KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Kohler 30 Hp Engine  (Read 3270 times)
Offline Bodger
Kohler 30 Hp Engine
« on: January 10, 2012, 09:10:46 PM »
I purchased a Kohler  CH750-0003 with about 100 hours to stand in while I rebuilt my Onan.  It had been setting up for quite a while and needed an ignition module.  I ran it for 50 - 65 hours and it ran like a champ.  Just before I pulled it off I replaced a head gasket.  The Onan is running like a champ now and I don't really need a back up so I'm selling.  It has the HD air filter and the muffler which points right (from flywheel side).  I also will include the 2" blocks needed to retro fit to a WM LTHD40 (mine is a '95) and the three grove pulley.  It should bolt right onto the same series Woodmizer.  I am located in South Alabama and really would prefer you to pick up.  I was satisfied with the Kohler but like the idea of staying stock with the Onan.  Price is $1100.  My number is 334 222 1528.  Please call before 8:30pm central time.  Thanks
Work's fine for killing time but it's a shaky way to make a living.
Offline LOGDOG
Re: Kohler 30 Hp Engine
« Reply #1 on: January 10, 2012, 09:29:33 PM »
Bodger,
Can you take a tape measure and measure the height of that motor from the base to the top of it's highest point for me? I have an edger that it might work well on. I've got a 3 phase motor on it now and wouldn't mind swapping out.
Offline Bodger
« Reply #2 on: January 11, 2012, 08:37:29 AM »
It measures 28 3/4" from the base to the top of the air filter.  Overall width is under 18".  Height to center of shaft 6 1/4".  The pulley is 3 1/2" diameter.
Offline LOGDOG
« Reply #3 on: January 11, 2012, 09:48:43 AM »
Thanks Bodger. I have to see if I have the clearance for that. Seems too tall but I'll check.
Offline LOGDOG
« Reply #4 on: January 15, 2012, 11:22:27 AM »
I just measured my clearance. I have 22" and that's within a half inch of the infeed belt on the edger. So at a minimum the motor is 6 and 3/4 " too tall. Thanks anyway.
Offline dukndog
  • A Traveling Man
« Reply #5 on: January 15, 2012, 01:52:16 PM »
If I'm not mistaken, the cannister air filter on his engine is "remote" meaning it can be moved to a desirable area. It just needs a hose connection to it.
DnD
WM LT-15G25 w/PwrFeed, Mahindra 3510, Husky 385xp, Stihl MS261 and a wife who supports my hobby!!
Offline Bodger
« Reply #6 on: January 15, 2012, 05:14:11 PM »
I will take a look in the morning to see the feasibility of moving the air filter.  Thanks for the input. Thanks dukndog.
Offline Bodger
« Reply #7 on: January 20, 2012, 01:48:42 PM »
If the air filter canister is removed the clearance would be just over 19".
Help with Kohler engine
Started by stumpy on Sawmills and Milling
Last post September 16, 2009, 07:56:46 PM
by backwoods sawyer
Kohler EFI engine 26 hp ECH
Started by MartyParsons on Sawmills and Milling
Last post March 28, 2016, 12:25:08 PM
by scsmith42
A Kohler engine question
Started by Quebecnewf on Sawmills and Milling
Last post February 25, 2018, 07:00:24 PM
by Peter Drouin
Kohler engine won't start
Started by BadgerJim on Sawmills and Milling
Last post November 10, 2017, 10:26:04 PM
by pineywoods
