Baltic Abrasives Technologies
Author Topic: Need Ideas for DIY Rail guides for Alaskan Mark III  (Read 12202 times)
Offline SilverKing
« on: October 10, 2011, 06:21:15 PM »
I will be purchasing an Alaskan Mark III mill 36" and wanted to setup my own rail guide system.  Any ideas?
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Need Ideas for DIY Rail guides for Alaskan Mark III
« Reply #1 on: October 10, 2011, 06:30:33 PM »
an aluminum ladder works great
lots of dull bands and chains
Offline zopi
« Reply #2 on: October 10, 2011, 06:35:46 PM »
Good straight two by six..
I used that channel stock they hang conduit on...forget what they call it...
Channel iron would do too...
I sawed five logs with the mkIII....then bought a bandsaw mill...too bloody much work.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline JV
  • Live - love - laugh a lot today.
« Reply #3 on: October 10, 2011, 07:10:51 PM »
I used two 2x4's on edge with the t-slot channel from Granberg.  You have to drill through the edge to attach the bolts.  I used 3/8" all thread to space and adjust the 2x's.  I nail the channel to the face of the log with duplex nails as they are easy to pull.   I let the ends of the 2x's stick out about 18" so I can hang the saw on them.
I used a 2x6 on the far end to either level or cut a taper.  I have a 52" mill with a Stihl 084 with a 60" bar and this rig handles it fine.  I used 16' 2x's to cut longer timbers.  Makes a cheap rail system.
A 3" x 46" x 80" slab I cut for a customer.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Offline Dan_Shade
« Reply #4 on: October 10, 2011, 07:28:13 PM »
I have some square tubing with holes punched in it.  I lag screw this to the log, and zip tied it to the ladder.
I don't have any pictures.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #5 on: October 10, 2011, 07:52:59 PM »
zopi I think you are talking about unistrut..Tim
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline mikeb1079
« Reply #6 on: October 10, 2011, 08:13:03 PM »
i made mine out of two 10' pieces of unistrut with cross pieces welded in between.  if you put the slotted side outwards you can slide the end pieces ( i used angle iron) to adapt to different lengths of log.  heavy but works well.
homebuilt 16hp mill
Offline SilverKing
« Reply #7 on: October 10, 2011, 10:48:51 PM »
Thanks for the ideas and pics.  They were very helpful.  Zopi would you be interested in selling your Mark III?
Offline zopi
« Reply #8 on: October 11, 2011, 07:25:21 AM »
Yep..unistrut...works well..I made a pair of angle iron end clamps with holes to nail the assembly to the log..worked out well..
Got Wood?
And lots of junk.
Offline zopi
« Reply #9 on: October 11, 2011, 07:29:51 AM »
Well...I suppose so...lemme think on it a bit..not sure what to ask...it takes up to a thirty six inch bar...
Got Wood?
And lots of junk.
rail options for an Alaskan II
Started by roughhewn on Chainsaws
Last post March 25, 2006, 06:32:34 AM
by CaseyForrest
Logosol Timberjig vs. Alaskan Mark III
Started by Shawn on Sawmills and Milling
Last post December 27, 2005, 08:54:06 PM
by rino
Post and Rail ideas
Started by bman on Timber Framing/Log construction
Last post November 03, 2007, 10:12:53 PM
by Thehardway
Slabbing rail ideas????????
Started by Oregon_Rob on Sawmills and Milling
Last post September 30, 2002, 08:04:00 AM
by Oregon_Rob
