Arborwear
Author Topic: Deutz Diesel Issue  (Read 29558 times)
Offline OntarioAl
Re: Deutz Diesel Issue
« Reply #20 on: January 16, 2012, 10:55:15 PM »
Corley5
Deutz are great engines I pearsonally have limmited experience with them but I  did a goggle search and this web site may be of some help.
http://www.filestube.com/d/deutz+engine+manuals
I hope this helps
Al
Al Raman
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #21 on: January 17, 2012, 06:12:08 PM »
  I pulled the injectors this afternoon and took them in to have them cleaned and patterned/tested.  They all had some carbon buildup and #3 seemed a bit damp.  I might have them back by the end of week but more likely the 1st part of next week.
  I did check for leaks in the fuel and didn't find any visible so I sprayed them with ether with the engine running.  No change in the way the engine ran  ;D :)  I think I'm good there.  Hopefully just having the injectors serviced fixes the problem.
Offline Doppelganger
« Reply #22 on: January 19, 2012, 12:47:51 AM »
You might want to give a compression test and check the tappet settings if there is nothing seriously wrong with the injector.  Tight tappets will give a miss at higher PRM's.
Check cylinder studs are tighten to the correct preasure.
Offline Corley5
    • Whittaker Farms
« Reply #23 on: January 19, 2012, 09:46:15 AM »
I want to check the compression before I put the injectors back in if I can find an adapter.  I've got a Sun tester and adapter for a range of engines but Deutz isn't one of them.  I should have compared the injectors to my adapter before I sent them out  :-\ ::)  There's a chance it'll work but I don't want to wait for the injectors to come back and then find out it won't :)  I called Sun but they only list one for Deutz engines with glow plugs and their diesel expert just retired so they couldn't tell me if mine will work ::) :)  The Deutz adapter they show threads into the glow plug hole and my engine doesn't have glow plugs.
Offline kiko
« Reply #24 on: January 19, 2012, 01:51:47 PM »
If you can come up with an old injector you can take it apart and gut it then weld or braze a fitting on that fits your compression guage. If you can't find an injector to make a compression adaptor you can reinstall the injectors. If the smoke remains you can break the injector lines off one at a time ( with it running  and secured so the machine does not try to move around) untill you find which one clears the smoke off. At this point you know which cly it is and you will likely find the fire ring to be cracked resulting in the low compression. As you break the injection lines off the fuel should "bounce" up 6 to 8 inches, if the fuel just runs out around the nut you could have fuel pump issues( unlikely though as a fuel pump issue seldom causes the white blue smoke you speak of). I have seen this issue many times on a duetz. Because it is air cooled it is has a fire ring rather than a head gasket. Is this engine a FL912? As much as you said you have run it with it smoking a piston/ring problem would likely have  already developed into a piston slap. Also, a broken fire ring will sometimes sound like an exhaust leak.
Offline Bandmill Bandit
« Reply #25 on: January 19, 2012, 02:54:59 PM »
does sound like a possible pump issue but injector nozzels can do the same thing as you are describing and in some of the older Deutz engines slobering injectors was not all that uncommon.
I would pop the injectors lines first and check fuel delivery pressure (if in spec) then pop the injectors get them reconditioned.
If pressure is off well then it recon for pump and injectors.
Kiko goes into more detail and deeper and he is on the money if you need to go further but id start with looking for a slobbery injector and go from there.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4.
2007 Woodmizer LT40HDG28 almost Super
2 Logright 36 inch cant hooks and a bunch of stuff I built my self
Offline Corley5
    • Whittaker Farms
« Reply #26 on: January 19, 2012, 04:43:09 PM »
  I must of had glow plugs on mind when I made the post earlier in the day.  It's the injectors I sent out to be tested.  It doesn't have glow plugs  :)  I don't hear anything that sounds like an exhaust leak.  I'm still hoping it's an injector  :)
  It's an F4L912.  The clock shows around 5,300 hours.  Thanks for all the advice  8) 8) 8) 8) 8) 8)
« Reply #27 on: January 19, 2012, 04:51:07 PM »
at 5300 hours I will pretty much bet on injectors. Never owned a deutz that went past 6000 hrs without recon on injectors. I owned 2 of them and my cousin owned 3 of them. Injectors came out for recon between 4500 and 5000 ish hours.
Offline swampbuggy
  • TK B-20,Lucas 50" slabber, JCB930
« Reply #28 on: January 23, 2012, 11:08:49 PM »
Here are a couple of things to look at from my experience.
1. There is a lift pump (fuel pump) on the side of the injector pump that has a pre-screen in the top of it. Take out the small bolt, 8mm wrench I think, and see it it os clogged. Cleans out easy.
2. This fuel injection pump may not have an oil feed from the engine so the governor weights could be sticking. On the rear of the pump is an allen head plug and about 3/4 of the way down is a bleed plug. It is possible that diesel fuel has washed into this cavity and it needs to be flushed. The drain/bleed plug is NOT the one secured with the anti tamper wire. I think its a 10mm and when opened you can see a hole in it. Open the bleeder, take the top plug out, and flush with engine oil until it flows clean and slows down. Close the bleeder and do not add any more oil. Put the cap on and run it for a while to see if the rack in the injection pump frees up.
3. 4 cyl engines usually don't have an aneroid on them because they don't have a turbo. If yours does have a turbo it could be a bad or plugged tube from the turbo to the pump ( it won't sense the need for more fuel and the pump will not go to full throttle) Let us know if its a turbo model
Thats all I can remember on those engines right now. I'll sleep on it...
If your getting the injector tips cleaned and pop tested make sure you bleed the pump to injector line..They will not self bleed very well.
Good luck.
Swamp
If it was easy, everyone would be doing it!
Offline swampbuggy
« Reply #29 on: January 23, 2012, 11:12:14 PM »
The Cummins b series injectors are very similar and if you can find the adapter for one of them it should work.
Offline timh
« Reply #30 on: January 24, 2012, 12:38:45 AM »
start with simple things check the fuel filter
Offline Corley5
    • Whittaker Farms
« Reply #31 on: January 25, 2012, 06:22:34 PM »
My injectors came back today.  According to the shop they were shot.  They've been reconditioned with new tips.  Gonna put them in tomorrow.  Hope it does solve the problem  :)
Online beenthere
« Reply #32 on: January 25, 2012, 06:30:10 PM »
Will keep our fingers crossed. :)
Offline Reddog
  • Forest & Urban woody plant management
« Reply #33 on: January 25, 2012, 06:31:22 PM »
Offline Corley5
    • Whittaker Farms
« Reply #34 on: January 27, 2012, 06:20:04 PM »
  Injectors installed and machine running better than ever but the problem was not the injectors.  Having them reconditioned did make it run better and eliminated the light blue smoke that it's always produced.  It never has used engine oil but smoked just bit.  That problem is solved  8) 8) 8)
  I started putting it back together late yesterday afternoon and ran out of patience so it was time to go home  ;D  Finished it up this morning.  Bled it and it fired up during the process  8) 8)  Sounded good until we revved it up and it did the same DanGed thing  steve_smiley  :'( :( :'( :( :o :)  So now what  ???  As I was standing there thinking about injector pump repair, fire rings etc. Bob, one of the guys that works for me, pulled out the air filter.  Now I checked the air filter right at the beginning of this whole affair after talking to my neighbor who has an 83 year lifetime experience with iron.  First thing he told me was to check the air filter.  I did, pulled it out, tapped it out, it wasn't bad by any means and wasn't that old.  However I didn't pull the 2ndary filter  ::)  smiley_dunce smiley_dunce  Not that it would have made any difference with the engine shut off.  Even today it looked fine but we noticed a difference in the way the engine ran as soon as it was removed and with it removed the engine ran fine at full throttle.  No smoke no miss.  We put the primary back in and left the final out and it still ran fine.  A trip to Carquest for two new filters and it's fixed ::) :)  I still don't understand how a secondary filter can go bad without the primary getting plugged but it happened.  I guess it's a cumulative process  :)  I've had the machine almost two years and have not changed that filter so I have no idea how old it is but it didn't appear unserviceable today.  It's in the trash can at Carquest.  My experience with farm tractors in ultra dusty conditions we changed the primaries when they needed it and the secondaries were changed at the beginning of the season in the spring and before late summer tillage began in August.  I should have changed this one when I got the machine  ::)  A learning experience for sure but it still seems odd that it went bad all at once ???
  So I've got reconditioned injectors, new air filters, it's running great and the light blue smoke is gone.  Having the injectors done wasn't a bad thing  8)
Offline kiko
« Reply #35 on: January 27, 2012, 06:43:28 PM »
Good news for you. I have missed the inner filter as well.
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #36 on: January 28, 2012, 01:42:54 AM »
Good news.   We only have one machine with a secondary, the manual says change secondary every other change of the primary.   I try to follow unless I can't remember when I changed it.   ::)  If this occurs, I change it anyway.  If I was smarter, I'd write the date on the end of the filter.
Scott
[Magicman]
« Reply #37 on: January 28, 2012, 06:53:06 PM »
i use a red and black sharpie and just put and X on the end of both. If they have one black X when you pull the primary to change it then you just change the primary and it goes in with a red X. The secondary gets a second X with the red marker beside the black one. next change you get a double X when you pull the primary so you know you change em both.
has worked good fro me.
DEUTZ diesel engine
Started by Jerry on Sawmills and Milling
Last post September 08, 2010, 12:18:39 AM
by paul case
question
Timberjack with a Deutz?
Started by dgdrls on Forestry and Logging
Last post December 31, 2014, 11:32:21 PM
by Maine logger88
Anyone know the value of Deutz tractors?
Started by brdmkr on General Board
Last post April 22, 2007, 10:42:55 PM
by Handy Andy
deutz motor
Started by treefarmer87 on Forestry and Logging
Last post February 22, 2010, 04:02:33 PM
by mad murdock
