Author Topic: Shingles on an LT-10 ?  (Read 1349 times)
Offline Indiana Robinson
  • I'm new! No I'm not. I'm too old to be new :-)
« on: July 06, 2012, 05:47:16 PM »
Has anyone built something like a single block tipper that would clamp on something like an LT-10?
I want to make a few and have several ideas but then why re-invent the wheel if not needed.
I don't want to roof a bunch of stadiums  :), just mostly decoration on a few gables and maybe even part of a smallish wall in one room of the house.
Something quick and simple...
Did I mention that it is hot?
Lifetime farmer.
Lifetime sawdust lover.
Old Tractor lover.
 Have worn a lot of hats.
Once owned a Kasco mill that would saw a 30"x24' log. Now a new little LT-10 Woodmizer for my own lumber.
And yes, my woodshop is seriously infested with Shopsmiths.
Old geezer trying hard not to be one. :-)
Offline fishpharmer
Re: Shingles on an LT-10 ?
« Reply #1 on: July 06, 2012, 06:39:38 PM »
There may be others, planman1954 bought or made a neat shingle making fixture.  You might try searching his old posts if he doesn't see this one.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #2 on: July 06, 2012, 06:51:45 PM »
Beveled siding and tapered shingles are nice but you can also get the same look using 1/2" or 5/8 thin slices off of cants, just apply a narrow starter to get the taper going. Or you can make a simple jig using a nice 2x12. Cut your shake bolts at even lengths 18" long. Make you a stick 1/2"x1/2" and place it under your blocks on the ends to raise it , drill a couple of holes at angle so you can anchor blocks or bolts to your 2x12 with some decking screws also fix you a solid stop using some short strips of broken blades to help hold other end of blocks. Just remove 1/2x1/2" stick every other pass do as many bolts that you want to line up 5 is reasonable and just clamp 2x12 to bed rails with log clamp. Hope this makes sense.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline Woodsrover
« Reply #3 on: July 06, 2012, 07:26:03 PM »
That's on my list of things to do.  I'd love to make my own shingles for a few of the planned projects around here.  looking forward to more ideas and maybe even some photos.
Offline Planman1954
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Offline thecfarm
« Reply #5 on: July 07, 2012, 08:11:26 AM »
Planman,I forgot about that thread, I bookmarked it. Thank you. It was a nice journey to follow.
« Reply #6 on: July 07, 2012, 09:24:14 AM »
Thanks... This stuff is exactly what I was hoping to see.
Lifetime farmer.
Old Tractor lover.
Shingles Shingles Shingle
Started by just_sawing on Sawmills and Milling
Last post July 26, 2018, 04:44:11 AM
by Satamax
Red Elm for shingles???
Started by Rob-IL on Timber Framing/Log construction
Last post April 26, 2007, 05:35:29 PM
by Dodgy Loner
Shingles
Started by Stephen1 on Health and Safety
Last post April 06, 2016, 05:10:29 AM
by square1
Started by Rob-IL on General Board
Last post April 27, 2007, 12:18:20 AM
by WDH
