Baltic Abrasives Technologies
Author Topic: LT-40 clamp cylinder seal repair  (Read 1362 times)
Online terrifictimbersllc
    • Terrific Timbers LLC
« on: April 19, 2012, 08:57:38 AM »
Anyone replace the hydraulic seals on the up/down clamp cylinder and is there anything hard about it?
Yesterday my clamp on my LT-40 super started acting up,  occasionally wouldn't go down. Run it up a bit then down would get it going but not always.  Tap on the top of it while pushing the lever down would get it going.  Flow/pressure was there.  Nothing was leaking and oil level was good.  Nothing wrong with the clamp cylinder that I could see looks like new.  Able to finish the job.   In the end I was pushing the lever down, and it blew apart  the hose going to the bottom of the cylinder (separated at the crimp on the end).  WM said it is likely the seal needs replacing.  Seal kit and new hose coming this morning by Fedex overnight.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Re: LT-40 clamp cylinder seal repair
« Reply #1 on: April 19, 2012, 09:20:38 PM »
It's fixed.  Didn't believe it would happen. I will saw tomorrow.   Took me about 6 hours to get the cylinder apart.
Grateful to WM tech service reps Doug and Ron who actually seemed to have taken one of these apart before themselves.
We'll see if the repair holds up tomorrow.  The end seal (at bottom of the cylinder) was broken, which seems to explain everything.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #2 on: April 19, 2012, 09:32:11 PM »
That's GREAT news T.  :D I know you feel better....I would.
Ain't dem ORANGE people GREAT!
They'll walk you right through the process you have to fix.
Now let's see some sawdust!  8)
Offline customsawyer
    • The Custom Sawyer
« Reply #3 on: April 19, 2012, 09:46:47 PM »
I have had a few of the cylinders to go out on me but then again I have 7000 hours on a mill that has been doing more than it should for a while. They will get your jaws tight, but once you have done a few it gets easier.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Online beenthere
« Reply #4 on: April 19, 2012, 10:22:07 PM »
terriffic....
That oughta cheer you up!!  like the smiley face... :) :) :) :) :) :)
Offline Bogue Chitto
« Reply #5 on: April 20, 2012, 07:02:03 PM »
 I noticed the other day that there is movement or play in my clamp.  When it is free I can move it around about one inch to each side.  Is this normal?
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #6 on: April 21, 2012, 02:41:04 AM »
If the clamp is simply rotating around the horizontal guide shaft then it's not a problem.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
« Reply #7 on: April 21, 2012, 06:59:06 AM »
Cut all day yesterday.  Wow the clamp goes down fast now!   At the beginning I was worried, he top end holder separated (moved up) about 1/16" from the cylinder body, thought it might blow out.  I had to re-use the retaining ring (wire) because I misplaced the new one in the repair ordeal.  It was probably a half inch shorter by the time I got it back in.  Plus I had bugged up the top end including the wire groove a bit.  But I think the 1/16 is just a bit of new play which doesn't matter.  Tossed around 4 giant logs so it got a workout.  If you don't know what I'm talking about consider yourself lucky.  I don't usually feel like taking pictures when it seems the world is coming to an end.  >:( >:( >:(
Also had to pay attention to routing of the hose lines which were readjusted by the time I got it back together.  If I hadn't watched this I would have torn off the new line to the bottom of the clamp.
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #8 on: November 29, 2018, 11:08:25 PM »
@terrifictimbersllc
I have the same exact mill and problem.
I will be ordering the seal kit from WM tomorrow. Any tips for me before I dive into this?
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
« Reply #9 on: November 30, 2018, 06:11:10 AM »
Its all a distant memory.   Maybe keep everything clean and organized and don't lose anything.
Also have an extra cylinder on hand so you can take your time.  :) :) :)
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #10 on: December 02, 2018, 07:07:28 PM »
Glad you got it all back together TT! Looks like my plan to go full time on the mill is fading away and Ill be back to spinning wrenches soon :( had an interview last week that seemed to have gone well. Unfortunately, its an hour drive each way.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Repair of Hydraulic Cylinder
Started by Left Coast Chris on General Board
Last post November 10, 2010, 11:16:18 PM
by Left Coast Chris
Husqvarna 359 Cylinder damage, repair or replace?
Started by jjmk98k on Chainsaws
Last post May 31, 2010, 07:26:43 PM
by jjmk98k
Engine repair using "clamp a stud"
Started by Jim_Rogers on General Board
Last post December 13, 2011, 04:52:57 PM
by POSTON WIDEHEAD
To seal or not to seal? That is the question.
Started by kevin19343 on Drying and Processing
Last post August 30, 2014, 05:52:57 PM
by BCsaw
