Author Topic: Forwarders 8 wheel VS 6 wheel  (Read 3752 times)
Offline RobertR.
« on: December 09, 2011, 07:23:12 PM »
I've been looking at forwarders for quite a while now trying to learn the ins and outs and all that. Does anybody have any experience with 6 wheeled vs 8 wheeled? I know that the bogies provide a lot more maneuverability over obstacles and all but are there any pro's to going with a 6 wheeled machine?
Object to logging? Try using plastic toilet paper.
Offline bushmechanic
  • Someone else has it worse than you.
Re: Forwarders 8 wheel VS 6 wheel
« Reply #1 on: December 09, 2011, 07:33:02 PM »
The only difference I can see would be the extra cost of the replacement of the extra tires and tracks if equiped.The eight wheeled machine rides a lot smoother than the six and will travel on rougher terrain.
Offline Jamie_C
« Reply #2 on: December 09, 2011, 07:43:26 PM »
The 8 wheel won't be quite as manueverable as the 6 wheel drive but it will also be a lot rougher. If you want to haul big payloads with minimal ground disturbance then go with the 8 wheel.
I have driven 8 wheel drive Rottne's, Ponsse's & John Deere's and there just isn't any comparison to a 6 wheel drive in 99% of the circumstances.
Offline RobertR.
« Reply #3 on: December 09, 2011, 08:52:48 PM »
I'm used to running my fathers Clark rangers so I imagine I'll be used to the bumpier ride. Would you happen to know where I could find the spec sheet for a Valmet 860.1?
Offline Jamie_C
« Reply #4 on: December 10, 2011, 06:12:43 AM »
I would try the Komatsu Forest website.
Online snowstorm
« Reply #5 on: December 10, 2011, 07:58:05 AM »
never ran an 8 wheel mine is 6. like they say the 8 rides much better. also 2 more very expensive tires to buy and tracks.
Offline Jamie_C
« Reply #6 on: December 10, 2011, 08:21:53 AM »
Most contractors up here run chains on the front and tracks on the rear. I have only once worked in ground bad enough that we needed tracks front and back to climb the hills. It takes quite a hill before an 8 wheel drive forwarder with chains on front won't climb it.
Offline Gary_C
  • Sunrise on the Prairie
« Reply #7 on: December 11, 2011, 12:43:35 PM »
There are no big differences between a 6 wheel and an 8 wheel forwarder other than the obvious more manuverability for a 6 wheel machine and more flotation for an 8 wheel machine. I would consider ride as not being a major consideration as they both can be rough riding depending on terain. But the difference in ride is small and perhaps slanted slightly to the 8 wheel machine. So they both can do the job depending on your particular needs.
There are other things that are more significant than ride, manuverability, and flotation. Things like having an electronic automatic transmission for huge productivity gains and good loader controls too. The condition of the machine is also very important.
I have a Valmet 840 that is a six wheel machine. It is one of the earlier ones with the 4 cylinder Sisu engine and it is red painted so it may be an 840.1. I believe the 840.2 has a six cylinder engine. I don't think I have any spec sheets anymore and the 860's were just slightly larger and always came with the six cylinder engine.
Offline barbender
« Reply #8 on: December 11, 2011, 05:33:08 PM »
I know guys that went from 6 to 8 wheel machines and didn't like it, you get to run every stump over twice.
Opinion: Band wheel w nothing btw blade and wheel
Started by chisel on Sawmills and Milling
Last post June 14, 2004, 02:26:41 PM
by Fla._Deadheader
Help with Timberjack 450 dead wheel "3 wheel drive"
Started by Spartan on Forestry and Logging
Last post September 09, 2015, 09:59:48 PM
by Spartan
question
CBN wheel wheel worn out?
Started by JustinW_NZ on Sawmills and Milling
Last post May 09, 2013, 08:32:16 AM
by tommone
wheel
Started by Ronn5072 on General Board
Last post April 29, 2019, 07:10:01 PM
by Ronn5072
