Author Topic: Sawmill Sheds  (Read 82854 times)
Offline Bogue Chitto
Sawmill Sheds
« on: March 07, 2012, 03:16:15 PM »
I am thinking of building a sawmill shed for my mill.  What do you have? Pictures would be nice.  As of now I have a metal or portable shed that is on wheels, but I want a permanent one.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Sawmill Sheds
« Reply #1 on: March 07, 2012, 07:16:32 PM »
   maybe make one like this :) :)
  24x60   ;D
A&P saw Mill LLC.
License NH softwood grader.
Offline hackberry jake
Re: Sawmill Sheds
« Reply #2 on: March 07, 2012, 07:22:00 PM »
Or this? 18x32
Offline MHineman
Re: Sawmill Sheds
« Reply #3 on: March 07, 2012, 10:06:13 PM »
  Peter Drouin, how long is the span on that opening?  What did you use for the header?
  You can saw something reallllly long on that rig.
1999 WM LT40, 40 hp 4WD tractor, homemade forks, grapple, Walenstein FX90 skidding winch, Stihl 460 039 saws,  homebuilt kiln, ......
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
Re: Sawmill Sheds
« Reply #4 on: March 08, 2012, 12:28:54 AM »
  Iam set up stationary and  went with cantliever roof need to have open cutting deck for loading big logs and odd shape stuff that dosent roll. I saw at night alot so the lights shinning down and forward works real well. I have a cover for cutting deck that I take on and off with forks, when not in use.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
    • A&P Saw mill LLC
Re: Sawmill Sheds
« Reply #5 on: March 08, 2012, 06:17:16 AM »
Hi MHlinman  43' door, and the head is a steel I beam 45' long.  works good for me . and this year im going to add a 16' bay next to the JD
A&P saw Mill LLC.
Re: Sawmill Sheds
« Reply #6 on: March 08, 2012, 08:58:19 AM »
Thanks everyone.  I like your setups.  8)
Offline opticsguy
Re: Sawmill Sheds
« Reply #7 on: March 08, 2012, 09:15:06 AM »
Looks like Peters shed has a steel I beam for the open span.
An alternative is building a box beam built out of lumber and plywood.  Might require an engineers stamp if you are getting a building permit and a good idea even if no permit.  I used a box beam spanning 24 feet in my garage to avoid any posts and to support the second floor, an easy build and high strength.
Obviously you cannot cut a beam longer than your mill which is really want you want.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline tcsmpsi
  • Time is relevant, only because it exists.
    • The Custom Shop/MPSI
Re: Sawmill Sheds
« Reply #8 on: March 08, 2012, 07:21:11 PM »
Here's one.
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
Offline jcbrotz
    • Brotzmans Woodworks
Re: Sawmill Sheds
« Reply #9 on: March 09, 2012, 05:14:47 AM »
Yes you can. I have done it to many times longest being a 32 footer on my mill WM LT-40. All for customers but one is gunna be for me when I start my "shed" this year but that is another topic.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Sawmill Sheds
« Reply #10 on: March 09, 2012, 09:04:01 AM »
Correct, there are many innovative ways to saw longer than your sawmill's specs.  The forum's search button above should uncover several methods.
Offline learydeere
Re: Sawmill Sheds
« Reply #11 on: March 09, 2012, 11:39:43 AM »
Offline eastberkshirecustoms
Re: Sawmill Sheds
« Reply #12 on: March 10, 2012, 08:26:36 PM »
learydeere, looks like someone built with the cold weather in mind. ;) We used to have something similar to that on the circle mill shed, but it had a flip up door to roll the logs in.
redbeard,  do you have long hydraulic cylinders bracing up your shed? If so, that's too cool!
Offline learydeere
Re: Sawmill Sheds
« Reply #13 on: March 11, 2012, 08:05:48 AM »
Haha yea you're right there's a hundred acre field behind he and 6 months out of the year the wind is brutal so i closed the north side and left the south side open
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Sawmill Sheds
« Reply #14 on: March 11, 2012, 08:39:08 AM »
If you are like me, you will need a place to store lumber, too, so take that into consideration.  I have shed roofs on each side of my workshop that extend 26 feet on either side so that I can build racks and store air dried lumber.  On the right side, a pesky scarlet oak got in the way  :).
On the left side, it was a pesky white oak.
Offline Norm
Re: Sawmill Sheds
« Reply #15 on: March 11, 2012, 09:02:57 AM »
Ummm Danny you missed one!  :D
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Sawmill Sheds
« Reply #16 on: March 11, 2012, 10:31:59 AM »
I have to admit......I like the trees through the roof! I'll bet you've got a ton of comments on your roof.
Offline Kansas
  • In the mountains of Kansas
Re: Sawmill Sheds
« Reply #17 on: March 11, 2012, 10:40:57 AM »
The carpenters on here could answer this one better than me. But why couldn't you simply laminate a beam. We have done it and I think they stay straighter. Its a pain to cut a beam longer than the saw will allow. It can be done; we have. Its pretty slow going. I would think some 2x12 or 14 laminated with ring shanks and some bolts would work just fine.
Offline learydeere
Re: Sawmill Sheds
« Reply #18 on: March 11, 2012, 10:52:26 AM »
Thats exactly what i did. I wanted a 26' door and a beam was around $1500 so i used 2x6's and staggered all the joints and put plywood between and added 150 locking screws and 10 tubes of liquid nails and ended up with a 8x12x26 for under $200
Offline redbeard
Re: Sawmill Sheds
« Reply #19 on: March 11, 2012, 01:03:59 PM »
There are some beam span ideas on Timber framing page, tried to find one members post on this subject it was a bridge he built. Or you can google wooden bridge beams. His post was really interesting maybe someone can link it here.
Sawmill Sheds
Started by Tee on Sawmills and Milling
Last post April 11, 2013, 08:35:42 PM
by Tee
sawmill sheds
Started by lyle niemi on Sawmills and Milling
Last post June 18, 2012, 07:58:30 AM
by 36 coupe
Show Me Your Sawmill "Sheds"
Started by pwrwagontom on Sawmills and Milling
Last post January 25, 2017, 11:19:23 PM
by Briankinley2004
How many sheds does a boy need?
Started by Qweaver on General Board
Last post June 16, 2012, 11:46:30 AM
by OneWithWood
