Author Topic: dry kiln for drying bowls  (Read 12532 times)
Offline Den Socling
  • just wondering
Re: dry kiln for drying bowls
« Reply #20 on: February 13, 2004, 03:06:08 PM »
Discontinuous vac kilns used to be built by an Italian company and VacuTherm tried to sell them. With thick stock, they are probably 5 or 10 times faster than conventional kilns. But they are slow compared to continuously heated vac kilns. I've worked on them and the wiring, relays and timers needed for automation in the 'old days' are a nightmare. The patent has expired and one might be built by an enthusiast.
The basics are as follows: You heat the wood by blowing warm air over it. Lumber gets stickers. Blocks would just take time. When you heat the wood, you increase a property of the water in the wood. This property is called vapor pressure. If you heated until the vapor pressure was (for discussion) 50 and then you pulled the chamber pressure down to 50, all of the water would instantly evaporate. This doesn't happen in reality because, when water evaporates, it takes heat with it. The remaining water cools and it's vapor pressure is lower - say it's 40. Then too, the evaporating water fills space and eliminates some of the vacuum so the chamber pressure might become 60. Instead of all of the water evaporating, only some can and then the 50/50 doesn't exist anymore.
With discontinuous vac drying, you heat with air and then pull vac. Repeatedly. You could do it by hand. You could do some automation. You could make it completely automated. The cost, for the most part, depends on how much you will scrounge for parts and how much you want automated.
Offline shopteacher
  • Hiking Sedona, AZ.
« Reply #21 on: February 13, 2004, 03:15:18 PM »
Ya got us all setting on the edge of our seat Den. Please continue.
Offline Greg_Kaldor
« Reply #22 on: February 13, 2004, 03:26:19 PM »
I have a good friend where I work who is an instrument man and I am sure will give me tech. advice.  Most of this is all Greek to me.  But I will try very hard this is very important to me.  I will be watching for more.  Thankyou.
Greg
Offline Den Socling
  • just wondering
« Reply #23 on: February 13, 2004, 03:27:52 PM »
It's been a long day with a DanG 50 HP freq drive blowing up in my face, it's dinner time and I'm ready for a beer.
But you need a chamber. I'm always wondering about propane tanks. They come in all sizes. They are stronger than needed. If you could just cut the end off and turn it into a door.
Offline etat
  • Member*
« Reply #24 on: February 13, 2004, 05:18:04 PM »
careful cutting into a propane tank.  first remove the valve, then either fill full of water and cut, or hook up a hose to the exhaust of an engine and cut while co2 is pumping into the cylinder.  Otherwise you might find you head going into orbit, along with the tank
Offline Bill_B
  • Rio Wisconsin
« Reply #25 on: February 14, 2004, 03:48:47 AM »
The chamber that is used needs to be totaly sealed?
What kind of vacumn unit would be needed?
What temp should  be reached?
Rough figures are only needed right now.
This sounds like a interesting project.
Bill B
Offline Den Socling
  • just wondering
« Reply #26 on: February 14, 2004, 05:32:27 AM »
If I planned on using a propane tank, I'd take it to professionals to be cut. There are shops that repair gas tanks. I'd use one.
Propane tanks aren't the only possibility. Any cylinder designed to hold pressure might work. A total vacuum puts only 14 psi on the tank (from the outside). This doesn't sound like much but it can flatten a 'box' design real quick. That's why I suggest a cylinder. Something from an air compressor?
After you cut off the end, you would need to weld pipe flanges on both pieces. Door movement (hinge, boom, truck or whatever) would depend on size. The chamber needs to be totally sealed but you would not need all the bolts that a pipe flange might have. As soon as you start pulling vacuum, atmospheric pressure will push it in tight.
During the heating cycle, I would pump warm water through an automobile radiator inside the chamber. Nipples for water connection in and out are easy. I might try low temperature, maybe 110F for wet wood. Put a fan behind the radiator to circulate. If there is a chance of cracking, elevate RH by spraying water on the radiator.
Now the necessary process control. You would need a temperature sensor (an RTD) in a sample of wood. You would run the heating cycle only until the wood was 110F.
When the wood is up to temperature, I'd start a little, two-stage, liquid ring vacuum pump. To keep things cheap and simple, I would use a partial recovery system and dump some water to keep it cool and clean. After starting the pump, I'd watch the wood temperature. The wood is going to start to cool. When the temperature stops dropping, there is no use in running the vac any longer. Open a valve, let air in and heat it again.
As the the MC of the wood comes down, I'd raise the temperature of the water in the radiator. 120, 140 and maybe 160 if you wanted really dry.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #27 on: February 14, 2004, 09:24:10 AM »
  Oh man, this is too simple.  ;) ;)
 Den, on our soaking wet wood, using the system you just described, how long would it take to get the wood to 12%?? I know exact days are tough, just ballpark. 4 weeks, 6 weeks?? I would use a 500 gallon tank.  Maybe there is a formula of MC divided by volume or something????????
 Once you pull the vacuum, can you shut the pump off and hold the vacuum with a valve of some sort, or is that not neccessary???   Great info. I got it built already, in my mind. ;D ;D
Offline Den Socling
  • just wondering
« Reply #28 on: February 14, 2004, 10:14:00 AM »
Drying time would depend a lot on the porosity of the species that you are drying. If you didn't waste any time on cycles, I would expect 12% in about a week or two. Even a log that is soaked is going to give up a majority of that water quickly and easily. Naturally, a very dense wood is going to take longer.
The size of the vac pump would also influence drying time. A gallon of water makes about 227 cubic feet of vapor. If you wanted to remove a gallon per hour and your heating cycle took one half hour, then you would need a pump that could move about 8 CFM (227 divided by 30 minutes).
If everything was sized right, the volume of wood would not affect drying time. Since we are talking about a car radiator as a heat exchanger, volume could have some influence.
Now you can begin to see where automation is extremely useful. If you ran it only a couple hours a day while you could watch it, it could take 4 to 6 weeks. If a controller was watching the wood temperature and controlled the cycling, the kiln could run 24/7. The Italians made the mistake of trying to use timers.
Once you get to the end of the vac cycle, I'd turn the pump off. If the system is automated, you need a solenoid valve to turn the water off. A check valve will prevent the vacuum in the chamber from pulling water out of the pump. Then open a valve to bleed air into the chamber.
Offline DanG
« Reply #29 on: February 14, 2004, 10:58:34 AM »
Well I'll be DanGed!  I had thought of using a propane tank for a vac kiln chamber, but I figgered the idea was too harebrained to even mention. ??? I, too, already have this thing planned in my head. I have a heater out of an old bus that would make a perfect heat exchanger for such a small space. :)
Den, would one of your controllers adapt to this application? What would a ballpark price be on such a controller? Do you think it would be practical to weld 2 tanks end to end, to get more length for lumber?
This is a great  thread! 8) 8) 8) :)
Offline Den Socling
  • just wondering
« Reply #30 on: February 14, 2004, 11:20:57 AM »
Our controllers aren't designed to run something like this but I could design one. Jason of WI might be able to come up with something cheaper.
If you can weld, there would be nothing wrong with putting two chambers end to end. The old VacuTherms were more than 30 feet long. The problem is air flow. The Italians had about a dozen fans along the side. And they made the chamber with a double wall so that they could heat the air with hot water circulated through the wall.
« Reply #31 on: February 14, 2004, 11:38:21 AM »
  Too many brains thinkin alike, here.  :o ;)  I already got the 2 tank system figgered AND cutting out both ends and loading from each end, with roller tables and racks :) :)
 I just gotta study up on vac pumps. Only kind I'm familiar with, are Dairy milker pumps, Vane types???
 Did I ever post the pic of the 500 gallon STILL we built in Arkyland??? IT had a compressor radiator in it to heat the mash to distill "spirits".  ;D ;D ;D ;D  Had a water heater outside and plumbed into the tank to the radiator ;D ;D ;D ;D
 This is gonna be SLICK. Thanks again, Den. ;) ;D ;D
Offline Den Socling
  • just wondering
« Reply #32 on: February 14, 2004, 12:22:50 PM »
Do a Google for liquid ring vacuum pumps. SIHI and Nash are good brands. Used pumps are available. Don't buy bigger than you need as HP goes up quickly. You want 2-stage. Anything under 20 CFM is considered very small. A 20 CFM pump will use about 2 HP. The pump on my 1000 bf kiln cost $1324 new and bare.
Pressure control is not an issue here since drying is not going to be continuous. However, you want the pump to pull low enough to boil the water out at low temperature. If you can pull to 55 Torr (55 mm Hg), the wood temperature will drop rapidly to under 100F.
I'm glad you appreciate this. Vacuum drying is suppose to make a living for me!  :D Actually, I just can't figure out how to make a really small kiln cheap. Welders cost a lot of money. Sure helps if you can do it yourself. Carbon steel will rust if you dry Red Oak. I have to use stainless. (Use coal tar epoxy in your recycled tanks.) I can't scrounge for used parts. They all have to be available off a shelf. I have to have multiple sensors and safeties and tight control for guaranteed results, etc., etc.
Offline DanG
« Reply #33 on: February 14, 2004, 12:24:20 PM »
I was thinking of mounting the radiator and fan at one end and running a duct with multiple outlets along one side, then channeling the return air along the other side to the input side of the rad. Sound feasible?
Another possibility for a chamber might be an old pressure treating vat. They might be available if one were to look in the right places. They already have the track and trolley system for loading lumber, and the seals to run the pressure up and down. :P
Offline Den Socling
  • just wondering
« Reply #34 on: February 14, 2004, 12:30:47 PM »
The duct work sounds interesting. Last summer, I considered blowing over the top and into the end of a baffled kiln charge. The heat exchanger and fan would be above the load. Periodically, you could change fan direction to give more even drying.
Another source of a chamber is tire vulcanizing chambers. They look just like small vac kilns. More likely, cylindrical vac kilns look just like big tire vulcanizing tanks.
« Reply #35 on: February 14, 2004, 12:56:46 PM »
  Ya know, I believe ALL the info like this is really appreciated on this Forum. Sometimes the info is taken and no thanks is offered. That makes the person with the smarts feel UN-appreciated. I hope folks here get a little more "Thankful" and express it more. I KNOW it helps.  Thanks AGAIN, Den
 Too bad we don't live closer. Stainless is our "other" business. ;D ;D
Offline Bill_B
  • Rio Wisconsin
« Reply #36 on: February 14, 2004, 02:45:42 PM »
Thanks Den. You have presented a lot of good ideas.
I was on a woodturning site and they were talking about boiling wood bowls for 1/2 hour to help dry and to prevent cracking.
Your idea is much better.
Bill B
Offline Greg_Kaldor
« Reply #37 on: February 14, 2004, 03:28:41 PM »
HI Den,
You are the one with the smarts.  All of us are very grateful to
you for you valuable input.
Thanks again,
Greg
Offline shopteacher
« Reply #38 on: February 14, 2004, 03:36:32 PM »
Den have you ever thought about  putting together a kit for the do-it-yourselfer?  Something like  a set of written plans, heat exchanger, selnoid valve and a simple controller, etc.  Let the builder come up with a suitable chamber and pump.  Rather than add expense with redundant controls as part of the instruction pack tell what could be done with  multiple sensors and safeties and tight control for guaranteed results.
  I realize it not prudent from a selling point to give out the information you've worked and researched to gain. I do assure you I for one and probably everyone else reading these threads are very appreciative to have you and your expertise on this forum.
Online Ianab
« Reply #39 on: February 14, 2004, 03:37:07 PM »
What about plastic pipe for the chamber?
It's gonna limit your size of course, but for bowls and carving blocks you should be able to get a good amount into a long pipe.
I found this web site with some info on a DIY vacumn dryer, no doubt it could be improved with some of Den's ideas?
http://carverscompanion.com/Ezine/Vol2Issue4/LynnDiel/LynnDiel.html
ian
Kiln drying after air drying
Started by SDM on Drying and Processing
Last post November 13, 2007, 09:22:39 PM
by Tom
Air drying vs Kiln drying
Started by Chuck_W on Drying and Processing
Last post December 17, 2004, 05:08:16 AM
by Patty
Kiln Drying
Started by sawwood on Drying and Processing
Last post May 01, 2014, 06:41:55 PM
by GeneWengert-WoodDoc
Kiln drying by RH
Started by foresterstan on Drying and Processing
Last post June 10, 2015, 02:41:41 AM
by foresterstan
