Author Topic: Which glue?  (Read 3198 times)
Offline Brad_bb
Which glue?
« on: December 20, 2011, 03:57:47 AM »
I split a piece of pine 2X material that I need to glue back together.  It won't be exposed to the elements.  Should I use yellow woodworkers glue or urethane (gorilla) glue?  And why?
Offline Ianab
Re: Which glue?
« Reply #1 on: December 20, 2011, 05:25:35 AM »
As long as you can get a good spread of glue and clamp it up properly while it cures, it wont matter. Modern wood glues are stronger than wood anyway. If it fails again, it wont be at the glue line.
Save the Gorilla glue for when you need it waterproof, it's a messy overkill for normal work.
Offline SwampDonkey
  • Large Tooth
Re: Which glue?
« Reply #2 on: December 20, 2011, 06:19:40 AM »
Lepages or Titebond will do it. As Ian said it's stronger than the wood bonds. I find Lepages to be the strongest carpenter glue, but I use Titebond because I can buy it cheaper by the gallon jug. Both glues made in Ohio.
Move'n on.
Offline Busy Beaver Lumber
    • Busy Beaver Lumber
Re: Which glue?
« Reply #3 on: December 20, 2011, 10:04:45 AM »
I would use the titebond glue. I use a lot of it, about 10 gallons a year, and have never had a glue joint failure with it. Just make sure you wipe of any excess real well with water or it will not allow your stain to penetrate that area
I would be hesitant to use the gorilla glue as it has a tendency to expand and push parts apart when it cures. It would however be good for repair a very loose chair leg assembly, or any other assembly that has a lot of play in the joint due to its expansion property, but just make sure you clamp it well or it will tend to push the joint apart as it expands.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
Re: Which glue?
« Reply #4 on: December 20, 2011, 09:57:36 PM »
I like the titebond 3. Like any good glue make sure that you have a good coat on all the surface. It has been good for me. bg
Offline Brad_bb
Re: Which glue?
« Reply #5 on: December 21, 2011, 01:41:45 AM »
ok, Thanks for the input guys.  Titebond it is.
Offline Den Socling
  • just wondering
Re: Which glue?
« Reply #6 on: December 21, 2011, 02:25:08 PM »
I like Titebond, too. But if you do butcher block that you plan on planing with knives, kiss the knives goodbye.
Offline Norm
Re: Which glue?
« Reply #7 on: December 21, 2011, 02:43:00 PM »
Why's that Den?
Offline beenthere
Re: Which glue?
« Reply #8 on: December 21, 2011, 04:39:40 PM »
Are we talking Titebond III here?
There are many different Titebond glues.
Offline Brad_bb
Re: Which glue?
« Reply #9 on: December 21, 2011, 06:21:09 PM »
If you're asking me, I'm not sure.  I know I have titebond in the shop, red label I think.  Maybe it's titebond II?
What should one use if doing a butcher block style glue up and planing?
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
Re: Which glue?
« Reply #10 on: December 21, 2011, 06:52:54 PM »
Some magazine (years ago) did a test of glues and found Titebond II was stronger than III. III is for use in wet conditions. At least that's how I remember it.
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Offline SwampDonkey
  • Large Tooth
Re: Which glue?
« Reply #11 on: December 21, 2011, 10:03:15 PM »
I use Titebond 2, it's waterproof (interior/exterior) and can be used on butcher block.
Lepages is interior and has 2 tonnes of bonding strength.
Move'n on.
Offline DouginUtah
Re: Which glue?
« Reply #12 on: December 21, 2011, 10:18:46 PM »
I've got to correct you, Bill. II is water-resistant, III is water-proof. III has a longer open time and is good to use on oily woods.
-Doug
Offline 5quarter
    • Blue Harbor Refinishing
Re: Which glue?
« Reply #13 on: December 21, 2011, 11:49:28 PM »
Brad...use titebond III. It has a longer tack time. It is in fact stronger than II. I have tested both extenively. Both will work fine for your application, but TB III will work better.
Offline jamesamd
Re: Which glue?
« Reply #14 on: December 22, 2011, 12:35:44 AM »
I use Devcon 2 ton epoxy for cutting boards,no proplem with planning.
I also use Titebond II&III depending on moisture levels to deal with.
Jim
All that is gold does not glitter,not all those that wander are lost.....
Offline DouginUtah
Re: Which glue?
« Reply #15 on: December 22, 2011, 12:47:11 AM »
I found a reference to the testing done by Wood magazine--somewhat dated, and, as I remembered, Titebond II was found to be stronger than Titebond III. Gorilla was found to be much better than both in the submersion test.
http://www.diyprojects.info/bb/ftopic70-0-asc-0.html
-Doug
Offline SwampDonkey
  • Large Tooth
Re: Which glue?
« Reply #16 on: December 22, 2011, 04:43:33 AM »
Doug, your right. The word over the little ducky on the label is "weatherproof". My brain registered it as waterproof. Seems like it must be waterproof though (rain is water), but maybe that refers to submersion. ;D
Move'n on.
Offline Den Socling
  • just wondering
Re: Which glue?
« Reply #17 on: December 22, 2011, 08:53:16 AM »
Norm, One time I made a counter with strips of tropical hardwoods and Titebond II. I ran it through my planer with new knives. The knives ended up nicked. I always blamed the glue joints. I would be glad to be corrected if the glue didn't do the nicks. The counter is still laying in the shop. Den
Offline metalspinner
Re: Which glue?
« Reply #18 on: December 22, 2011, 09:43:57 AM »
Hardened glue will nick your knives.
After the glue firms up a bit, I always scrape off the squeeze out.  That lets the glue up sit flat on the planer bed, too.  It also reduces he chance of nicking the knife.
If the glue up is going straight to the sander, I scrape off all traces of excess glue on the surface. I have ruined too many drum sanding strips by being impatient with scraping glue.
Offline Norm
Re: Which glue?
« Reply #19 on: December 22, 2011, 09:45:44 AM »
Thanks Den, I'm about to make up an end grain cutting board. I used Titebond II for it but I have a spiral cutterhead in my planer. I was going to just run it through my drum sander but now Chris has be wondering which way to go.
Can you use calking glue to glue logs together?
Started by Rod on Timber Framing/Log construction
Last post February 28, 2005, 10:45:59 AM
by Rod
Glue up
Started by stumpy on General Woodworking
Last post May 15, 2019, 02:08:17 PM
by Larry
Glue-ups
Started by D._Frederick on General Woodworking
Last post March 27, 2009, 09:40:54 AM
by Modat22
Glue????
Started by Jno wood on Timber Framing/Log construction
Last post May 01, 2018, 09:24:04 PM
by Brad_bb
