Log Cookie Table top
Started by Mooseherder, February 05, 2012, 10:06:29 PM
Mooseherder
I didn't have a big enough cookie to make a top for the Pavilion project center table today but made one out of a few cookies to see what it would look like.  I was thinking it would look like clover but ended up looking like a flutterby at some angles.
The top cookie covers the 4 inch deck screws in the other pieces.  I'll go with this for now and see if it grows on me.  The cuts with a chainsaw were hard to get even.
Lud
Not bad, not bad.  Multiple layer tables have potential.  Or maybe the middle one could be a lazy  susan! ;D
Looks like a short stumpy tree to me!  Very creative.  That one will bring out a lot of discussion, so you will have to get used to telling your story.  I really like it.
POSTON WIDEHEAD
Mooseherder, now ya got me wanting to make one of these for my yard to set beside mu benches.
Thanks for the pic! Nice work!!!
Mooseherder
You'll be able to make your cookie tolerances a lot closer than mine. :)
sandhills
That's just plain neat!  Now I have to try it.  :)
breederman
I like it :)However  every cookie I have ever made has split and my fear would be that the splits are going to be where you put the deck screws, :( I sure hope it stays together for you.
Together we got this !
Nice spot to park your favorite beverage and a snack.  ;D :)
CHARLIE
Breederman, in the woodturning world, a man in Hawaii discovered that if he took his green rough turned bowls and soaked them in a 6 part water to 1 part dish detergent (cheap stuff from Costco or Sam's) for a day or two and then let them dry some before turning they won't crack. The wood still moves (goes oval) because it is green wood but it won't crack. I had good luck with the process but haven't used it in a few years.  Now I'm thinking......what if you filled a washtub with 6 part water to 1 part dish detergent and put a cookie into it for a couple of days.  Throw some plywood over the lip of the washtub as a cover. I'm thinking that the cookie won't crack. It would be worth expermenting with a cookie and wouldn't cost much to find out.
Charlie
Norm
Let me know what Donna says when you tell her that's what you're gong to do in the bathtub. :D
CHARLIE
Ha! Never thought of using the bathtub but that's a great idea since our shower is separate.  I'm sure she'd understand since I'd only be soaking the wood for a day or two and it wouldn't take her too long to scrub the tub out. Don't ya think?  ::)
Charlie
I think that some ideas are best left as just that....ideas.   ;D
Well for starts, your going about it wrong. If your expecting Donna to do the cleaning up. That will put the kibosh on it right off the bat. :D
breederman
I have a water vat that would work for that, but currently the water is hard. ;D
Mooseherder
It got bleached 3 days ago and is now ready for some stain.
Clam77
Can already see the top one starting to crack already...     :-\
Andy
Stihl 009, 028, 038, 041, MS362
Mac 1-40, 3-25
jamesamd
Looking great ,I like it.Spar varnish,as a finish coat?
Jim
All that is gold does not glitter,not all those that wander are lost.....
LeeB
Now you need some three legged stools with cookies for seats. 4 should just about match up to the table.
Mooseherder
Quote from: Clam77 on February 08, 2012, 08:49:40 PM
That is an area that needs to be sanded.  No cracks yet. ;)
I'm not sure what I'll use for the finish yet.
Chris Burchfield
The potential for a 6 part water to 1 part dish detergent doesn't sound out in left field.  If the cookie has not cracked yet, seems green would be slow to absorb but, the detergent may allow the fibers to move.  Without releasing from one another to cause a crack.  I've got some fresh wind blow down oak I may have to try this on.  In a small plastic kiddie pool sounds like the ticket.  Seems you would not want to go too strong on the detergent as it may inhibit your finishing product you intend to apply.
Woodmizer LT40SH W/Command Control; 51HP Cat, Memphis TN.
CHARLIE
Chris, I used shellac on my bowls and it didn't seem to bother the finishes at all.  I knew other turners that used lacquer or varnish without any problems.
Charlie
lewisclan
Quote from: Chris Burchfield on February 09, 2012, 08:58:10 AM
I know this is an old thread......But did you try this method  and if so how did things turnout ? i currently have a bunch of Ash cookies 4-8" thick   40"-60" dia just cut last week and sacked & bar clamped to steel welding tables and am looking for a cheep stabilizer.
You will not dry those cookies without a crack. Any information to the contrary is just setting you up for eventual disappointment.
Texas Ranger
One through cut from outside to pith will let the thing shrink on its own, then fill in the pie shaped void.
nk14zp
Could the cookies be cut in quarters and then rejoined when dry IE with dowels/biscuits and glue?
Belsaw 36/18 duplex mill.
Belsaw 802 edger.
http://belsawsawmills.freeforums.org/
