Author Topic: virginia pine  (Read 6058 times)
Offline SwampDonkey
  • Large Tooth
Re: virginia pine
« Reply #40 on: November 18, 2012, 04:32:57 AM »
They stamp jack pine lumber under the SFP grade up here. I was wondering if they stamp VP under the same grade down there. Both pine look about the same and plantation jack pine is pretty knarly stuff. Wild jack pine grown thick is a world of difference in quality. Straight as guns and limb free for several feet. Irvings buy jack pine logs at their stud mill in Sussex. It's an on and off again proposition with those guys though, no matter what they are buying. 8 foot at around $60/mt or $66/ton, min 4-1/2" top, 13 max on the but. When you drive down around there, it's miles and miles of jack pine.
Move'n on.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: virginia pine
« Reply #41 on: November 18, 2012, 07:18:46 AM »
I am sure that some of it gets mixed in the the regular 4 commercial species of southern yellow pine.
Okra,
Longleaf pine and loblolly have a different branching habit.  The end of the branches where that round pom pom is located are very stout, at least twice the size of the end of the branches of loblolly.  Like the difference between a 1" - 1.5" dowel and a pencil.  Very distinctive, plus the long drooping needles and the big cones.  You can tell them apart going 60 MPH down the road.
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Avast! Here appeareth some sweetgummery about....
Re: virginia pine
« Reply #42 on: November 18, 2012, 07:57:59 AM »
I'm sure I will be able to tell them apart going 60 mph down the road once I am fully sure that what I am seeing is longleaf. When I am, then I will know. First, I have to positively identify one or two in my area. I know where two are that I suspect are LL. I need to stop and make a positive ID.
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Turbosawmill 8" cut GX390 Warrior Sawmill, 13hp Honda
MS290 Stihl
Genesis Hardwood Lumber
Offline Okrafarmer
Re: virginia pine
« Reply #43 on: November 18, 2012, 07:58:58 AM »
SD, 4 inches on the top? You sure are spoiled. Our pine mills don't want anything less than 8" on the top.
MS290 Stihl
Offline SwampDonkey
  • Large Tooth
Re: virginia pine
« Reply #44 on: November 18, 2012, 10:40:02 AM »
I've seen them take a 2-1/2" top in fir and spruce during second thinnings.
Move'n on.
Offline Road Runner
Re: virginia pine
« Reply #45 on: November 18, 2012, 11:39:28 AM »
Okra,  If you have any longleaf in your area my guess is it was planted as you are a good bit north of it's natural range which as a general rule runs on the north edge of the sandhills in SC.  We have some longleaf in Abbeville Co. but it was all planted, mostly on USFS land in the 50s with very slow growth in the red clay.  Longleaf likes sandy soil.
Oconee, Pickens, and Greenville Counties have both shortleaf and virginia pine, but my guess is that most sawlogs are shortleaf due to the size. limbs, and knots associated with virginia pine.  Virginia pine is used for interior paneling (knotty pine), but not so much for framing.
WM LT40G25, Kubota MX5100, Husqvarna 365 & R460
Offline Okrafarmer
Re: virginia pine
« Reply #46 on: November 18, 2012, 02:33:38 PM »
The two longleafs I suspect, are in someone's yard, so probably planted.
The Virginia pine obtain some decent size here, up to at least 16 inches dbh or more. We have tons of them around, it is one of the default trees for the whole area. Along with Sweetgum, Tulip Poplar, Water, Southern Red, and White Oak, Loblolly pine, and ERC.
MS290 Stihl
Virginia Pine
Started by Osagedon on Sawmills and Milling
Last post March 14, 2008, 10:48:11 PM
by DR_Buck
Virginia Pine?
Started by JimVA on Timber Framing/Log construction
Last post April 18, 2004, 10:58:28 AM
by SwampDonkey
What to do with Virginia Pine ?
Started by Markus on Forestry and Logging
Last post February 27, 2006, 05:51:42 AM
by BBK
Virginia Pine....Any Good?
Started by DR_Buck on Sawmills and Milling
Last post May 07, 2004, 08:53:15 PM
by dail_h
