Author Topic: A day cutting wood  (Read 339564 times)
Offline Lawg Dawg
  • True South Sawmill Lumber
Re: A day cutting wood
« Reply #2820 on: October 02, 2018, 08:21:14 PM »
Heck Yeah, you like me. I like to be close to home...actually in the 8 years I've been sawing, I've never done a road job!  8)
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #2821 on: October 02, 2018, 08:32:12 PM »
Wouldnít it be cool if WM could put a horizontal edger on their mills that travels in front of the blade so we didnít have to do all this extra stuff to edge boards
Boy, back in my day..
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
« Reply #2822 on: October 02, 2018, 08:40:41 PM »
4x4
Sharpen your debarker up and give er a little more fuel. It will zing right through there :D
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #2823 on: October 03, 2018, 06:59:22 AM »
The edger will take more work to set up. Yes, all the wood will go one way.
A&P saw Mill LLC.
License NH softwood grader.
Offline Bandmill Bandit
« Reply #2824 on: October 27, 2018, 12:06:56 PM »
We are getting back to the cabin since we have some good weather again.
Here is what was done during the prep work as weather allowed the last few weeks.
The jig we built and are using is from Log Dovetail Jig Homepage and it works very well. I think the pics are all pretty self explanatory. If you have a question just ask.
The staining was completed on Wednesday and today is set for stacking the walls IF it dont rain, and right now that is not looking so good. I will post pictures from the stacking when we are done that part.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4. 2018 F150
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built myself
« Reply #2825 on: October 27, 2018, 08:28:57 PM »
Today turned out real well!
Rafters, chinking, door and window jams next.
Offline 69bronco
« Reply #2826 on: October 28, 2018, 09:00:42 AM »
Looks good! What size did you saw your logs? Are they green?
Offline barbender
« Reply #2827 on: October 28, 2018, 09:36:35 AM »
A heck of a day! It's great to get that kind of progress!👍
Offline LeeB
« Reply #2828 on: October 28, 2018, 09:46:45 AM »
May be a dumb question, but why are log structures not dead stacked? Is this to allow for less than perfect logs?
« Reply #2829 on: October 28, 2018, 11:10:06 AM »
The logs are 6"X 9". The trees went down during a late summer storm in 16 so have been through 2 winters. They were sawed in August and dry stacked on a very windy hill. Testing for moisture says they are at 12% to 14%. The builder says that is about dry for this region.  The joints are cut to allow one inch chinking/insulation space. That how the owner wanted them after talking to the people at the log dovetail jig website.
« Reply #2830 on: November 01, 2018, 03:16:26 PM »
Took out 1 row of logs and got the conner posts installed.
« Reply #2831 on: November 05, 2018, 10:04:16 PM »
Progress!
Purlins, insulation and roof metal are next.
Offline PAmizerman
    • Byrne Millwork
« Reply #2832 on: November 06, 2018, 08:19:08 AM »
Looking good!
 Looks like it's going to be a race against the snow smiley_horserider :snowball:
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
« Reply #2833 on: November 06, 2018, 10:52:55 AM »
It is certainly looking that way. Hopping to have the tin on by the weekend.
Offline rjwoelk
    • countrysidefirewood
« Reply #2834 on: November 07, 2018, 08:26:52 AM »
How did they do the mid span dovetail?
We rigged a second jig that followed the main jig to make bread cuts then cleaned them out and smoothed it all off with a slick work very well.
For that cery reason we gad a second set of top cants incase we screwed up the first ones. :D
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
« Reply #2835 on: November 07, 2018, 11:39:35 AM »
Hi RJ. Yup sounds like we did pretty much the same thing. It worked very well. Was a bit fiddly but worked good. We have an extra log in case of screw ups but so far every thing has worked very well.
Offline rjwoelk
« Reply #2836 on: November 07, 2018, 09:31:02 PM »
we did the same with our cabin.
« Reply #2837 on: November 18, 2018, 10:14:42 PM »
Here is a few pics of the Nordic Spa at the Kananskis Lodge that I posted the milling for in post #163. These pic swere taken by my son when he and his wife went out there for a day trip. I will get a few more pictures when i am out there myself after christmas.
<br
    • A&P Saw mill LLC
« Reply #2838 on: March 04, 2019, 08:28:50 PM »
Very nice, Bandmill Bandit, Are you the sawer here that uses carbide blades??
A&P saw Mill LLC.
Offline hersnsh#590
  • I'm new(ish)
« Reply #2839 on: March 04, 2019, 08:38:48 PM »
Peter:  Good to see you back.
Dale
TK 1600, small sugaring operation, a bench full of J'reds, a tired ford 1710, 2 Honda 4 whlrs, and an understanding wife.
Cutting Wood
Started by luvmexfood on General Board
Last post January 03, 2018, 10:49:47 PM
by luvmexfood
My Day Cutting Wood
Started by lxskllr on General Board
Last post November 10, 2018, 05:10:32 AM
by timberlinetree
Cutting wet wood
Started by outdoortype on Chainsaws
Last post April 26, 2005, 05:46:41 AM
by rebocardo
Cutting burnt wood
Started by gumnut on Chainsaws
Last post September 15, 2005, 03:44:42 AM
by StihlDoc
