Arborwear
Author Topic: Thick slab glue up  (Read 8364 times)
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
Thick slab glue up
« on: December 30, 2011, 06:25:45 PM »
I'm looking for some ideas on improving my method.  frequently I need to glue up slabs as thick as 2", wide as 12", and long as 8'.  The problem is getting a good edge on them so they glue up clean and seamless.  I use biscuits and Tightbond 2 glue.  The problem is, if I rip them on the mill, they're fairly true, but not good enough.  I tried running them thru my joiner, but they're just to big to handle.  I tried the table saw, but because they're so big, it's hard to control the cut.  Any ideas????
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Offline tyb525
  • Always learning.
Re: Thick slab glue up
« Reply #1 on: December 30, 2011, 06:37:38 PM »
Circular saw and good blade, with a long, stiff straightedge (metal or hardwood). Clamp the straightedge to the board and run the base of the saw against it.
Online Ianab
« Reply #2 on: December 30, 2011, 07:20:09 PM »
I've mounted my big router on the mill carriage. Put a large flat cut bit in the router and you can joint and plane pretty much any  size board, and get it as true as your mill's rails.
Offline shelbycharger400
  • m14/04 0
« Reply #3 on: December 30, 2011, 08:18:36 PM »
i use a pro's edge  (menards) and a skill saw.
I must add,  pro cabinet shops use LONG toe and foot boards on their jointers
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #4 on: December 31, 2011, 06:27:47 AM »
     Try a long, wide straight edge made of something thin and hard clamped to the board.  Use a router with a 2" long pattern/trim bit.  You can get them with the bearing either on the top, bottom, or both.
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline LeeB
« Reply #5 on: December 31, 2011, 09:00:17 AM »
You can also use the skilsaw/straight edge combination by laying the two boards to be glued side by side. Use some cleats and wedges to lightly clamp them together. Position the straight edge so the cut will be centered on the seem down the middle. Any discrepecies will be mirrored from one edge to the other.
Offline Rooster
  • Tools are extensions of ourselves... share a tool.
    • Photobucket image storage account
« Reply #6 on: December 31, 2011, 10:28:46 AM »
Stumpy,
Here are a couple ideas:
Build portable workbenches on lockable casters that will double as infeed and outfeed tables for your table saw.
Use a 18" x 96" ripped slice of 1/2" cdx plywood, and clamp your 2" stock to the top...use the factory edge of the plywood against your fence. Carraige bolts, wing nuts, and some hardwood blanks can be used to hold the stock in the correct position.
Also, there is a company in Madison called The Workbench Tool Company
http://www.workbenchtool.com/
...and they may still have a straight line rip saw.  It takes rough sawn lumber and edge cuts automatically.   Might be worth the trip "Out West" to get a quality product that you don't have to fight with...and get a good seamless glue-up.
Good luck,
Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Offline purple otter
« Reply #7 on: December 31, 2011, 06:14:35 PM »
A few years ago I built a dining table out of 3" thick white oak.Like you said it is HEAVY.In order to handle the planks I built infeed and outfeed tables for my jointer.They were only as wide as my jointer and have adjustment screws onthe legs.The tops were melamine to help the material slide better.I also ripped everything to 6",this not only made it easier to handle ,but allowed me to true  up one surface on the jointer before planing them.I know it sounds bad ripping a nice 12" piece in 1/2,but when they are glued back together you honestly can't see the joint.Good luck!
Hudson Oscar 228 on homebuilt trailer, Kubota B2320 with homebuilt forks,Stihl 028 Super & 029 Super, Solar Kiln .
Offline scsmith42
    • Whispering Pines Farm
« Reply #8 on: December 31, 2011, 10:11:35 PM »
Depending upon your budget, I would suggest two options.
Option 1 - Festool track saw (the larger one).  Expensive, but phenominal quality.
Option 2 - a high HP router with a straight bit and an edge guide.  Less $ than the Festool, and more versatile.
Option 2 is probably the most commonly used option for achieving a straight edge on longer boards.
Tom's 3638D Baker band mill
Offline beenthere
« Reply #9 on: December 31, 2011, 10:17:46 PM »
The slightes change in moisture content will likely change any straight edge obtained.
So quick assembly after straightening the edge will be important as any crook will not likely be removed by clamping.
purple otter has a very good idea for thick material.  ;)
Offline Norm
« Reply #10 on: January 01, 2012, 08:24:16 AM »
I have the festool track saw Scott talked about and it works great.
Offline red oaks lumber
« Reply #11 on: January 01, 2012, 09:09:36 AM »
finding someone in your area that has a straight line rip saw will be the cheapest, fastest, most accurate option :)
« Reply #12 on: January 01, 2012, 05:21:15 PM »
Here is a  picture of the jointer extention ,and the dining table.
Offline beenthere
« Reply #13 on: January 01, 2012, 06:13:10 PM »
I have similar jointer extensions for long pieces on the jointer as well.
I see you are getting some top shrinkage in the table but have allowed for it to slide in the end caps.
Offline stumpy
« Reply #14 on: January 01, 2012, 06:33:38 PM »
Thanks for all the input.  I'm reminded why I'm a member here.  keep it commin 8)
« Reply #15 on: January 01, 2012, 06:54:13 PM »
Beenthere,the 3"oak airdried for7years and the 40"top shrunk 1/2",not too bad.
Offline SwampDonkey
  • Large Tooth
« Reply #16 on: January 01, 2012, 07:03:28 PM »
Like beenthere says about truing up the edges, make sure you use it soon or it will move out of square over a few days.
Dirty Harry
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: January 01, 2012, 08:21:19 PM »
Yup, you gotta allow wood to do what wood does.  I built a Grandfather clock out of Pecan once.  Well, I should say "was building".   :-\  I finally had to scrap the entire project because I did not allow enough room for shrinkage with some wide raised panels.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #18 on: January 01, 2012, 08:29:29 PM »
Purple Otter,
The sliding dovetail on the breadboard end is a very nice design feature!
Offline Ironwood
    • http://www.branchandburl.com
« Reply #19 on: January 01, 2012, 08:36:17 PM »
Well, others have said this but, for what is worth I make my living building with BIG thick material. Delivering a 22' walnut bartop to downtown Pittsburgh tomorrow morning. Tree was lightening struck lightly, see the check in the pics. Also, it is in priamrily two pieces with a third center "marque"
 The straight edge router is THE way to go. Skip Festool (sorry guys) unless you have other uses for their system(s),...$$$
 Go to an aluminum supply shop and get/order a 1/2" or 5/8" x 4" piece of high tensile aluminium (40/20 I think)  "flat bar" , Mine is 12' long and it get used frequently for just this purpose. Forget about add-on tables (although I have them on my 16" Oliver jointer) the straight edge is the way to go. I even have a hidden hole in the wall on the outfeed side of the jointer for the boards to go out if they are longer than 9' or so ::)
 It stays true and will last and last. mine was $150 many years ago. Pic looks shiny, it dulled down when it dried (I HATE shiny)
Ironwood
How do you glue up thick table tops?
Started by ozarkgem on General Woodworking
Last post June 03, 2015, 12:03:25 AM
by 5quarter
3 foot wide x 6" thick x8' 6" long Pine slab
Started by Curly_Woods on Sawmills and Milling
Last post October 12, 2003, 09:05:32 PM
by ARKANSAWYER
Can you use calking glue to glue logs together?
Started by Rod on Timber Framing/Log construction
Last post February 28, 2005, 10:45:59 AM
by Rod
how thick is your firebox. Mine from Central Boiler is not as thick as you think
Started by Mocha2324 on Firewood and Wood Heating
Last post March 15, 2016, 11:38:06 AM
by Bert
