Author Topic: covered bridge construction?  (Read 3060 times)
Offline hackberry jake
« on: October 27, 2011, 03:51:07 PM »
My dad bought 100 acres of wooded land a couple years ago, and just recently bought a smaller dozer. He's wanting to use the dozer to improve the roads, build a pond, and level out a spot for a cabin. He wants a covered bridge across the pond for four-wheeler traffic and fishing. I've been pondering how to construct it. I thought about a floating bridge, but I'm starting to lean towards building either rock and mortor pillars, or concrete pillars every 8' or so. How would you build them so they wouldn't settle much? I would then run 3 2x8s or so across the spans for support, and 1x for the boards on top. His land consists mainly of oaks and hickorys. He has a good amount of cedar, but I hate using cedar structurally. Would hickory or red oak last if used in the roof section?  I imagine white oak will be the wood used for the platform. Any opinions?
Offline paul case
  • Original wearer of the PCM.
Re: covered bridge construction?
« Reply #1 on: October 27, 2011, 07:46:07 PM »
Are you talking about for purlins or rafters and a metal roof? If so, then hickory or oak will last you a lifetime, if you die when you should.
PC
pc
« Reply #2 on: October 27, 2011, 08:56:27 PM »
Yes, rafters and purlins for the metal roof. I believe he got the idea of the bridge from the woodchuck commercial. "DanG woodchucks... quit chuckin my wood!" That guy has a bridge across a river or pond of some kind. Sure would look neat, not so sure its worth the labor and timber though.
Offline thecfarm
« Reply #3 on: October 28, 2011, 06:58:24 AM »
Don't forget to leave a gap between the floor boards to let the dirt fall through. Good over hand on all sides,the ends too.
Offline bandmiller2
« Reply #4 on: October 28, 2011, 08:05:28 AM »
I would study the design of a simple truss then upsize it to the size you need. Frank C.
Offline Dave_
« Reply #5 on: October 28, 2011, 12:00:59 PM »
A timber framed structure might be cool.  You might want to go over to the timber frame forum and bring it up there.
« Reply #6 on: October 28, 2011, 08:37:30 PM »
I could possibly get away with longer spans if I made timber trusses. The top of the trusses could hold up the roof rafters somehow. Could I get a moderator to move this topic over to the Timberframe and log construction section? Purdy please.
Offline Rooster
  • Tools are extensions of ourselves... share a tool.
    • Photobucket image storage account
« Reply #7 on: November 01, 2011, 10:48:03 PM »
What is the total span of the pond?  I have built a covered bridge that spanned 51ft with a Multiple King-post truss wall system.  Town lattice trusses are easy to build because there isn't any mortice and tenon joints, just overlapping 3x10s with 2in, trunnels.
http://www.past-inc.org/historic-bridges/image-towntruss.html
Sounds like a fun project!
Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
« Reply #8 on: November 04, 2011, 02:46:58 PM »
I'm not too sure about the span of the pond yet as we haven't began construction yet. I need to know how often to build the supports. I plan on building them in the dry before we seal up the pond.
Offline losttheplot
« Reply #9 on: November 04, 2011, 05:57:50 PM »
I was going to build one of these once.
http://mathemati.ca/1040a.html
If your span is 24' or less.
DON'T BELIEVE EVERYTHING YOU THINK !
Offline jdtuttle
  • If it's worth doin, it's worth doin right
« Reply #10 on: November 05, 2011, 10:40:58 AM »
If you haven't dug the pond yet put a small island in the middle & have either two shorter bridges or use the island for center support. A friend of mine did his this way & it looks great.
Jim
Have a great day
moved
MOVED: covered bridge construction?
Started by Jeff on Sawmills and Milling
Last post November 04, 2011, 12:59:17 PM
by Jeff
Covered Bridge Festival
Started by cbecker on Timber Framing/Log construction
Last post May 02, 2012, 10:34:55 AM
by Jim_Rogers
Covered bridge photos
Started by Jim_Rogers on Timber Framing/Log construction
Last post September 08, 2007, 04:27:58 PM
by Dave Shepard
Timber covered bridge
Started by fred in montana on Timber Framing/Log construction
Last post September 27, 2010, 10:01:58 PM
by fred in montana
