Arborwear
Author Topic: Over 40" bars for MS660?  (Read 9671 times)
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Over 40" bars for MS660?
« Reply #20 on: July 04, 2012, 09:31:14 AM »
My new MS660 has a screw on the bottom to vary the amount of oiling.   It is set in the middle of the range.  I haven't used it yet but will turn it up if my 36" bar isn't oily.   S Grinder how much was that higher output oiler for your MS660?
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline s grinder
« Reply #21 on: July 04, 2012, 05:13:34 PM »
Terrifictimbersllc,The up graded oil pump was $82.34 retail,part #1122-640-3201.Now Sthil issued a technical bulletin #34.2009 stating that "in the future,oil pump #1122 640 3205 will be replaced by oil pump #1122 640 3201 on both flush and wrap handles on versions of the MS650 MS660 Magnum.If you just bought the saw and is brand new you might have the up graded version,mine is almost 2 years oil and did not.If you cut a couple of logs close to 36"and they are dry,you'll know how it oils very quick
« Reply #22 on: July 05, 2012, 05:40:06 PM »
Thanks.  There is something in the manual about how to tell whether it has the high output oiler. I will check.
« Reply #23 on: June 18, 2013, 05:30:45 PM »
Continuing to shop for a long bar for my MS660 for occasional freehand trimming of flare on large logs.
Have found an Oregon OR 423RNDD025 at Bailey's, 42 is for 42", 3 is for 063, RND is replaceable roller nose, and D025 is the mount for "small Stihl" (12.1mm slot).  This bar is $120 at Bailey's.
Cannon has CSB-S1 50 63 4 (S1 is the "small stihl" 12.1mm slot for MS660/MS460, 50 is 50 inches,  63 is 063 ga, and 4 stands for 404 pitch).  Bailey's has it and says they can swap on a 375 roller nose which makes it a CSB-S1-50-63-3 (last 3 is for 375 pitch).  This bar is $300 at Bailey's.
Wondering if these are the only choices for over 40" bar for MS660.  I already have a 36" so I am thinking get a 48-50".  Still wondering if there are others to choose from.
Offline clww
  • Oh yeah? Watch this!
« Reply #24 on: June 18, 2013, 08:47:54 PM »
I've gotten my two longest bars (used) off ebay. The 54" is a Cannon, and the 60" is an unknown brand. I don't use these often, but they come in handy when needed. The 60" hanging on the 090 is really a sight! ;D
Many Stihl Saws-16"-60" Husky 372XP
18-Wheeler Driver for Millis Transfer
Offline sawguy21
« Reply #25 on: June 18, 2013, 10:29:52 PM »
Not much call for the really long bars anymore, the loggers have modified their techniques so they don't have to lug those monsters around. We still get requests from mills, they use them to trim lifts before loading on rail cars and sea containers. Cannon is very good but very expensive as they use high quality materials and are limited production. I am really glad I don't need to swing that 090
Offline HolmenTree
« Reply #26 on: June 19, 2013, 07:24:26 AM »
Here is a photo of a job I had at our local Tolko pulp and paper mill about 7 years ago. We had to cut these cull paper rolls in half so they could be put back into the re-pulper. The rolls couldn't be sold because of defects so they were just recycled.
On the first week of the contract I swung my 090 with 60" b/c through these rolls 12 hours a day all by myself, but the following week I got a helper :D
On our best day we cut 42 rolls of this tough SPX paper used to make cement and feed bags, some of the strongest if not strongest paper in the world. One mile of paper in these 54" diameter rolls  when rolled out and weighs over 5,000 lbs.
One cut took up to 5 minutes at wide open throttle, and the .404 Stihl harvester chain needed a quick 5 minute touchup with the file for every cut. Toughest fiber I ever cut.
Offline turbo885
« Reply #27 on: June 19, 2013, 06:16:26 PM »
That had to be a dirty dusty job
Offline customsawyer
    • The Custom Sawyer
« Reply #28 on: June 19, 2013, 07:31:09 PM »
If I was buying a new long bar I would lean towards the Oregon reduced weight bars.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
« Reply #29 on: June 19, 2013, 09:09:34 PM »
I can't find Oregon selling any bars over 42".
Offline HolmenTree
« Reply #30 on: June 19, 2013, 09:37:02 PM »
It was but it paid a $100 hr at the time 7 years ago and all it cost me a day was 5 gal of mix gas and a gal of bar oil plus minimum wage for my worker.
Btw I think Stihl still sells 42" and over bars, could be wrong now though, Cannon is the only other alternative.
« Reply #31 on: June 19, 2013, 09:57:03 PM »
Yes Stihl over 42" for the large mount 880, 090 etc, but 36" is the largest stihl bar for the MS660.   I have two 090AV's but these are just too heavy for me anymore.
Offline HolmenTree
« Reply #32 on: June 19, 2013, 11:05:10 PM »
36" was the longest I ever ran on my 066 Mag. That was the longest bar spec Stihl put on the 660/066, a lot of the 066/660 had weaker then normal oil pumps but there was a high output pump available, I'm not sure my 066 has the option, never replaced it.
« Reply #33 on: June 20, 2013, 06:22:21 AM »
Yes, I can get a higher output oiler for the MS660 if I need to, think it's about $80.  Doubt my usage amount would make me need it though.
    • The Custom Sawyer
« Reply #34 on: June 20, 2013, 08:39:54 PM »
I will check with my still dealer and see where he gets them. All I can say is that he has gotten me two 48" bars over the years.
« Reply #35 on: June 20, 2013, 08:49:29 PM »
Appreciate that.  Maybe Oregon or some others sold them earlier but don't now.
« Reply #36 on: July 07, 2013, 01:36:20 PM »
Customsawyer checked with his dealer and was told that they can't get an Oregon longer than 42" for the MS660 anymore.
My conclusion..... only options I have found for a 50" bar is a Cannon 063 bar (Bailey's) with either a 375 or a 404 sprocket nose.  I don't know if Baileys can get me a 50" Cannon 050 bar or not.
Now I'm wondering if the MS660 (1 year old) will pull 404/063 chain, I would use OR 27AX (the skip sequence).   This chain is 0.025" wider (chassis) and about 0.08" wider (outside of cutters) than 375/050 chain.  I don't know how much wider it is than 375/063 chain (dont' have any of that).    I think I'll make a new post to ask this question.
28" bar for ms660
Started by ohiowoodchuck on Wanted
Last post January 25, 2016, 01:48:20 PM
by rdobb13
any suggestions on a "full chisel" chain for stihl 310? what about bars???
Started by fury1973 on Chainsaws
Last post January 23, 2012, 05:10:56 PM
by tcrew
47" - 50" 3/8 Stihl-mount sprocket-nose bars
Started by DonnerParty on Chainsaws
Last post January 26, 2016, 11:53:40 PM
by Redbull661
"frost bite Chainsaw bars"
Started by logger444 on Forestry and Logging
Last post September 19, 2014, 11:47:07 PM
by Maine logger88
