Author Topic: Firewood  (Read 12975 times)
Re: Firewood
« Reply #40 on: February 22, 2004, 01:24:17 PM »
What always twisted my mind was making charcoal.  Those folks burn wood to burn the wood that makes the charcoal, then take the partially burned wood to stove and use wood to light it and then burn it for heat.  Seems kinda convaluted to me. :D
Offline Oregon_Rob
  • NW Oregon
    • Not open yet, but soon I hope
Re: Firewood
« Reply #41 on: February 23, 2004, 09:25:37 AM »
I have heard the best way to slow down a chimney fire is to throw a couple of cups of water on the fire and then shut the stove down as tight as possible. The theory is that the steam will help to slow down or extinguish the fire. Has anyone else heard this one?
On the soot build up side of things, some of the newer stoves really burn the wood so much more efficiently than the older equipment, that the build up is almost non existent. I am currently in the market for a stove and have pretty much settled on a Quadrafire.
It is really nice that the EPA tests all new stoves and gives a good set of impartial numbers for efficiency and grams per hour of smoke output.
With the newer stoves, you cant even tell, by looking at the top of the chimney, weather a fire is burring or not. All this has to add up to less stuff in the chimney.
Chainsaw Nerd
Offline beenthere
Re: Firewood
« Reply #42 on: February 23, 2004, 10:35:57 AM »
Oregon_Rob
Where is your resource for the EPA tests of all new stoves?  I would be curious to see these numbers, and figure they must be on a site somewhere. Thanks
Offline Oregon_Rob
  • NW Oregon
Re: Firewood
« Reply #43 on: February 23, 2004, 11:02:34 AM »
Here is the stove I am looking at:
http://www.quadrafire.com/products/stoves/woodStoveDetail.asp?f=3100actMILL
Here is an EPA document listing a bunch of different makes and models of stove and their numbers:
certifiedwood.pdf
If you do some more searching, you will find all the details about how they conduct the testing.
I wish there were more products that had independent testing like this.
Chainsaw Nerd
Offline beenthere
Re: Firewood
« Reply #44 on: February 23, 2004, 11:35:24 AM »
Thanks for the info site.
I found it interesting that the grams/hour particulates can be so low and the efficiency be low as well. Seems to be contradictory.
I did found my Vermont Castings Defiant stove, which came in at 0.8 g/hr and 72% efficiency. However this one has the catalytic converter. I like it real well.
Offline Jason_WI
  • He who dies with the most toys wins.
Re: Firewood
« Reply #45 on: February 23, 2004, 11:35:26 AM »
Salt will take care of the chimney fire in a quick hurry. All you need is an icecream pail full handy and slowly poor down the chimney.  This what my dad used to put out a few fires.
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
Offline Carl_B
Re: Firewood
« Reply #46 on: February 23, 2004, 05:39:01 PM »
Oregon Rob I bought a Quadra-Fire 4300 in 1996 it has the pedestal base the only thing that I would say make sure that you buy one that is big enoughf for the house that you are going to heat with it.All of the people that I talk to said that I didnot need one that big. I am glad that I got one bigger than I need. I have had no trouble with the stove they make a very good stove.
Offline Oregon_Rob
  • NW Oregon
Re: Firewood
« Reply #47 on: February 24, 2004, 07:19:05 AM »
Carl,
Thanks for the words. I feel pretty comfortable that it is the right one. I have a 95' 2000sf manufactured. In Oregon, that equates to 2x6 walls, vynal frame, double payne wndows...
so it's pretty tight. And I'm in western Oregon. We never get below zero, a very cold night is 10f and we didn't get that cold this year. I would guess our average low this time a year is something like 40.
I am feeling pretty good about the decision.
Did you get the step top or the flat top?
Chainsaw Nerd
Offline BW_Williams
  • Part time sawyer, East slope of the Cascades
Re: Firewood
« Reply #48 on: February 24, 2004, 08:18:21 AM »
Hadn't heard Chimfex went out of business, they made a good product and we've used them several times.  Be careful putting water in a chimeny fire as it violently expands 1700 times it volume and may cause injury or damage.  Haven't heard about potatoe peelings or salt.  I like Metalbestous pipe, never seen it fail during a fire, seen triple wall and single wall fail.  Be sure to screw your joints together, or county requires it on single wall, Metalbestous has locking rings.  Good luck and clean that chimeny at least once a year.  BWW
Support your local Volunteer Fire Dept.  (not by accident)
Support your local Ski Patrol (by snowboarding:)
Mayor of Millerdale, Washington, USA (by God)!
Offline Carl_B
Re: Firewood
« Reply #49 on: February 24, 2004, 05:04:27 PM »
Rob I have the flat top. I am heating 1300sf that is 40 years old even when it is 20 below zero no trouble in keeping up. I think that the pedestal base with ash pan is a real nice .
How long is split and stacked firewood viable as firewood.
Started by mart on Firewood and Wood Heating
Last post August 28, 2014, 06:05:10 PM
by mart
Firewood bags and a firewood bagger?
Started by jayinwww on Firewood and Wood Heating
Last post June 30, 2015, 08:54:23 AM
by CTL logger
Kiln direct firewood kiln and dyna firewood processor
Started by Pclem on For Sale
Last post March 19, 2019, 08:31:11 PM
by Pclem
Got your firewood done yet?
Started by uplander on Firewood and Wood Heating
Last post August 28, 2014, 06:19:55 PM
by mart
