Author Topic: Tongs . . . . . . again  (Read 6656 times)
Offline opticsguy
« on: June 26, 2012, 12:08:31 AM »
I know we discussed tongs here awhile back, kind of forget what all was covered.
Will start building a wheel arch this coming month and will need a tong for hauling and lifting the log.
First question:  All tongs seems to come with a warning; NOT FOR LIFTING.  Would this apply to a wheel arch?
Second question;  I do prefer to support my local businesses and the best hardware store, probably on the West Coast is in my small city.  They carry three tongs, one made in USA but very small and two larger ones.  Looks like the largest, about 30" tall would be the one i need, will this work on smaller logs and down to what size? Cost about $96
Third Question;  do you folks grind and sharpen the hook tips to make them function properly or does this really matter so much?
And finally, Is there a better place or better deal or a particular brand of tongs that is so good, i should buy it?  (Kinda of like those Logrite Cant hooks?)
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline captain_crunch
Re: Tongs . . . . . . again
« Reply #1 on: June 26, 2012, 01:09:19 AM »
You cant go wrong with Logrite All lifting equip has this warning to cover lifting people or over them to be politicaly correct as in cover their b**t
Offline coastlogger
« Reply #2 on: June 26, 2012, 01:25:27 AM »
Ive been using the same set of tongs for 30 years and they are likely 80 years old.Im guessing they are around 26 inches tall, i know they are 1.25 inch stock,real good steel. Theyll pick up down to about 8 inches reliably,less than that they tend to be dropsy. I can lift a 24 inch log easily, but the tongs are at max spread and can bend easy that way. If the log is real heavy I try to do one end at a time,or use a strap.I sharpen them occasionally like maybe every few years.I(f theyre sticky sharp they do grab hold better but are more difficult to get off the log by jiggling tooth sucking etc. Once the tongs are bit in its immaterial how sharp they are. Ill measure them tomorrow.
I hang them on a piece of 3/4 chain and find I rarely have to manually set or unhook them.Practice does help.
clgr
Offline bandmiller2
« Reply #3 on: June 26, 2012, 06:32:35 AM »
What Coastylogger says.I've had a pair of tongs I bought from Belsaw when they were in business must be 35 yrs ago,the good ones last forever.Any tongs that are reasonably priced have that warning just means their not approved for overhead lifting.Some tongs are approved but are very expensive with the pedigree tag on them.For what you want to do the nonhoists will do fine.Never bothered to sharpen mine but it won't hurt anything to keep them pointy.Frank C.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: June 26, 2012, 08:10:01 AM »
The arch on tongs is just as important as the hook arch on a cant hook.  Flimsy tongs will spring out with a heavy log and some may actually bend.  Heating and re-arching is tricky because of the temper of the metal.
As has been previously mentioned, tongs that are 50+ years old were made for work.  Sadly, most of today's tongs were made in China, and made to sell, not handle a load.
The tongs on the right will not spring out and loose their shape.
Offline opticsguy
« Reply #5 on: June 26, 2012, 08:21:36 AM »
Thank you for your replies.  Magicman, Now i see the REAL difference, your tongs are a lot better shape than the ones at my local store.  Larger and well angled points.  Have advertised on craigslist in my area for several months with no replies.
I will keep looking for a real set!!
Thanks!!
Offline Bogue Chitto
« Reply #6 on: June 26, 2012, 08:40:36 AM »
  These do a good job.  I lift logs off of trailers and skid with them.  Never been sharpened.
Offline opticsguy
« Reply #7 on: June 26, 2012, 08:45:36 AM »
Magicman,
I see two hooks on chains hanging in your photo, what do you use these for?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: June 26, 2012, 09:04:29 AM »
Those are my "End Tongs" used for unloading logs and adjusting logs around the sawmill.
I made them from broken logging tongs.
I use them to unload and move logs.
Adjusting a 20' log on the sawmill using the roller toe boards and side supports.
Adjusting a log using the sawmill's log clamp.
Offline MHineman
« Reply #9 on: June 26, 2012, 12:36:40 PM »
  I like that half tong with the sawmill winch.  That was always work getting the log moved square to the mill let alone the challenge getting the log to roll up the ramps.
  I have 3 tongs, but only 1 sees any real use.  Slight differences in the angle on the hook, the curve of the tong, and the length of the hook make one easy to use and another very difficult.  If possible find someone nearby that has a set of tongs that work well and make a template to compare to one you are thinking of buying.
  I have a small set I got many years ago.  They are too small to be useful and the hooks are too short.
  The other 2 I got from a local sawshop about 3 years apart.  The first is a 25" tong.  It has blue paint like the Logrite cant hooks, but no name on it.  The second is red, but faded quickly to pink.  The second is a 32" tong.
  I use the 25" tong to skid logs from 10" to 36" in diameter.  It works great.  The points were sharp when I got it and have not done a thing to it.  I never once worried about bending the tongs, but a 40 hp tractor is a good match for these too.
  I tried to use the 32" tongs and had nothing but problems.  The arch of the tong seems to be a little less that it should and that keeps the points from digging in and the points are a little short.  The points also seem to be very slightly off from the ideal angle.  These were new tongs or I would have thought they might have been bent before I got them.
  Regarding "not for overhead lifting" I think tongs with a chain hook are always consider in that category.  Some tongs have a ring instead.  I prefer the chain hook to work with.  I'm sure CYA has a lot to do with the declaring the not for lifting, but knowing people will use them however they want.
1999 WM LT40, 40 hp 4WD tractor, homemade forks, grapple, Walenstein FX90 skidding winch, Stihl 460 039 saws,  homebuilt kiln, ......
Offline Larry
« Reply #10 on: June 26, 2012, 01:00:04 PM »
I bought a used set made by I know not who a long time ago.  There plenty heavy and work well although I did break one sidedoing something stupid.  A few years later I bought a second set at auction just because they were cheap.  Still had a shipping tag and they were sold by TK.  They are heavier than the first set and about the same size.  They have one big advantage over the first set in the range of logreally small to big.
I saw a set in TK last time I was there so I assume they still sell them.  I can recommend them highly.
« Reply #11 on: June 26, 2012, 01:35:07 PM »
M_M
Them look like mine  :o Judgeing by ring they appear to be older ones. Out west here they were a dime a dozen then somebody got idea to make fireplace andiorns(you know what i mean) and lots of them fell to that fate
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: June 26, 2012, 01:51:39 PM »
That is terrible, but many good tools have fallen because folks had no use for them and modified their use.  I remember that my Brother got the hooks from our old peaveys and we used them for fence staple pullers.   :-\  It seemed like a good idea at the time.
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #13 on: June 26, 2012, 03:23:30 PM »
Maybe someone can elaborate more on skidding tongs and lifting tongs there is a difference in shape. The tongs Bouge Chitto has on his tractors 3 pt look like lifting tongs.
  in this pic iam using lifting tongs for skidding NOT recomended. Idont do this any more. I picked up a nice skidding tong at store Optics guy mentioned they are 1/3 the price the lifting tongs are. TK dose sell both and they are USA.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
« Reply #14 on: June 26, 2012, 04:19:54 PM »
When I ordered it said on the label, not for lifting.  I do lift with them tho.  ::)
Offline beenthere
« Reply #15 on: June 26, 2012, 05:08:05 PM »
Don't know what a person could do with tongs that didn't involve lifting.   ::) ::)
Offline pineywoods
« Reply #16 on: June 26, 2012, 05:10:36 PM »
I make my own tongs. Use them for lifting, skidding, and anything else I need tongs for. These are made from big truck tie rods, good quality steel. Heated with a torch and bent to shape, then ground the points off sharp. Notice the angle of the points, that's fairly critical..
Offline wdncno
« Reply #17 on: June 27, 2012, 09:08:03 AM »
Check our sponsor Bailey's- They have lifting tongs.
Offline Sixacresand
  • John and Nancy
« Reply #18 on: June 28, 2012, 08:56:20 PM »
I bought a set of tongs (probably Chineese) at one of those shopping center Tool stores up in Pigeon Forge, TN during a trip to dollywood.  They work pretty good.  I wish I had bought two.  Using on my log arch and picking up 24 inch X 16 ft logs and not bending/breaking.
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #19 on: June 28, 2012, 10:43:21 PM »
The Dixie Mfg tongs are made in America and are very high quality.  I believe that they are the same ones Logrite uses.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Help out kids at the museum! Difference between ice tongs and skidding tongs?
Started by HistoryNerd on General Board
Last post April 05, 2018, 10:30:38 PM
by r.man
lifting tongs or skidding tongs
Started by boboak on Timber Framing/Log construction
Last post January 04, 2006, 11:56:11 AM
by KILROY
skidding tongs or lifting tongs?
Started by surfsupinhawaii on Timber Framing/Log construction
Last post February 18, 2007, 07:51:03 AM
by Jim_Rogers
TONGS ON E-BAY
Started by AtLast on General Board
Last post November 30, 2003, 11:21:02 AM
by sawman
