Carlton Stump Grinder sp4012
Started by westyswoods, February 10, 2012, 06:49:59 AM
westyswoods
Does anyone know what the spec numbers on the Kohler Engine are for the new Carlton SP4012 Stump Grinders are? Sounds like an easy question not so.
I called Carlton and the only info they will divulge is their inventory number. They want to sell and engine.
Need to replace one off an old Carlton and the engine has already had a short block put on it. All numbers are gone off ID tag. This engine has to be the exact dimensions with shaft size, height and all others to make it work.
If worst comes to worst I can measure all that is needed and match with new specs of Kohler 27 HP engines.
Just throwing it out there may save some time.
Stay Safe and Healthy
Westy
Stay Safe and Be Healthy
Westy
