Author Topic: Fifth wheel and gooseneck  (Read 1203 times)
Online LeeB
« on: July 03, 2012, 09:45:26 AM »
Can you have both on the same truck?
Offline chevytaHOE5674
Re: Fifth wheel and gooseneck
« Reply #1 on: July 03, 2012, 09:49:10 AM »
Yes depending on the hitch you purchase.
Offline BBTom
  • Retired, If building a new homestead is retired.
« Reply #2 on: July 03, 2012, 09:50:59 AM »
Not at the same time, but I love my B & W turnover ball gooseneck hitch with the Companion fifth wheel that latches into it. You can turn the ball over and have a smooth flat bed with no rails sticking up.  pull the ball out and drop the companion hitch in the socket and within two minutes you are ready to pull with it.
Offline Norm
« Reply #3 on: July 03, 2012, 11:21:38 AM »
Yep another recommendation for the B&W hitch.
Offline Cypressstump
  • I'm not so new now!
« Reply #4 on: July 03, 2012, 12:17:18 PM »
My truck has the rails for the 5th wheel attachment, altho I do not own a 5th wheel trailer any longer, but still have the rails bolted into the bed/frame....
I found on FleaBay an adapter hitch that is for a gooseneck ball, that latches into the rails for my 5th wheel. It's a very sturdy unit that has a positive lock in pins. I'll soon be buying one.
So if you have the rails for a typical 5th wheel for less than 150 bucks you can have the gooseneck ball hitch as well.
Stump
Stump
Timberking 1220 25hp w/extensions -hard mounted
Case 586E 6k forklift
2001 F350 4X4,Arctic Cat 500 4 wheeler wagon hauler
Makita 6401 34",4800 Echo 20"er, and a professional 18" Poulan PRO , gotta be a 'pro' cuz it says so rite there on tha' saw..
Online LeeB
« Reply #5 on: July 03, 2012, 05:38:01 PM »
Don't know what brand gooseneck I have. Will have to check.
Thanks guys.
Offline scsmith42
    • Whispering Pines Farm
« Reply #6 on: July 04, 2012, 11:43:28 PM »
Re the B&W gooseneck hitch, if y'all compare a Draw-tite hitch to the B&W, you'll probably purchase the Draw-tite.
The Draw-tite is a much stronger / heavier-duty hitch, at least for late model 1 ton Ford's.
Tom's 3638D Baker band mill
Offline BBTom
« Reply #7 on: July 05, 2012, 02:15:01 PM »
Both have the same ratings, I have overloaded my B & W on more than a few occasions and never heard a wimper from it.
It seems that B & W is about the only hitch company that Cequent Performance Products has not been able to buy out,  B & W did invent the turnover ball.  You know me, I have to root for the little guy.  I am sure they both are excellent hitches.
Opinion: Band wheel w nothing btw blade and wheel
Started by chisel on Sawmills and Milling
Last post June 14, 2004, 02:26:41 PM
by Fla._Deadheader
Gooseneck Adapters
Started by Gary_C on General Board
Last post July 18, 2012, 08:45:08 PM
by Gary_C
Gooseneck Trailer
Started by Paul_H on General Board
Last post June 08, 2005, 03:28:04 AM
by mometal77
Log Loader Wanted for Gooseneck
Started by shamusturbo on Wanted
Last post April 05, 2015, 08:39:03 AM
by brendonv
