Author Topic: overhead electric  (Read 961 times)
Offline Steve_M
overhead electric
« on: February 06, 2012, 11:57:38 AM »
I am moving into a new building an am looking for a better way to handle my overhead electric .  In the old building I used a trolly system riding on a cable directley over the mill to pull and push the power cord.  Looking for ideas and pictures on a pivot system that would keep the power cord out of the way.
Steve
2001 WM Super LT40 Electric and WM Twin Blade Edger, just a part timer custom sawing and cutting salvage logs.
Offline Norm
Re: overhead electric
« Reply #1 on: February 06, 2012, 04:03:11 PM »
I don't have any help for you Steve but am going to be doing the same thing in a year or so. Hope someone can chime in here with suggestions.
Offline beenthere
« Reply #2 on: February 06, 2012, 04:37:51 PM »
Steve
WM uses a pantograph on some of its systems. A form of that might work for you, if you have the room.
Offline Ironwood
    • http://www.branchandburl.com
« Reply #3 on: February 06, 2012, 05:15:48 PM »
Look at your local Pressure washing bay, Just like that pivoting rod, and the "pantagraph" version would have another junction. Also, the light at your dentist is a good example, two pivots. Next time they are drilling, think "sawmill electric" instead of OUCH  ::)
Ironwood
Offline Woodwalker
  • Old, ugly, rude, cude and sociability un-acceptable.
« Reply #4 on: February 06, 2012, 07:40:30 PM »
I rigged a festoon on mine.
Just cause your head's pointed, don't mean you are sharp.
Offline bandmiller2
« Reply #5 on: February 06, 2012, 07:47:03 PM »
Steve,depending how much overhead you have you can just hang a cord with some slack around the middle of travel.Where I have my bandmill set up theirs a high celing with just the cable hanging down. Frank C.
Overhead trolly hoist
Started by WoodButcher on Sawmills and Milling
Last post June 27, 2006, 12:31:02 AM
by UNCLEBUCK
Air drying without overhead cover
Started by grweldon on Drying and Processing
Last post January 27, 2019, 08:33:57 AM
by GeneWengert-WoodDoc
Overhead track system for slabs
Started by Joey Grimes on Sawmills and Milling
Last post May 26, 2018, 06:24:58 AM
by Satamax
Overhead Cable for Hydraulic Hoses
Started by Rougespear on Sawmills and Milling
Last post April 19, 2016, 11:44:49 PM
by Rougespear
