Author Topic: Cycle time for Solar Kiln  (Read 2181 times)
Offline VA-Sawyer
« on: January 24, 2004, 06:27:24 PM »
What is a realistic number of loads one can cycle through a solar kiln in a year. I've seen claims ranging from 12 ( average one a month ) to 3 ( 1 over fall/winter , 2 during spring/summer )
I realize there are a lot of variables. Lets figure 4/4 red oak, fresh off the stump, fresh sawed. Dried to 6 or 7% MC.
Total loads per year ?
Offline sawwood
Re: Cycle time for Solar Kiln
« Reply #1 on: January 24, 2004, 06:59:03 PM »
VA_Sawyer Larry dryes about 3 to 4 loads a year. I think
it depends on where you are. Hope Larry see this and he
can answer it better.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline chet
« Reply #2 on: January 24, 2004, 07:03:00 PM »
This past year I was able to get 4 loads threw mine. But ya have to remember I'm way north of you, U.P. of Michigan. All loads were green off the stump.
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline Ed_K
« Reply #3 on: January 26, 2004, 08:22:25 AM »
 Will air drying for a month, make it easier or worse (more checking). Whats the highest temp you can achieve in the UP.
Ed K
Offline Carl_B
« Reply #4 on: January 30, 2004, 05:56:15 PM »
I think that the 3 to four loads a year is about right. I am on the first year with my kiln and we just put the 5 load in. The first load was poplar that was green then elm that was air dryed fo 6 months red oak green then air dryed mixed load of cheery and elm the last load is mixed and air dryed should be out when the year is up. Carl B.
Solar Cycle Kiln as seen on Timbergreenfarm.com
Started by jwoods on Drying and Processing
Last post January 10, 2010, 08:50:08 PM
by dail_h
Solar Cycle Kiln & Sterilizing
Started by E-Tex on Drying and Processing
Last post February 16, 2018, 08:40:29 AM
by E-Tex
Solar kiln this time of year
Started by vfauto on Drying and Processing
Last post January 06, 2018, 06:41:11 PM
by vfauto
Mental Exercise! Hybrid kiln design (solar drying concept w/o solar heat)
Started by scsmith42 on Drying and Processing
Last post March 31, 2016, 10:51:46 PM
by GeneWengert-WoodDoc
