EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Tool for Millers Falls Chuck nut  (Read 1007 times)
Online Brad_bb
    • My timberframe blog
« on: December 29, 2011, 03:15:02 AM »
I've taken a few of the chuck shaft nuts off of a Millers Falls boring machine with the hammer and chisel method, but that leaves marks.  I finally found the correct tool.  It's hard to fit a tool in that space for that large thin nut,but I found a Low Profile 32mm oil filter socket at the auto parts store.  Around here if I need a specialty tool, I go to CarQuest.  I also see them available on line via google shopping and ebay.  This special low profile socket is made for some GM 2.2 litre engine oil filter.  It's 3/8" drive, and I use it with a 3/8 breaker bar to keep the setup as short as possible.  It works perfectly for the millers falls nut.  This nut is usually not very tight so it shouldn't take much to break it free.  The right tool for the job.
Millers Falls Dimensions
Started by Brian_Weekley on Timber Framing/Log construction
Last post September 14, 2015, 09:26:20 AM
by jueston
Introduction / Millers Falls
Started by Laurence on Timber Framing/Log construction
Last post July 16, 2012, 10:54:34 PM
by Laurence
Millers Falls Boring Machine
Started by D L Bahler on Timber Framing/Log construction
Last post April 20, 2013, 07:58:59 PM
by D L Bahler
Millers Falls Seat material?
Started by Brad_bb on Timber Framing/Log construction
Last post April 03, 2011, 04:18:04 PM
by Jim_Rogers
