KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: got a 208d tj, have some questions  (Read 3145 times)
Offline jocco
Re: got a 208d tj, have some questions
« Reply #20 on: January 09, 2012, 06:55:13 AM »
Bottom line you got to get the drum off. Could be a failed shoe binding up? broken spring or retainer? If opening the bleed did not release it, its not a dirty master cyl etc.
You may check out but you will never leave
Offline Sunrise Farms
« Reply #21 on: January 09, 2012, 05:28:01 PM »
My guess is that it was parked with the micro lock on for a while and the hinge part of the shoe rusted together so they arent returning when the pressure is off
Is it going to cause any damage to drive it around some and hope that it works loose?
How about driving it untill the pads wear out enough?
'84 timberjack 230a
'96 Woodmizer Lt40hdd40
Primero 8 forwarding trailer
« Reply #22 on: January 12, 2012, 06:12:28 PM »
So I got it apart. It seems to just be missing the return spring. The  cylinder seemed a little sticky. Those two and some brake clean should get me back together.
Does anyone know if that drum brake setup is from  any common truck? Id rather go to my local gut to get it than call Nash and wait for it to ship, and pay shipping...
'84 timberjack 230a
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #23 on: January 13, 2012, 06:55:54 PM »
Hey Sunrise farms congrats on the 208,that is a really nice machine.The brakes are a sore point ,rarely do they work properly.In order to get the brake drum off you will probally have to back the shoes off,the shoes usually wear a groove in the drum and makes it impossible to get it apart.There are nuts on the backing plate which work as a cam system to move the shoes out against the drum for adjustment,release those and you drum should come off.Check to see if there is any oil on the shoes,if so replace the oil seal.If the shoes are not sticking upon operation then I think your problem may be in your master cylinder or a kinked line.Good luck.
TJ 208D parts ??
Started by g_man on Forestry and Logging
Last post May 04, 2016, 06:59:03 AM
by Woodhauler
Timberjack 208D-SOLD
Started by madmari on For Sale
Last post January 23, 2012, 07:50:56 AM
by PAFaller
Timberjack 208D grapple skidder (w/pics, and now it runs!)
Started by Dave Shepard on Forestry and Logging
Last post May 06, 2014, 09:58:49 PM
by ga jones
Timberjack 208D serial number with plate missing
Started by MEFor3470 on Forestry and Logging
Last post November 14, 2012, 10:19:54 PM
by thecfarm
