Author Topic: Lewis winch?  (Read 1088 times)
Offline gspren
Lewis winch?
« on: March 05, 2012, 05:12:30 PM »
  I have seen these mentioned on FF and looked at them on-line but never in person. I only cut firewood for my OWB on my own land and sometimes could use a winch to get a tree up or down off of a steep hillside to work it better but don't really need a big logging winch. These look like they would be handy around the farm for other uses also. I have an old 041 Stihl Farm Boss saw that I don't need to cut with so it would be the powerhead. Anyone have experience with the Lewis winch? Pros and cons? Will they pull out a stuck truck?
Thanks, gspren.
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
Re: Lewis winch?
« Reply #1 on: March 05, 2012, 06:16:46 PM »
I've had no experience with one, go to youtube and watch one at work, looks like it would be a pretty handy tool.
Offline Jasperfield
Re: Lewis winch?
« Reply #2 on: March 05, 2012, 07:10:24 PM »
Take a look at the "Portable Winch", too. They use a rope (rated at whatever capacity you want) of any length. Out of the box and using a single line with no pulleys, they'll pull 2,500 lbs. With pulleys they'll go on up over 10,000 lbs.
Logrite sells them.
Jasperfield
Offline jocco
Re: Lewis winch?
« Reply #3 on: March 06, 2012, 06:29:26 PM »
They are very good (cant tell you the lbs of power) The rope ones are used for differnt purposes. They use a chainsaw as it is lighter to move around. The only bad feature is the cost $7-1200, used ones are scarce. As an aside there was several makes years ago Mcculloch being one.
You may check out but you will never leave
Lewis Winch????
Started by timberbeast on Forestry and Logging
Last post February 25, 2003, 06:17:35 PM
by burlman
Lewis Winch
Started by RevCant on Sawmills and Milling
Last post December 11, 2008, 06:32:18 PM
by JV
Lewis Winch
Started by arbo71 on Wanted
Last post March 08, 2010, 10:36:04 AM
by arbo71
Lewis chain saw winch
Started by joe_indi on Chainsaws
Last post December 22, 2009, 09:38:51 PM
by firefighter
