Arborwear
Author Topic: Building a JD Forwarder Model, and Have Questions About the Bogies  (Read 9403 times)
Offline twinotter
Re: Building a JD Forwarder Model, and Have Questions About the Bogies
« Reply #20 on: January 15, 2012, 05:41:30 PM »
I thought I should update this thread.   I'm making some progress, but I haven't had much time to work on the forwarder.   The chassis is almost complete, and I've been able to include planetary gears in each bogie.  I've got a bit more work on the chassis, then I'll be moving to the boom.
I have another question though.   Does the boom base have sideshift capability?  What are the cylinders in this picture for?  Are they some kind of hydraulic cylinders?  Picture is the base of the boom.
Thanks!
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #21 on: January 15, 2012, 05:58:31 PM »
I'm not positive, but would bet that is the double  hydraulic rack and pinion assembly that turns the boom. The racks slides back and forth in those housing, turning the pinion. A rack on each side of the pinion gear, moving in opposite directions to turn the gear/boom.
Offline beenthere
« Reply #22 on: January 15, 2012, 06:14:07 PM »
Like Jeff said, and here is what is inside (to skew, according to jdparts).
Offline twinotter
« Reply #23 on: January 15, 2012, 08:00:26 PM »
Thanks!  I've been in a debate with a guy who claims that it is part of a side shift, but I haven't seen any evidence of that in any research that I've done.  You guys have just confirmed what I was thinking.
That's an interesting skew mechanism.  Pretty cool.
Thanks again!
Daniel
Offline mad murdock
« Reply #24 on: January 15, 2012, 08:23:18 PM »
All I can say is WOW twinotter! That is some awesome modeling you got going on smiley_clapping smiley_clapping
I can't wait to see the forwarder in action! BTW, your handle wouldn't be in reference to a DHC-6 by chance? Just wondering.
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline twinotter
« Reply #25 on: January 16, 2012, 04:28:06 PM »
Thanks!  Yup, twinotter is in reference to the DHC-6 twinotter.  Dhc6twinotter is the username I usually go by on other forums, but not sure why I went with the short version here.  I'm never good at picking usernames, so I just go with the name of aircraft.   :D
Offline mad murdock
« Reply #26 on: January 16, 2012, 05:16:21 PM »
I had a suspicion ;)I worked in bush Alaska for a few years, worked on the -200 and -300 'Twotter.  Great aircraft.  Got a chance to fly a few times in a re-engined DHC-3 (big russian radial and 4 bladed prop), that was a FUN plane, and quite a HOSS!  How long does one of the LEGO creations take to build?  I find it quite incredible the level of detail and realism that is present in your models!  Thanks for sharing your craft on the 'Forum. :)
Offline twinotter
« Reply #27 on: January 16, 2012, 11:04:41 PM »
The time depends on the model.  I just got back into LEGO after finishing school, so I'm still in the learning process.   My tractor was my first model, and that took probably 70 hours or so.  Everything on it had been rebuilt at least once, and some of it I rebuilt about 20 different times.   The backhoe took about 80 hours or so, but that is much, much more complex than the tractor.   The little radial engine with variable pitch prop I built took about 7 hours.   I usually only get 1 or 2 major project done in a year.   I watch very little TV and don't play video games, so this is pretty much what I do on my downtime (along with posting on several forums).
I've never had a chance to fly on a real Twinotter.  Back at my old place, a local parachute outfit used to fly one out of a grass strip down the road.  They'd buzz the trees around the house sometimes.   Very cool planes.  I think they are using a Sherpa now, but not sure.
I'd like to build a few aircraft too.  Grumman Avenger is at the top of my list, and I'd like to build a P-38, B-25, and a DHC2 Beaver on floats as well.   They would include working flight control surfaces, and whatever other functions that particular plane has.
I'll post up some progress pictures in a few days.
Thanks!
Daniel
1965 Iron Mule forwarder, model 2200
Started by babysister on Ask The Forester
Last post May 08, 2014, 10:35:24 PM
by ffskidder
Building the Model T
Started by Raider Bill on General Board
Last post November 10, 2009, 03:12:53 PM
by scgargoyle
Husqvarna model questions
Started by husky55guy on Chainsaws
Last post January 15, 2015, 09:58:56 AM
by HolmenTree
Bought '79 tj 230 forwarder, have questions (brakes)
Started by Sunrise Farms on Forestry and Logging
Last post December 03, 2010, 05:51:38 PM
by furltech
