Author Topic: Will AnchorSeal Melt Off In A Kiln ?  (Read 2690 times)
Offline UNCLEBUCK
  • Life out on the prairie !
« on: January 26, 2004, 09:02:20 PM »
Last year I used paint on log ends but this spring I am going to use anchorseal on the log ends and then right from the sawblade all boards going into solar kiln. Will AnchorSeal stay on or is it going to melt off .Should I order anchorseal or not ! Please respond and many thanks to Jeff and crew for this great new spot on the wonderful forestry forum !  8)
Offline Norm
Re: Will AnchorSeal Melt Off In A Kiln ?
« Reply #1 on: January 27, 2004, 04:24:23 AM »
I won't melt off UB, it seems to soak in better at higher temps. I like to put one coat on the logs after I've freshened up the cut, then let it dry a day and then put another coat on.
Offline Frank_Pender
« Reply #2 on: January 27, 2004, 05:52:13 AM »
UB, for me, I have had no problem with it melting off.  Like was said, it seems to become more permanent to the end of the board while in the kiln.  I get my kiln up to 165* for at least 3 or 4 days atthe end of the cycle with no problems witht the seal. ;D
Offline UNCLEBUCK
« Reply #3 on: January 27, 2004, 12:22:16 PM »
thanks Frank and Norm , sounds simple enough but I just did not know .  Does anchorseal gunk up the planer much when planing after the board is dry?   :P
Offline Norm
« Reply #4 on: January 27, 2004, 02:17:05 PM »
Nope is doesn't UB, there is such a thin layer your taking off in the planer you don't notice it. :)
« Reply #5 on: January 27, 2004, 07:46:55 PM »
UB, I have coated whole boards on both sides and still run them through my 8" x 20" planer and not had any such problem.   The is also no problem with the Grizzely exhaust system which pulls the material through a 6" pvc pipe that has two 90* turns, before going outside onto the forest floor.
Offline UNCLEBUCK
« Reply #6 on: January 27, 2004, 08:46:58 PM »
thanks Frank, that is good to hear. I have a grizzly 15 inch planer but I took off the dust collector snout as I dont have any more room in my little woodshop so I crank up the air hose and open the doors now and then but sure would be nice to have a dust collector . This anchorseal sounds like good stuff and am going to order 5 gallons soon so I always wondered about this question . I guess I have another question about anchorseal and that is like from now until spring thaw if I am cutting oak and ash trees down and everything is frozen , could I wait until spring to apply anchorseal to the log ends because the logs are frozen solid right now . thanks again
Offline Norm
« Reply #7 on: January 28, 2004, 04:29:35 AM »
If you get a day where it's above 20F or so I'd put some on UB. The folks at anchorseal are real nice and you can call and ask them what they think. Don't e-mail them cause they're not very good at answering those.
https://www.uccoatings.com/prod_anchorseal.php
I wonder why they use a secure server for their index page, do you know Jeff?
sad
Snow melt !!!
Started by isawlogs on General Board
Last post April 15, 2011, 11:23:18 PM
by Coon
What I used to do, while waiting for the snow to melt.
Started by tgalbraith on Sawmills and Milling
Last post March 26, 2013, 09:39:01 AM
by tgalbraith
Sawing in the rain...will my LT40 melt?
Started by bkaimwood on Sawmills and Milling
Last post June 19, 2016, 08:13:27 AM
by scully
anchorseal
Started by redpowerd on General Board
Last post May 04, 2010, 03:25:17 PM
by metalspinner
