Author Topic: Sawmill Structural Timber Stamping?  (Read 1552 times)
Offline JWright
  • Backyard Sawyer
« on: July 01, 2012, 11:53:33 PM »
I was Wondering why there aren't more people milling lumber. I mean sure it's hard work don't get me wrong but there has to be a catch here! I read a post on a site the other night about the stamping of structural timbers.  The post basically was sayin that most states required this stamp on timber for it to be used for structural timber. The stamp would cost a comany like 250.00 a week to have your own stamp. Or you could pay an inspector to come check and stamp your wood. Does anyone know of this in the state of Georgia?
Offline opticsguy
Re: Sawmill Structural Timber Stamping?
« Reply #1 on: July 02, 2012, 05:46:15 AM »
$250 for a stamp??   Can you make your own?    :-)
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: July 02, 2012, 07:49:11 AM »
First, Welcome to the Forestry Forum, JWright.   :)
I assume that you are referring to lumber grading and Grade Stamp.  In my area, Architects will specify on the blueprint/construction drawings that #2 grade framing lumber be used.  Many municipalities and counties may also require that "graded lumber" be used before they will issue a building permit.  Building inspectors make periodic inspections as the building progresses to insure that the building materials are "up to code".  Loan institutions and insurers verify that the building was built using the materials that the Architect specified.
Yes, sometimes there are ways to circumvent grade stamps, but it is a very tricky venture.
Offline Kansas
  • In the mountains of Kansas
« Reply #3 on: July 02, 2012, 08:59:35 AM »
I didn't circumvent it. I just blew right through it. But then I live in an area where I can do that. Until I got on this board, I never realized the problems like this that some other folks have.
Offline morgoon
  • Location: North Western Ontario...Probably further North than the other Northern Ontario
« Reply #4 on: July 02, 2012, 09:42:49 AM »
It's a big problem for me
Up here in our municipality a farm doesn't need graded lumber for any out buildings, but everything else has to be grade lumber.
I don't make enough lumber to warrant a grader, but I would like to, and will soon have to find some one to do it.
I thought about becoming a grader, just to make things simpler.
Homemade bandsaw, made by my mentor and dear friend Unto...who turned 85 this year
And I just made my first longbow...awesome
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: July 02, 2012, 10:23:54 AM »
I have absolutely no problem with grading here.  The Architect indicates on the building plans to use #2 graded and/or rough sawn lumber.  That way the building meets the drawing specifications and everyone is happy.
If there is no financing done, or we are outside of a municipality, then we do nothing but build.
Offline dboyt
  • Log On!
« Reply #6 on: July 02, 2012, 12:29:10 PM »
Like, Kansas, no problems like that here in the Missouri Ozarks.  The best way "around" it is to not try to compete with the big boys to produce structural lumber (other than for yourself, if you can get by with it).  Barn siding, trailer decking, cabinet and furniture wood, and other jobs keep me pretty busy.
Offline JWright
  • Backyard Sawyer
« Reply #7 on: July 02, 2012, 02:00:59 PM »
Thanks y'all here in Georgia you can do or build pretty much anything yourself with no licenses permits or stamps. Like I said I just happened on that info the other day and was curious. I guess you could also look at it like if someone ask for a 4x4 I don't have to know if it's for a fence or a house! On the other hand if someone asked I want to be able too steer them write and not have them mad with me.
Grading structural timber
Started by woodsy on Timber Framing/Log construction
Last post March 30, 2011, 10:37:23 PM
by Mad Professor
Non-structural Timber Frame / Adding timbers inside stick framed room
Started by rachel on Timber Framing/Log construction
Last post June 17, 2011, 06:31:42 AM
by logman
Structural Adhesives
Started by TGS on General Board
Last post June 11, 2011, 09:25:24 PM
by scsmith42
Hammerbeam structural ridge ....
Started by zelpatsmot on Timber Framing/Log construction
Last post April 07, 2013, 02:00:58 PM
by Chilterns
