Author Topic: 2 w.d. or 4 w.d. delivering firewood in northern michigan  (Read 5176 times)
Offline glassman_48
  • 1-231-258-4246-work/ed/231-564-2672/cell
« on: June 26, 2012, 06:53:56 AM »
I had a post earlier this month (what type of dump truck) and got a lot of good advice.  I have found a 2000 F/550 2 w.d. 7.3 diesel for sale with 50,000 miles and a 16' dump bed.  My concern is getting around in the winter time delivering firewood especially when the truck is empty.  Ironwood had a 2 and 4 w.d. truck in this range.  Just wanted opinions, nervous about getting a 2 w.d. I am in northern lower michigan and I am in a snow belt.  Thanks in advance, Ed
Offline chevytaHOE5674
  • Forester
Re: 2 w.d. or 4 w.d. delivering firewood in northern michigan
« Reply #1 on: June 26, 2012, 08:32:38 AM »
Loaded up shouldn't be to bad, but empty might be another problem. We get a lot of snow UP here and you couldn't give me a 2wd truck as I couldn't make it out of my driveway when empty. Once on the roads I can usually manage in 2wd but slow speed maneuvering around the farm and stuff is nearly impossible. Also with 4wd comes Low range which really helps with slow speed maneuvering with lots of weight in the truck.
Offline thecfarm
« Reply #2 on: June 26, 2012, 08:52:34 AM »
Duel wheels on the back? If so would be hard in  snow to get around I would think.
Offline NWP
    • Nicholson Wood Products LLC
« Reply #3 on: June 26, 2012, 08:56:15 AM »
I had a 2 wd truck in high school.  I swore I would never have another one.  A little extra cost looks pretty cheap when you're stuck.
1999 Blockbuster 2222, 1994 Duratech HD8, 1997 Duratech HD10, 2011 Case SV250, 2000 Case 1845C, 1990 Peterbilt 378 w/ Hood 7000 loader, 2001 Chevrolet, 2005 Chevrolet, several trailers, and Stihl saws.
Offline snowstorm
« Reply #4 on: June 26, 2012, 10:36:15 AM »
i plow roads with a f550. 10' plow 9' wing i very seldom use 4wheel drive. it gets around very well
Offline glassman_48
« Reply #5 on: June 26, 2012, 03:52:42 PM »
snowstorm, your truck has regular wheels in back not duallies am I correct?  I almost always had to put my toyota tundra into 4 w.d. when pulling my  12 foot dump trailer loaded with one pulp cord when pulling into a driveway to deliver.  thanks for your input everyone,,Ed
Offline snowstorm
« Reply #6 on: June 26, 2012, 06:02:24 PM »
all f550's are dual wheel. a no spin rear was available. tires make a difference i run winter deep bandag caps on the rear. you can always buy a set of chains. with a long wheelbase it may have a double frame........thats good. is it auto or 6 sp?
Offline glassman_48
« Reply #7 on: June 26, 2012, 07:35:12 PM »
snowstorm, he just said a manual trans.  cell phone could barely hear him.  He got out his registration, and said gross weight was 18,000 lbs.  My b- in law said with a 16' bed the overall weight of the truck might be to much to haul 2 cords of firewood.  I figured 8,000 lbs for the wood.  I am trying to get him to a scale to weigh it.
Offline snowstorm
« Reply #8 on: June 26, 2012, 08:22:24 PM »
the reg can be any amount you want to pay for. depending on springs it could be 17500 to 19500 gvw that makes it a class 5 truck. i would not worry about hauling 2 cd on it
Offline glassman_48
« Reply #9 on: June 26, 2012, 08:46:53 PM »
snowstorm,
I want to make sure I understand this, if the truck is rated at 18,000 lbs.  And the truck with a 16' box weighs say 12,000 lbs. then I could not legally carry 8,000 lbs is that correct?  I just started reading the cdl manual to get a cdl license.  This stuff is kind of foreign to me.  Could I put heavier springs on then, the part where I could get the truck registration at a higher weight doesnt make sense to me.  I understand that the higher the weight rating you have to pay more money every year.  Sorry to be so naive, I can answer almost any glass question, but this still isnt quite making sense.   Thanks Ed
Offline bill m
« Reply #10 on: June 26, 2012, 08:57:44 PM »
I just sold my f450 2 w.d. chip truck. I think it was stuck almost as much time as it was moving. Spend the money and get a 4wd. It is better to have it and not need it than be stuck and have to call a tow truck.
Offline Ironwood
    • http://www.branchandburl.com
« Reply #11 on: June 26, 2012, 11:41:00 PM »
Nearly IMPOSSIBLE to find a 7.3 550 4x4. They are a premium. Get the 2wd, get chains, and a posi rear (I have one if you want it, and a set of 3:91's instead of the 4:88's from the factory) a 550 4x4 7.3 will cost twice as much as a 2WD. The 3:91's will tach at 2000 RPM at 70 and save the engine from winding out if you do any highway. Also, grab a local UPS guy and ask to see his "quickie chains" for when they get in a tight spot/ get stuck. They simply hook through the outer budd rim holes on three of the four (skip the one with the air valve unless you wanna rip it out ) and will usually get you out of a tight spot without fully chaining up (takes about an hour), quickies take about 5-10 minutes. Trust me, unless you can settle for a V10 gasser, get the 2WD.  The 4x4 7.3  are "hen's teeth" I have only seen a few and they are usually 8-10' beds. One local guy has one it is rough looking, low miles 90k, and he wants $17,000. Most were township salt plow trucks (read: Rough life laid up wet and salted)
 Ironwood
Offline Ironwood
« Reply #12 on: June 26, 2012, 11:47:39 PM »
I was going to put the posi and 3:91's in my V10 550, but the truck tachs well with 4:88's (gears more suited to the gas engine) and my"gear shop" broke open the Dana 136 and said "you got Tru-Track" you dont want the Detroit posi in here" this is almost as good. So, I told them to seal her back up and call it a day.  So, the Tru-track must be the no slip the guy talked about, and I gotta say it never has spun when I have been in a yard, or plowing. This was a propane delivery truck, so it had the special order Tru-Track  for going into yards and also an output plate on the auto tranny for a PTO (that's another story, only Muncie made the custom kit and it was $3200 retail, gear box and pump). Also, the standard trans is the way to go, I miss mine nearly everyday I haul a BIG load.
  • Forester
« Reply #13 on: June 27, 2012, 12:42:07 AM »
Our local UPS and FedEx people have switched from the usual rwd vehicles to f450 and f550 4x4 trucks with boxes for the winter. According to my local UPS driver he was getting stuck and having to call a wrecker so often it was cheaper to buy 2 smaller 4x4 trucks and hire another seasonal driver for the winter months so they could stop paying for unstucks and paying for the downtime and lost production.
Not sure how some of you guys do it but even with a full load of firewood in my pickup with a locked rear axle I can sometimes hardly make it out of my driveway without 4x4. Drag any sort of trailer behind and 4x4 is mandatory to get moving unless you happen to be on a flat or downhill paved road.
Edit: and before UPS and FedEx went to 4x4's they would park on the road all winter and walk packages to the door so that they didn't risk getting stuck in somebody's driveway.
Offline snowstorm
« Reply #14 on: June 27, 2012, 06:59:56 AM »
snowstorm,
  i dont know how the registration works where you are. here you can put whatever you want on it for reg. mine is at 20,000 lbs plus the 10% equals 22,000. here they dont use the gvw tag as saying thats all it can haul. the state is more concerned with the number of axles tire size and tire with. i dont know how heavy mine is. with all the plow gear and the combo dump sander body. 15000 maybe plus 5yds of winter sand around 25000 loaded.dosent seem to bother it any. the 6sp trans is good a 4x4 would be better also for the lower gear in low range.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #15 on: June 27, 2012, 11:16:36 AM »
Get a 4wd.  The reduced stress level is worth every penny  :)
Offline John_Haylow
  • "If you are going through hell, keep going." W.C.
« Reply #16 on: June 27, 2012, 12:45:15 PM »
You will never regret having 4wd.
John
2004 Wood-Mizer LT40HDG28
Offline Ironwood
« Reply #17 on: June 27, 2012, 10:11:13 PM »
Just another "learn by anothers mistake". I have seen highway/ sub highway speeds disinegrate the front driveshaft on several 99-03 Ford 4x4 F-250-550 trucks, when this happens it breaks the tranny and transfer case all up. About a 6,000+ repair, IF you can find the parts. It never happened to me but have seen it twice on others trucks and heard about it from others. My two current trucks (2000 F-550 4x4 gasser. and Shinnlinger's old 2002 F-350  4x4 CC/CC 7.3) I have had both front driveshafts completely rebuilt just in case. For $300 each it is cheap insurance.  FYI
 Just another thought, if you are in "snow country" I might lean toward the V-10 4x4. I LOVE my 7.3, but in the dead of winter I can just go out and throw the key, no plug-in, no worry and go plow or whatever. Combine that with increasing disparity of high test gas vs. diesel (and lubricity additive for the older diesels), and the math is not as good for the diesel, ESP given the 2x's the cost of the used 550 7.3 4x4.
 I love my V-10 and have had no issues with it (has 190K, bought it at 170K), but the 99-03 (or 04) had issues with spitting spark plugs out of the heads (thin aluminum) solved I believe in 05'. I have NOT had any issues, mine might have a few helicoils in it (I dont know) but has been great and purrs like kitten, just thirsty. I get about 7 MPG around town and best was 10-11 empty on highway "testing" with my foot OFF the pedal. My engine is really clean, as it was run on propane (propane delivery truck) most of it's life. they switched it to gasoline about 6 months before I bought it after the propaner induction computer went out. It is for work so it is just a variable cost, I drive, it works, I feed it. Fact of life. An unmodified F-550 7.3 might get 11-12, and not much more (possibly less with the 4;88's). Best I ever did was 15.5 on highway with the 3;91's foot out of it. usually averaged around 11-12 loaded OR empty, truck never cared. Do the math on your miles driven and the intial outlay for a diesel. It might surprise you and make the V-10 look VERY good financially.
Ironwood
Offline Ironwood
« Reply #18 on: June 27, 2012, 10:34:26 PM »
Also, for tires I usually run an Oliver Blizztrack http://www.oliverrubber.com/blizzard_track.html on the rear, this is whats on my 550 currently. I would buy new steers and then save them when worn for one iteration as a retread on the rear.
 These are GREAT for snow and are deep and wear well. One FYI, I try to get them on early, like late sumer to wear them down a bit and get the compound to "harden up" a bit before winter as the tread is so deep it squirms a little for a few months. You dont want that during snow periods as it wil lfeel like you are starting to spin out on ice when it is just the tire squirm. I have NEVER had one delam on me and I ran them on long hauls heavily loaded.
 Ironwood
Offline RobertJoseph
« Reply #19 on: June 28, 2012, 02:17:34 PM »
I used to have a 2wd dually plow truck and it worked fine in northern VT....granted I usually wouldn't let the sander get completely empty between fills. It can be done, but it's definitely not ideal.
However, a 7.3l with 50k has alotta life left in it. My current 2003 7.3 has 200k on it and starts dead of winter no problem. Synthetic oil, good batteries and glows and you're good to -20. Still on the original injectors, HPOP, turbo, waterpump and auto trans and runs like a top. My glows were starting to give up some hard starts late this past winter, but they have over 100k on them.
Robert
Routed Signs for Northern Michigan Firewood Products
Started by Busy Beaver Lumber on General Woodworking
Last post September 13, 2014, 07:23:11 AM
Delivering Firewood
Started by deastman on Firewood and Wood Heating
Last post April 16, 2014, 01:41:02 AM
by CRThomas
Is there money in selling and delivering firewood?
Started by TJ Timber on Firewood and Wood Heating
Last post January 23, 2013, 11:12:40 AM
by Al_Smith
Looking for Northern Michigan Logger
Started by Woulde on Forestry and Logging
Last post October 27, 2010, 10:08:29 AM
by barbender
