Author Topic: Circle mill headblock/blade clearance?  (Read 818 times)
Offline SPD748
  • "Tuam Libera Mentem"
« on: July 05, 2012, 04:30:40 PM »
I've looked through all the reference manuals that I have and can't seem to find an answer to my question. What is the recommended clearance between the edge of the headblock and blade? I'm ready to fabricate the beams that will tie the track frame to the husk. The only missing dimension is the blade/headblock clearance. I'm thinking it's something like 1/2" or so but I want to be sure before I cut and weld the beam. Thanks guys!
-lee
Frick 0 Handset - A continuing project dedicated to my Dad.
410 Deere, 240 Massey... I really need a rough terrain forklift :)
Sawing Since 1-19-2013 @ 3:30 pm
Serving Since 2002
"Some police officers give tickets, some gave all."
Offline beenthere
Re: Circle mill headblock/blade clearance?
« Reply #1 on: July 05, 2012, 05:03:32 PM »
1/2" is mentioned in Stan Lunstrum's Circular sawbook.
http://www.fpl.fs.fed.us/documnts/misc/circsaw.pdf
Might have to do with how thin you want to go with your dog board, and how close the dogs will set to the knees.
Offline ALWOL
  • Love the sound of a circle saw in the morning!
« Reply #2 on: July 05, 2012, 05:08:47 PM »
   I like to be able to saw down to a 1" dog board, so 1/2" will likely allow you to do this without to much danger of the board falling off the knees. I have mine set to clear by about 3/8" while at speed.
       Alan
There's a big difference between staying busy and making money.
Offline steamsawyer
  • I'm Antique
« Reply #3 on: July 05, 2012, 06:40:05 PM »
       Alan
I'm right in there with Alan. That is exactly how mine is set up.
I always keep an eye on the saw guide clearance to the blade. Make sure the guide won't allow the blade to run out enough to hit.
Alan
J. A. Vance circular sawmill, 52" blade, powered by a 70 HP 9 1/2 x 10 James Leffel portable steam engine.
Inside this tired old mans body is just a little boy that wants to go out and play.
Great minds think alike.....  Does your butt itch too?
Alan Rudd
Steam Punk Extraordinaire.
Offline SPD748
« Reply #4 on: July 05, 2012, 07:27:53 PM »
Thanks guys. I'll set up the frame to allow the clearance to be adjustable from 1/4" up to 3/4" so I can dial it in once the mill is up and running.
-lee
Serving Since 2002
Four Headblock Circle Mill Again
Started by Autocar on Sawmills and Milling
Last post April 09, 2015, 05:24:59 PM
by Autocar
Left Hand Three Headblock Mill
Last post March 13, 2011, 06:32:10 PM
by beenthere
Circle mill blade
Started by schmism on Sawmills and Milling
Last post March 28, 2010, 09:10:07 PM
by bandmiller2
circle mill blade question
Started by Tripp on Sawmills and Milling
Last post April 19, 2012, 08:05:51 AM
by Tripp
