Author Topic: Double Sawing w/Lucas  (Read 4009 times)
Offline logboy
« on: November 04, 2011, 10:23:53 AM »
Last night I was thinking how I wished I could cut wider boards with my Lucas 827 without having to lift 400 pounds of powerhead.  Has anyone tried removing the guards and double sawing like a Peterson? I have to believe it is a faster way of double sawing as no lifting is required.  On the downside the guards are all removed.
I like Lucas Mills and big wood.  www.logboy.com
Offline beenthere
Re: Double Sawing w/Lucas
« Reply #1 on: November 04, 2011, 10:31:06 AM »
Can you do that without "climb" sawing coming back?
Offline Ianab
« Reply #2 on: November 04, 2011, 03:15:55 PM »
You reverse direction of the horizontal cut when you are cutting from the other side.
Not sure on the practicality of removing the Lucas guards though? Will the design actually allow you to cut from the other side, even wiht some parts removed?
Offline logboy
« Reply #3 on: November 04, 2011, 05:10:25 PM »
In theory? Isnt that how the Peterson works?  I've only been around one Peterson.
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #4 on: November 20, 2011, 11:13:43 AM »
     Looking at my 1030, I see you'd have to remove a couple of side guards.  However, your depth of cut (IE the thickness of the board you'd be limited to) from the "wrong" side would only be about an inch.  Personally I wouldn't try it.
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline logboy
« Reply #5 on: November 20, 2011, 07:10:30 PM »
Nomad, how do you like your 1030?
Offline nomad
  • Member
« Reply #6 on: November 29, 2011, 08:34:02 AM »
     Logboy, sorry it's taken me so long to reply.  I like my 1030 a lot!  The only complaint I have is loading it into my pickup.  I could sure use some ideas on doing that alone.  In fact I think that's worth a post of it's own.  So...
Offline chainsaw_louie
« Reply #7 on: April 09, 2012, 12:20:24 PM »
Hi,
This is an interesting topic, I found some information elsewhere (woodweb.com) that pertains to this discussion.  The thought of 16" wide quarter sawn boards is a very tempting thought:
"was thinking about a wedge, or even a flat bar to take the weight of a heavy one just as the saw exits. So I guess you've concluded that it's more important to maintain the cutting directions than to worry about dropping the boards on the blade?
From contributor M:
Actually I put the wedge in at the beginning of the horizontal cut on big beams, as the Lucas has what is called a "riving knife" which is a 3/16" plate attached right behind the blade which keeps the kerf open where the blade is cutting. This is the reason that the Lucas needs the mill to be rotated to make a double wide cut. I have been told that some Lucas guys are removing the riving knife with no ill effects and are able to make the wide cuts without rotating.
From contributor C:
Peterson has a riving knife, too. They can do the big double cut without turning the head around because the motor doesn't sit over the blade like the Lucas.
From contributor A:
Contributor C, how can the return cut be operated with a following riving knife attached? Personally I would never remove this attachment. For one thing, if there was any incident for which an insurance claim was made then it would immediately be voided by this tampering with essential safety equipment. And second I donít find the head rotation that difficult even with one man. Just put on the wheels, drop the ground, unhook and rotate, replace, wind up to original level. Iím nearly always with 1-3 mm of off side cut which I find acceptable. The whole process is about 45 seconds. This is only used for the 2 or maximum 4 boards either side of the heart to maintain quarter-sawn properties. Otherwise it's a waste of time and wood.
I must say to all the Peterson owners that I certainly donít like the idea of horizontal cutting towards you when walking backwards over uncertain terrain. You can fall and your legs can be thrown into the saw - massive injury if not permanent incapacity. Too much of a risk. "
http://www.woodweb.com/knowledge_base/Oneman_swing_milling.html
-Tim
Offline Dakota
  • Swing'en in South Dakota
« Reply #8 on: April 10, 2012, 09:45:51 AM »
Here's an idea about lifting and swinging your saw head.  I bought the little winch at Costco for $50.  Lifting straps are just motorcycle tie downs.
Dave Rinker
Offline Silver_Eagle
« Reply #9 on: June 11, 2012, 11:18:41 PM »
That is a slick set up Dakota.
Double cutting w standard 8" Lucas
Started by chainsaw_louie on Sawmills and Milling
Last post September 20, 2012, 06:34:54 PM
by sigidi
Double Sawing
Started by Magicman on Sawmills and Milling
Last post January 14, 2011, 09:01:00 PM
by Magicman
Mobile sawing double check the site
Started by Finn1903 on Sawmills and Milling
Last post February 13, 2015, 04:03:40 PM
by Magicman
Sawing oak with my lucas 618
Started by Peder McElroy on Sawmills and Milling
Last post March 09, 2010, 01:30:28 AM
by sigidi
