AVAILABLE
Author Topic: Belsaw Blade needs Hammered  (Read 1293 times)
Offline reride82
« on: July 02, 2012, 09:38:57 PM »
I need to get the blade hammered on my Belsaw. Is it left or right handed? When standing on the board side of the blade it turns clockwise and the carriage feeds from the right. Is this a right hand mill or is it backwards since the arbor is under the carriage as opposed to a frick? Thanks in advance,
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline ALWOL
  • Love the sound of a circle saw in the morning!
Re: Belsaw Blade needs Hammered
« Reply #1 on: July 02, 2012, 11:42:29 PM »
   It needs to be hammered as for a right hand mill.
      Alan
There's a big difference between staying busy and making money.
Offline bandmiller2
« Reply #2 on: July 03, 2012, 07:39:58 AM »
Levi,replace any bits or shanks you were planning to replace before you take it to the smith.He also needs to know the type of bearings ball,roller babbit est.A 40" saw turning around PTO speed is quite forgiving as to tension. Frank C.
Offline snowshoveler
  • Knotty Knot Sawmill
« Reply #3 on: July 03, 2012, 11:30:22 AM »
If the 40" is quite forgiving that explains why my 38" belsaw dosen't move at all at engine idle in low gear or wide open in high gear.
Blade is flat all the time.
Only sawing errors have been mine.
 Regards Chris
International T5 dozer
JD M tractor
MF skidloader
Jonsered chainmill
Vintage Belsaw
Offline reride82
« Reply #4 on: July 03, 2012, 11:54:30 AM »
Thanks guys. My 42" blade developed a wobble after this past weekend. I think the culprit was that the blade was half in the sun and half in the shade and it didn't stand up like it should have. Since I had been in the sun all day, I didn't notice until I must have heated the center of the blade. I sharpened it that morning and sharpened it after so it was sharp. Upon closer inspection, it would sway about 3/8" when turning by hand. The bearings are new, they weren't getting hot, my lead was still set at approximately 1/16" and the track is straight and level. I never had the blade hammered when I got it, so I figured it should be done anyways. I hope it solves my problem.
Levi
Blade Hammered
Started by Kauff44 on Sawmills and Milling
Last post September 02, 2016, 09:03:17 PM
by Corley5
got the blade hammered (pics)
Started by lyle niemi on Sawmills and Milling
Last post June 14, 2012, 10:08:05 PM
by sawsmith
50 inch blade on a belsaw
Started by timberjackpa on Sawmills and Milling
Last post January 19, 2009, 10:27:14 PM
by sparky
Belsaw blade question
Started by Farmer_17 on Sawmills and Milling
Last post May 17, 2012, 02:58:57 PM
by sandhills
