Author Topic: Loading deck  (Read 5957 times)
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Loading deck
« Reply #20 on: April 05, 2012, 07:32:12 AM »
Frank,
You could also hollow out a section of the main beams, and the swing arms could hinge up and over 180 degrees to fit into the recess.
Offline bandmiller2
Re: Loading deck
« Reply #21 on: April 05, 2012, 07:54:56 AM »
Alas edging boards is a pain in the butt.What I do is stack the "edgers" on the dead deck usally in two piles wide and narrow.When I get the cant I'am milling down to 4" I stack the seperate piles on edge in front of it.The cant gives needed support and you can push the trimmins on top of the cant to save trips to the slab pile.When cutting heavy timbers I load one log at a time on the deck cut and roll back on the deck to be removed with forks. Frank C.
Offline WDH
Re: Loading deck
« Reply #22 on: April 05, 2012, 08:03:56 AM »
It is not too hard to slide a big beam back onto the log deck and pick it up with the tractor forks like you suggest.  The thing that I learned is to edge the boards that need it after each log and don't build up a big pile because it will kill you.
Offline Jemclimber
Re: Loading deck
« Reply #23 on: April 05, 2012, 08:49:16 AM »
Thanks for the pics CC. Looks very handy.
lt15
Offline caveman
  • In the land of the blind the one eyed man is king
Re: Loading deck
« Reply #24 on: April 21, 2018, 05:18:37 PM »
John and I worked on our log deck some today.  I started building it earlier in the week and still need to bolt it to the poles and strap it down.  We used rail road iron for the counter weights.  We may need to remove a bit of it but the idea is for the arms to swing up when not loaded with a log.  I hope that this deck improves our efficiency - saving me from getting on the tractor each time we need to load another log.
Caveman
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Loading deck
« Reply #25 on: April 21, 2018, 07:51:51 PM »
I hope those posts are in the ground a few feet ..
What size pipe?
lots of dull bands and chains
Offline caveman
Re: Loading deck
« Reply #26 on: April 21, 2018, 08:09:53 PM »
The posts are in the ground more than they are out.  The pipe is 2".  The span is 42" to the mill.  If they bend, I have a lot of 4" but I think they will work out okay. 2" of fall between the deck and the mill.
Caveman
Offline Dan_Shade
Re: Loading deck
« Reply #27 on: April 21, 2018, 09:18:43 PM »
That should speed up production
Making a Loading Deck and Edging Slab table
Started by AnthonyW on Sawmills and Milling
Last post June 01, 2015, 08:08:44 AM
by AnthonyW
Cautionary tale, Sawmill brow and deck loading SAFETY
Started by BoyZinthewoods on Sawmills and Milling
Last post April 15, 2016, 02:00:13 AM
by isaaccarlson
Time to re deck the deck
Started by rimshot on Sawmills and Milling
Last post October 01, 2013, 06:43:41 PM
by rimshot
Log Deck
Started by rooster 58 on Wanted
Last post October 31, 2014, 10:17:49 AM
by rooster 58
