Arborwear
Author Topic: DIY Fellerbuncher  (Read 26423 times)
Offline northforker
DIY Fellerbuncher
« on: December 14, 2011, 11:48:42 PM »
Greetings,
I'm new to the forum but have stopped in for a look several times over the years and have picked up lots of useful information from the knowledgeable folks here. I'm not a professional logger or a fabricator, just a guy who has about 50 acres of trees and tired of harvesting them by hand. That said, here's some pics of a fellerbuncher attachment for a skidsteer I recently completed. I only had time to test it with a dozen or so trees before the snow flew, but it seems to work real well and zips right through. It's your basic hotsaw or disc saw scaled way down. The disc is 5/8" X 36" dia T1 steel with 12 Quadco 1-1/8" teeth mounted on the rim. I use my ASV's 25 gpm circuit to spin the disc at 900-1000 rpm and the other circuit for the grab arm. I'll fab a bunching arm for it over the winter. I've designed it to cut a 14" stump maximum for safety's sake. I can't wait 'til spring to use it more!
Offline islandlogger
    • www.independentlogging.webs.com
Re: DIY Fellerbuncher
« Reply #1 on: December 15, 2011, 12:00:12 AM »
Welcome to this here forum northforker!
Say, that's some nice fabricating you done there! Nice looking unit, I can see you will have plenty of fun with that come Spring!!
Offline mad murdock
« Reply #2 on: December 15, 2011, 12:49:55 AM »
Welcome northforker. That is serious skookum you got on that tracksteer loader 8) nice job!!
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline sprucebunny
  • Gender: Female
« Reply #3 on: December 15, 2011, 06:51:31 AM »
Welcome to the forum !
That is too cool  8)
Any guesses what it cost you to make ? What was the hardest part ?
I think I've found a winter project !!!
Offline thecfarm
« Reply #4 on: December 15, 2011, 06:57:12 AM »
northforker,welcome to the forum. With a nice looking project like that one,there must be others?
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« Reply #5 on: December 15, 2011, 07:28:25 AM »
Nice looking project and welcome.  I'd get in trouble with one of those things!  ;D
Look forward to more action shots!
-Matt
“What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.”
Online chevytaHOE5674
« Reply #6 on: December 15, 2011, 08:34:48 AM »
Very nice work. I too would get in trouble with that. I would have the entire farm treeless just because it was so fun to play with. hahaha  8)
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #7 on: December 15, 2011, 08:55:41 AM »
All I have to say it WOW!!! I like it!!!!
The First 60 years of childhood is always the hardest.
Offline northforker
« Reply #8 on: December 15, 2011, 01:06:38 PM »
Thanks for the comments guys! Yeah, my wife saw the "Here's Johnny" look in my eyes the first time I fired it up and was very concerned for her trees. Yes, you do just want to cut everything down just for fun, kinda shaking like a junkie looking for his next fix.
I'd say the hardest part of building this thing was just figuring out how to do it. I went back and forth between building a tree shear, a bar saw feller, and the disc saw. Each has its set of pros and cons and that's why all of these solutions have been around for a long time. Because I have a relatively light carrier, weight played a big part in my decision. I wanted to build something sturdy, but have enough payload left over to actually carry a stem or two without tipping over. This ruled out a shear type of buncher as the high capacity ones (Dymax, Ryans, etc.) weigh in at around 1800 lbs. plus.
The bar saw feller is probably the most lightweight solution as there's no element of brute force to do the cutting. However, even a simple bar saw design ends up being relatively complex and requires a minimum of 3 hydraulic functions, 1 to turn the chain, 2 to grab the tree, and 3 to move the bar through the tree. Then there are the issues of oiling the chain, maintaining proper chain tension, and modulating the bar feed speed with chain speed. It's a fun to think about how to solve these little mechanical challenges, but I wanted to be cutting trees not tweaking a design until I got it functioning right. It seemed that the disc saw is the best combination of light weight and simplicity, just a big spinning disc and an arm basically. Cost-wise, I think all would end up being similar, with the shear being the cheapest and the bar and disc designs costing about the same.
I spent a lot of time just figuring out a workable design and what components I would use. Most fabrication time was spent on turning down the old truck axle. It is hard, hard stuff, probably 4140 chrome moly, and I have a cheap chinese 3-1 machine to do the work. I finally figured out that turning very slowly with carbide tool bits and lots of coolant worked taking off only a few 1000's at a time. Even drilling dimples for the setscrews in this stuff was impossible with HSS drill bits. I finally tried carbide tipped masonry bits (a few bucks at the hardware store) that worked very well.
Cost-wise, I figure I'm in the $2500 range on this project when you add it all up. The most expensive component was the hydraulic motor (~ $700) and the heavy duty type E Moline flange bearings (~ $400 for two). The Quadco teeth were about $150 at Baileys and steel was probably another 6-700 bucks or so. Throw in a few hundred more for hydraulic hose/fittings, double crossover relief valve, nuts/bolts, etc. Adding a bunching arm will cost a couple of hundred more for the cost of a small cylinder plus some kind of circuit splitter/selector valve.  Anyway, not too bad considering that a shiny new one built by real fabricators cost north of $25,000. I'd love to have one of those but, well you know...
Offline Coon
« Reply #9 on: December 15, 2011, 01:19:06 PM »
That would be a nice rig to play on, however, on my land you would end up doing just as much if not more hand felling due to timber size and also due to the windfalls and such.
Why wait for spring? A man's gotta get his fix of sawdust ya know.  ;)  ;D
Offline Raider Bill
« Reply #10 on: December 15, 2011, 01:42:18 PM »
That would sure work for me as a weekend/monthly wannabe logger trying to thin out my land. Hat's off to you northforker!
Offline barbender
« Reply #11 on: December 15, 2011, 01:58:02 PM »
Very nice work! I'd like to build a bar saw dangle head for my skid steer. My problem is I only have one hydraulic circuit, and it is only 16 gpm.
Offline thecfarm
« Reply #12 on: December 15, 2011, 07:01:35 PM »
northforker,if Raider Bill ask to borrow it say NO or he'll return it all burnt up.  :D
Offline semologger
« Reply #13 on: December 15, 2011, 07:07:22 PM »
from were did you learn to do fab work that well at? Very well done.
Offline simplicityguy92
« Reply #14 on: December 15, 2011, 08:31:40 PM »
did you build or by the saw?
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #15 on: December 15, 2011, 08:37:40 PM »
That is one cool build.  And welcome to the forum.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline treefarmer87
« Reply #16 on: December 15, 2011, 09:57:07 PM »
welcome to the forum :) very, very nice job 8)
1990 Ford F-800
1974 Ford L 9000 Self Loader
1994 John Deere 648E
1985 Franklin 170 Forwarder
John Deere 440 B
1980 Treefarmer C6D grapple
Prentice 210
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 660
Jonsered 2172
Jonsered 2255
Offline northforker
« Reply #17 on: December 16, 2011, 02:09:05 PM »
Thank You all again for your comments. Here's a couple more pics from the build. As you can see if you look close, I'm not a great fabricator. My goals are always simple, things that are made to stick together should stay stuck together, things should m/l work as they are designed to, and that nobody gets hurt. Anyway, as my Dad always said, "If you can't learn to be a good welder, learn to be a good grinder."
Offline northforker
« Reply #18 on: December 16, 2011, 02:23:15 PM »
BB, You can do a lot with 16 gpm as long as you don't want to do it fast or do it all at once. An advantage of the bar saw design is that you grab on to the tree first. This allows you to take as much time as you need to saw through. Have you seen Danzco'z website (http://www.danzcoinc.com/html/standard_saw_components.html)? They sell hydraulic chainsaws and components that you could incorporate in a design. Their basic chainsaws are powered by gear motors using from 10 gpm up to 30 gpm. I have no idea what they charge. I think they are using Cross gear motors that will run a couple of hundred bucks new that you could source yourself. One thing I'd be interested in if I was making a bar saw is their feed and motor control valve. This stuff becomes more important with lower gpm/psi available.
Offline northforker
« Reply #19 on: December 16, 2011, 02:31:22 PM »
I hear you on that, but most of my trees are 7+ miles off any kind of plowed road and the snow is *deep*. This is what we use to get there in the winter:
Franklin 170 fellerbuncher
Started by Duramax3500 on Forestry and Logging
Last post July 24, 2017, 06:09:28 PM
by Duramax3500
Timberpro 620e fellerbuncher
Started by logger444 on Forestry and Logging
Last post September 28, 2009, 03:08:15 PM
by PAFaller
does anyone make a 30k Lbs self leveling fellerbuncher or evc.
Started by sjfarkas on Forestry and Logging
Last post April 24, 2010, 04:02:53 AM
by ford62783
Rubber tired TigerCat FellerBuncher 22" hotsaw
Last post September 02, 2009, 06:06:13 PM
by MDLogging
