Arborwear
Author Topic: A day cutting wood  (Read 282937 times)
Offline Farm29
Re: A day cutting wood
« Reply #2160 on: November 12, 2017, 08:17:52 PM »
thats what i thought it was i was looking at a 5420 open station 81hp with 3000ish hrs on it and factory jd loader  they were asking $21900 thought that didnt sound to bad i have a 4020 now with no loader and im ready to move to a front assist with loader the one thing i wish it had was a left hand reverse but o well glad to see yours can handle some big logs.  i used the farms 6430 the other day to move a 42-36" by 10' walnut log and i think it was about all it wanted unless i put weight on the back but got it loaded know i just have to decide if i want to set it on my mill  ???
96 lt40 Hyd 24 hp onan
460 rancher
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #2161 on: November 13, 2017, 05:58:04 AM »
Maybe cut it in half first. [the long way] good luck. 8)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
    • A&P Saw mill LLC
« Reply #2162 on: November 21, 2017, 07:48:21 PM »
11 loads like this went out.
And always making more.  ;D
Sawing since 1987
    • A&P Saw mill LLC
« Reply #2163 on: November 22, 2017, 07:04:33 PM »
Sometimes loading a customers lumber can be a pain.
20' in a 24' box
Sawing since 1987
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2164 on: November 22, 2017, 07:09:28 PM »
Ah but putting them in is much better that taking them out...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #2165 on: November 22, 2017, 10:47:37 PM »
UHaul should make flatbeds.
And did you ask them how they planned to unload?
1992 LT40HD
Offline longtime lurker
« Reply #2166 on: November 23, 2017, 02:06:32 AM »
some questions are probably better not asked. :D
    • A&P Saw mill LLC
« Reply #2167 on: November 23, 2017, 05:55:46 AM »
NO. I said have a safe trip.  ;D
Sawing since 1987
Offline thecfarm
« Reply #2168 on: November 23, 2017, 07:37:57 AM »
Peter cuts them,and loads them.  :D
Offline jwade
« Reply #2169 on: November 23, 2017, 07:47:38 AM »
man, i hope he does not have to make a panic stop.
Offline Bruno of NH
« Reply #2170 on: November 23, 2017, 07:52:41 AM »
I was there and seen him load em :)
It went like clock work :)
With the Cat and John
Let's not forget Jake
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline 21incher
« Reply #2171 on: November 23, 2017, 10:30:33 AM »
Looks like a nice flat 20 foot long roof.  ;D Just saying.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #2172 on: November 23, 2017, 10:53:21 AM »
Loads em and leaves em.  :D :D
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Darrel
« Reply #2173 on: November 23, 2017, 09:18:39 PM »
Loads em and watches em leave. :D :D :D
1992 LT40HD
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #2174 on: November 25, 2017, 01:22:19 AM »
Could be simple.  Tie one of the middle ones to something solid and drive up.   ;D  The trick would be what to do with it after it's on the ground.   The outside ones would have to move to the middle so as not to rip the door tracks off.
Scott
[Magicman]
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #2175 on: November 25, 2017, 09:44:52 AM »
quote - "I hope he does not have to make a panic stop."
If the load is loaded tight to the front wall, no inertia can build up in a "brake - check" stop to cause damage. The force of all freight pushes evenly across the front of the van. On a flatbed trailer "false bulkhead" is built by stacking wood and chaining / strapping it down in front of the load to prevent forward movement.
Card carrying Wood-Mizer owner - 2017 LT28G19
Kubota MX5800 4WD HST, '07 Dodge Ram 2500 4WD 5.7 Hemi with 8'-2" Boss V-XT plow, a couple of Stihl chainsaws,
18 acres of trees, 7 guitars, and Class A CDL licence with about a million miles in a semi truck.
"Chasing the sawdust dream..."
    • A&P Saw mill LLC
« Reply #2176 on: November 26, 2017, 12:00:28 PM »
The price on W Pine went from .34 a bf to .38 this week is what some big mills are paying now.
I think by spring it will be .40 a bf for logs. :o
I'm going to set my log price at .40 to make my price list for lumber for 2018.
Sawing since 1987
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2177 on: November 26, 2017, 01:49:18 PM »
What grades and lengths do you accept? Do you have to take knotty uppers to get the loggers to sell to you?
Offline rjwoelk
    • countrysidefirewood
« Reply #2178 on: November 26, 2017, 02:05:06 PM »
There is talk of a 35 percent increase in lumber up here in canada. That is good for me.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
    • A&P Saw mill LLC
« Reply #2179 on: November 26, 2017, 06:39:15 PM »
All the big mills only want 12',14',16', and maybe some 10' logs.
What happens is the logs get cut mostly 16' some loggers don't look at the logs and there like a boomerang. :D :D
Over at A&P Saw Mill I want gun barrel straight logs, So that means [old school].
Cut the logs the way they come out of the tree, I get 8'6" and up to 16'6" some 20'6" too
And I pay the same for an 8' like a 16'. If the grade is there.
Hunch back logs, logs with 2 piths, 4"+ knots are pallet logs. Less $$ for them.
At one time that's how trees where cut.
I met a new to me old logger on Saturday was happy I buy 8' logs.
I just half to wach out I don't just get the top half of the tree in a load, The butts had better be there too. :D :D
When I started buying all this wood some truckers, loggers, tryed to pull a fast one from time to time on me. :D
It took a while to weed them out. Now I have a good bunch and they know me better too.
The bigges thing [ THE MONEY IS THERE] no bull.
Buying 8'and 10' brings loggers in.
Dave In the mill biz I do get some knoty stuff, But if I don't pay much for it and tell them [DON'T BRING ME THAT JUNK]  :D :D :D :D :D :D :D
They get it. Like I tell the them no smaller than 10" top. Some 8" will come too.
It is what it is, So I try to market the not so good logs.
The loggers don't grow the trees, They just work with it.
What I will not buy is Red rot W Pine.
I got one logger all mad at me because he brought a load of red rot junk. Culled most of it.
Sawing since 1987
Cutting wet wood
Started by outdoortype on Chainsaws
Last post April 26, 2005, 05:46:41 AM
by rebocardo
Cutting Wood
Started by luvmexfood on General Board
Last post January 03, 2018, 10:49:47 PM
by luvmexfood
Cutting Burn Wood
Started by rmack on Sawmills and Milling
Last post March 21, 2013, 04:40:15 PM
by johnjbc
woodbowl cutting my wood
Started by gatorpan on Sawmills and Milling
Last post March 31, 2010, 12:31:02 AM
by fishpharmer
