Author Topic: Recovering from Fishtailing  (Read 20213 times)
Offline Bruno of NH
Re: Recovering from Fishtailing
« Reply #20 on: June 25, 2019, 07:55:12 PM »
I just reach down and hit the trailer brake a bit till it straightens out.
I had one dump trailer that never pulled well no matter how you loaded it.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline samandothers
« Reply #21 on: June 26, 2019, 11:21:56 AM »
I too understood that trailer brakes applied manually would help.  I have a neighbor that stated he would get on the brakes of the vehicle and the accelerator.  He indicated this would apply trailer brakes and a pull from the vehicle to correct the fishtail.  I have never tried this.  Do you have a anti sway bar on the hitch, assume it is tag along?  A sway bar helped my camper pulling experience.
Offline Ed_K
« Reply #22 on: June 26, 2019, 04:10:22 PM »
 Haven't driven TTs for yrs do they still have a hand brake on the steering wheel pole?
Ed K
Offline clww
  • Oh yeah? Watch this!
« Reply #23 on: June 26, 2019, 07:31:02 PM »
Yes, Ed. Most companies still have the “Johnson Bar” or “Trolley Bar” for operation of the trailer brakes.
Many Stihl Saws-16"-60"
18-Wheeler Driver for Knight
« Reply #24 on: June 26, 2019, 08:18:36 PM »
Brake controller I installed on my previous  truck, 2004 GMC 2500HD, was made like a CB microphone and the cord plugged into an under dash control.  The hand held device that stayed on the console allowed you to adjust the brakes and had a switch on the side like a microphone key that you could squeeze if need to manually apply brakes.  The truck I have now has a factory brake controller but has a slide switch on the lower dash you can apply brakes with.
angry
Recovering Info
Started by Fla._Deadheader on General Board
Last post May 16, 2007, 09:32:14 AM
by Carries-Mom
I am a recovering scrap junkie
Started by slider on General Board
Last post November 29, 2015, 08:39:17 PM
by POSTON WIDEHEAD
recovering side lumber
Started by Dave H. on Sawmills and Milling
Last post February 17, 2016, 09:48:18 PM
by Jeff
thumbup
Recovering digital photos from a cameras deleted memory card
Started by woodbowl on General Board
Last post February 21, 2006, 07:58:17 PM
by iain
