Author Topic: How to load a big log on to a woodmizer...  (Read 7244 times)
Offline Slingshot
« on: October 29, 2011, 10:42:28 PM »
 sling_shot
Offline Slingshot
Re: How to load a big log on to a woodmizer...
« Reply #1 on: October 29, 2011, 10:51:33 PM »
   This one shows them cutting it;
_______________________________
Offline beenthere
« Reply #2 on: October 29, 2011, 11:06:51 PM »
How to load, or how not to load? That is the question.
Just was waiting for the guy to get crushed when that log rolled toward the tractor.
That WM mill is tough !!
Offline schmism
« Reply #3 on: October 29, 2011, 11:18:00 PM »
Ive watched my share of mill vids on youtube....
why does that WM sound so weird.... like the theath of the band are constantly cutting on metal?
039 Stihl 010AV  NH TC33D FEL, with toys
Offline woodzy88
« Reply #4 on: October 29, 2011, 11:38:32 PM »
That looked a highly dangerous way of loading a log that size and I thought it looked a bit rough on the mill. When we do things like this we only get away with it for so long until one little thing goes wrong then someone get badly hurt or killed. Not for me , I say work safe an use the right equipment for the job and stay alive.
woodzy88
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #5 on: October 30, 2011, 12:13:06 AM »
First Time I have seen an LT80 Must be building them in Europe   :) :)  ??? ;)
4TH Generation Timbergetter
Offline T Welsh
  • Woodmizer LT-40-HD http://www.welshtreeservice.com
    • Welsh Tree Service
« Reply #6 on: October 30, 2011, 02:07:04 AM »
Pushin it to the limits is my call! WM are tough, but I don,t take mine that far or hard. if it wont lift it by itself,I will help it with the loader (gently) if it will hold it,I will load it. then comes the point will I be able to get through it. I wont push a machine past it limits, because when you do that it costs money or headaches. I have had the Woodmizer off its back supports trying to lift a log up of center, if the log lift will pick it by itself,it gets sawn if not, how much are you paying! cause I,m near the breaking point. Don,t abuse your equipment, all it does is cost you in the end! Tim
Offline Bibbyman
  • Pro-Sawyer Mary and Bibbyman
    • Warden Sawmill
« Reply #7 on: October 30, 2011, 04:16:04 AM »
 Thatís just crazy!   I bet none of those guys own that mill.
Yea,  LT80.  Note the two axles and three loading arms and extra length.  I think they could saw up to 27í.
Yea, Europe.  They had two in the USA.  One they gave away to a mission in Africa and the other set behind WM in Indy for a long time until they finally (Iím told) cut it up for scrap.  They decided they didnít want to market them in the US.
Pictures taken at the Wood-Mizer 20íth anniversary party in Indy.
Sawing since '94
Offline Slingshot
« Reply #8 on: October 30, 2011, 10:40:28 AM »
        Bibbyman;
              I had never heard of the LT80 when I ran across this one on U-tube. I did a search
 on the forum and saw where you and  some others discussed them in 2007. And saw
 where Arkansawer was wanting one back in 2002. You also mentioned an LT60.
      I thought it was a monster of a saw and built to take what those guys dished out to it. smiley_bull_stomp
 sling_shot
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #9 on: October 30, 2011, 11:04:05 AM »
I would never abusd my mill like that , they cost to much :o :o and no log is worth that much. :D :D
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #10 on: October 30, 2011, 11:44:28 AM »
I thought that the whole process was scary, Halloween scary.
Offline Bibbyman
    • Warden Sawmill
« Reply #11 on: October 30, 2011, 12:51:45 PM »
       Bibbyman;
 sling_shot
The LT80 is just a stretched LT70.  More of everything.  It even had cant hold-downs.
The 16' length version of the LT70 was going to be an LT60 and maybe is so in Europe.   I think they've even dropped the LT30 (16' cut length) - if they build one today they'd probably call it an LT40.
I think WM USA wanted to standardize on the number of frame configurations.  Thatís my guess.
We can get YouTube on our TV through our Roko adapter.  I found the channel for these guys.  They have a bunch of uploads.  Many for loading this same log.  Looks like they tried a lot of things.  At one time it looked like they tried using a cable being pulled by the chain turner somehow.
Note too that it looks like the shield on the drive side is cut out.  Wonder why?
It would be plenty dangerous enough but add in the wet snow.  I know how that makes everything more slippery.
Sawing since '94
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #12 on: October 30, 2011, 02:40:42 PM »
I thought I was reading "LT80" when I watched the video's at 5:30-6:00 this morning.
I think that when loading the log onto the mill in that manner, I'd have liked to have had that back-blade raised up to stop the log and take some of the force off of the back-stops.  I could just about visualize that log cleaning all of the backstops right off the mill.  :o
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline pineywoods
« Reply #13 on: October 30, 2011, 03:12:59 PM »
Heck, I load stuff that size on my old manual mizer rather frequently. BUT, it's usually pine, not quite that heavy and I don't have a hydraulic loader. . There's a set of metal ramps comes with the manual mills. Using them it's fairly easy to parbuckle big logs up onto the mill. I don't pull them with the tractor, I use a hydraulic winch that just happens to be mounted on the tractor.   If you watch the video of them sawing that big log, you can see one of the big advantages of the cantilever head. One small notch chainsawed out of the side of the log, versus having to slab off the whole side of the log to clear the head.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #14 on: October 30, 2011, 06:01:07 PM »
The caption should say "why men live shorter lives".  :o
ďA pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty.Ē -Winston Churchill
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #15 on: October 30, 2011, 06:20:37 PM »
Was there anymore videos of the log being turned by its own turner, or did they use the tractor again, I sure wouldn't want to put all that force on the mill frame it was coming off the ground. That log should have been quartered  with a chainsaw.
Offline Ianab
« Reply #16 on: October 30, 2011, 06:27:30 PM »
We cut logs that size quite often.
My solution, leave the log where it is, and bring the mill to it.
Woodsy's solution - get a bigger tractor  :D
Either way, easier AND safer.
Offline Bibbyman
    • Warden Sawmill
« Reply #17 on: October 30, 2011, 06:30:13 PM »
Here is the link to the YouTube channel that the videos are on.  I see some 9 of them.  Some are only a few seconds long and you can see what they were trying didn't work!
http://www.youtube.com/user/Sosenkatartak#p/u
Sawing since '94
Offline Brian Moore
« Reply #18 on: October 30, 2011, 07:53:16 PM »
Can you say " Future Darwin Award winners".   Not if but When!
Offline logboy
« Reply #19 on: October 30, 2011, 11:26:02 PM »
I'm with Ianab.  Leave the darn thing on the ground and saw it with a swing blade.  No one gets hurt and no equipment is destroyed. Or find someone to chunk it into 10" thick slabs with their slabber and saw those on your bandsaw.
I like Lucas Mills and big wood.  www.logboy.com
Offline woodzy88
« Reply #20 on: October 31, 2011, 01:35:09 AM »
A friend of mine runs a lucas mill and a mahoe. He had a customer that had used a big russian helicopter to extract Rimu logs out of the bush to a flat paddock . there was still only limited access to the area and he dragged his lucas mill in with an atv . the logs were scattered around this paddock just as the chopper had left them. He just dragged the mill around on some 10 x2s from log to log and milled them up leaving stacks of timber and the waste and sawdust behind him . These were big heavy logs up to 5 tons and he milled the lot with only a timber jack to level the odd log and no other machinery. The timber was the got out to the road by atv and trailer. And from memory there was 50 odd logs so quiet a feat :) ::) 8)Just shows what can be done with the lucas mill , I intend to buy one to comliment my Mahoe.
woodzy88
Offline logboy
« Reply #21 on: October 31, 2011, 07:42:30 AM »
Not to hijack the thread, but how do you like your Mahoe? I'm wondering how it compares to my Lucas.
Offline Bibbyman
    • Warden Sawmill
« Reply #22 on: October 31, 2011, 08:20:51 AM »
They taste like grits.  Put a little butter on them and serve hot.   :D
Sawing since '94
Offline Bibbyman
    • Warden Sawmill
« Reply #23 on: October 31, 2011, 08:10:24 PM »
The LT80 is some monstor of a mill.  Kind of like two mills mixed together.
In this video you can see it has 2 clamps, 4 back supports, at least three roller toe boars and one power roller to move log forward/back on mill.  It has a chain turner and claw turner. Two axles, three loading arms.  It also has a spare tire mounted in the frame.  There looks to be an odd cutout in the drive side door.
The debarker looks like it's mounted different?
There looks to be an extension cord set up to run to the head.  I wonder if it's running the debarker?  It seems to be a lot more aggressive than our DC debarker.
Anyone figure out what country they're in?
Sawing since '94
    • A&P Saw mill LLC
« Reply #24 on: October 31, 2011, 10:26:22 PM »
I don,t know what country, but I would buy an 80 If they sold them here :o :o :D :D
Offline Slingshot
« Reply #25 on: October 31, 2011, 10:45:28 PM »
 Looked up the profile of Sosenkatartak and it shows the country to be Poland.
    sling_shot
woodmizer lt 28 whine under load
Started by NPsawyer on Sawmills and Milling
Last post October 31, 2016, 12:50:17 PM
by NPsawyer
temperature question - first load through DH4000 Nyle/woodmizer unit
Started by Dan_Shade on Drying and Processing
Last post March 20, 2012, 12:03:09 AM
by Dan_Shade
Woodmizer hydraulic mill and Woodmizer Edger
Started by Keith Edge on For Sale
Last post December 22, 2008, 08:11:51 AM
by Keith Edge
Another load of Dug fir
Started by Lonely Sawer on Sawmills and Milling
Last post August 25, 2014, 06:17:13 AM
by goose63
