Arborwear
Author Topic: older clarke skidder  (Read 2298 times)
Offline graves logging
« on: February 07, 2012, 03:52:41 PM »
not sure what year it is.its a 664 with a 353 and a 2 speed auto trans.under the floor there is a spot to put some type of fluid not sure if its hyd or trans fluid .the lines run to the pump on the end of the trans .can some one tell me what to put in it please.i would say its about a 1978..no manuel
Offline rick f
  • Location: Blueberry land- DownEast Maine ( Columbia Falls)
Re: older clarke skidder
« Reply #1 on: February 07, 2012, 07:39:15 PM »
There should be 2 covers when you take the floor board out. The one in the middle of the machine is automatic trans. fluid, outside is hydro. fluid.
If you have the serial number PM Oldseabee on here and he can help with the manuels.
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
5040 kubota farm tractor
« Reply #2 on: February 07, 2012, 09:14:58 PM »
thanks rick f.what year is that skidder in your pic mine looks about the same .batterys outside the cab
Offline rick f
« Reply #3 on: February 08, 2012, 04:37:21 AM »
664 clarke  1967-68 3-53 auto trans. gearmatic 19  16.9-30 rubber
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
Offline oldseabee
« Reply #4 on: February 08, 2012, 08:33:03 AM »
The hydraulic tank is on the left side under the floor. Above 0 Deg. F use 10W engine oil or hydraulic oil. Real cold areas down to -30 Deg. F use Dexron (not dexronII). If you have another fill place that looks like a small can on top of a tube, take the lid off and there should be a strainer. this is where you add transmission oil. 30Deg. and above use 30W engine oil, -10 Deg. and above use 10W engine oil or C-2 hydraulic oil, -30 Deg. F and above use Dexron (not Dexron II).
Offline rockwall
« Reply #5 on: February 09, 2012, 07:06:21 PM »
There is a great site with free manuals  http://www.alliedsystems.com/pubs/pubs.htm go there and hit Ranger on the left, there should be a drop down menu under ranger,click on what you want, then find your skidder and download parts book, owner manuals. It's great!
Started by graves logging on Forestry and Logging
Last post May 11, 2011, 11:37:04 AM
by mad murdock
Older Skidder
Started by Skip on Wanted
Last post November 30, 2007, 10:45:36 PM
by sawguy21
Tractor forwarding trailer vs. older skidder
Started by mf40diesel on Forestry and Logging
Last post August 12, 2014, 06:48:23 PM
by BEEMERS
Where to Buy a -- New/ Rebuilt Grapple Hyd. Orbit Motor for Older Skidder
Started by H60 Hawk Pilot on Forestry and Logging
Last post September 04, 2014, 10:59:13 AM
by H60 Hawk Pilot
