Arborwear
Author Topic: semi truck load of split firewood  (Read 6042 times)
Offline missouriboy
« on: May 05, 2012, 09:42:57 PM »
How much split wood is in a semi truck load and how much does it go for. ;D
Offline chevytaHOE5674
Re: semi truck load of split firewood
« Reply #1 on: May 05, 2012, 10:17:08 PM »
What size semi load....?  :D
Offline beenthere
« Reply #2 on: May 05, 2012, 10:18:15 PM »
What are you thinking ... a flat bed, box piled loose, stacked in, or on pallets? What wood species, and how seasoned will the split wood be when loaded?
Dump box? Van box?
How would you load the semi trailer, and how would you unload it?
Offline gunman63
« Reply #3 on: May 06, 2012, 01:07:21 PM »
get the measurements, figure square footage, if its loose dumped in, figure 160 sq ft a cord
Offline beenthere
« Reply #4 on: May 06, 2012, 03:42:08 PM »
Maybe meant 160 cubic feet?
Offline gunman63
« Reply #5 on: May 06, 2012, 05:09:52 PM »
yep i did
Offline missouriboy
« Reply #6 on: May 06, 2012, 08:24:59 PM »
sorry i don't know much about semi truck loads of firewood. If you couldn't tell  :D. Thats why i am on this site to maybe learn a few things from guy who do this stuff and any help would be great. What is the most common why people buy the stuff. So if you guys know the prices on different size loads and how much firewood each different kind of load can haul if it was loaded with oak or some other kind of hard wood.
Offline james
  • truck drivin fool
« Reply #7 on: May 10, 2012, 12:45:35 AM »
you are looking at a max payload with most flatbeds of 48,000 lbs 10-15 cords depending on the weight of the wood
james
Offline doctorb
  • Unofficial Team Physician
« Reply #8 on: May 10, 2012, 09:00:43 AM »
When carrying wood, is the payload of a generic "semi" (whatever that is) restricted by the weight of the load or the volume of it?  I mean, do you stop filling it up because of a weight limit, leaving it only partially full, or do you stuff it full to the brim, because weight is not a problem?
Offline Holmes
  • 1840 house
« Reply #9 on: May 10, 2012, 10:48:10 AM »
  Weight is the issue. You get fines for being over weight.
Think like a farmer.
Offline MDLogging
« Reply #10 on: May 11, 2012, 06:23:30 PM »
I've got a 33 foot dump trailer with 7ft sides and i figure it holds about 9 cord.  My gross weight is only about 72000.  I usually figure 185 cubic feet on a loose cord.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #11 on: May 11, 2012, 06:40:06 PM »
I figure 190 cubic per loose cord.  180 will stack up a little short.
Buying firewood by the log truck load to resele.
Started by saxon0364 on Firewood and Wood Heating
Last post December 29, 2012, 07:25:06 AM
by timberjack 450
going rate semi load of logs
Started by northernss454 on Forestry and Logging
Last post September 20, 2009, 08:29:11 PM
by Wild willy
semi load of cherry to plane what to charge
Started by ozarkgem on Sawmills and Milling
Last post May 02, 2014, 07:47:44 PM
by ozarkgem
How long is split and stacked firewood viable as firewood.
Started by mart on Firewood and Wood Heating
Last post August 28, 2014, 06:05:10 PM
by mart
