gently, then give it a whack or three with a dead-blow hammer. Once it's good and flat I tighten the clamp right up so sawing vibration doesn't release the timber.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline ladylake
« Reply #5 on: October 03, 2011, 05:03:57 AM »
 Both ideas are good, thanks     Steve
sawing bowing cants
Started by xlogger on Sawmills and Milling
Last post August 21, 2013, 06:24:20 AM
by xlogger
a clamp to prevent bowing cants ?
Started by kelLOGg on Sawmills and Milling
Last post August 08, 2008, 07:21:22 AM
by kelLOGg
Sawing logs into cants and saving the cants to saw later.
Started by TnSawyer on Sawmills and Milling
Last post September 08, 2007, 06:11:44 AM
by Cedarman
Blade Bowing
Started by j napier on Sawmills and Milling
Last post September 14, 2013, 10:54:13 AM
by beenthere
