Author Topic: PH 360 depth of cut  (Read 1019 times)
Offline Doug Wis
PH 360 depth of cut
« on: April 18, 2012, 11:53:14 PM »
   Planed some pine 2x today. Can't get it to take enough off the bottom side .I believe that the bottom depth of cut is controled by the  infeed table. had it all the way down and adjusted the tilt both up and down with very little change. Could it be that i need more preasure on the feed rolls? have never adjusted them from the factory settings. We haven't planed all that much, but don't remember having this problem at first. Thanks for your thoughts.
A man who says he can do everything at 65 that he did at 25 sure wasn't doing much at 25.
Offline DUGG
  • Member*
Re: PH 360 depth of cut
« Reply #1 on: April 20, 2012, 12:35:07 PM »
The 1st thing to check for is dull knives. No need to adjust the feed rolls.
Offline Doug Wis
« Reply #2 on: April 21, 2012, 08:23:12 PM »
   Thats probably the problem. They need grinding and I was trying to squeeze one more job out of them. Thanks
Cut Throat Depth
Started by JimFX on Sawmills and Milling
Last post April 12, 2013, 11:55:07 PM
by Banjo picker
Depth gauge removal?
Started by Satamax on Chainsaws
Last post September 01, 2011, 09:19:31 AM
by Al_Smith
Stump removal depth?
Started by jmsiowa on Urban and Community Forestry
Last post October 17, 2008, 07:45:56 AM
by rebocardo
Depth Gauge Height
Started by double clutchin weasel on Chainsaws
Last post January 09, 2015, 11:59:41 AM
by HolmenTree
