Author Topic: timberjack brake  (Read 14895 times)
Offline EricR
timberjack brake
« on: July 07, 2012, 05:03:24 PM »
I am working on my timberjack 200  and the brake needs work.  its a drum brake mounted on the transfercase.  It needs all new springs, shoes and wheel cylinder.  I was just curious to know if anyone knows if these parts cross to any automotive stuff. Also, has anyone on here ever converted the drum to a disc.  Thanks, Eric
Offline 2308500
Re: timberjack brake
« Reply #1 on: July 07, 2012, 05:44:46 PM »
i have been thinking about a disc conversion for a while. i think it would be the cats meow
with a little bit of machining and welding there should be a solution to the poor drum brake setup
Offline Mark K
« Reply #2 on: July 07, 2012, 06:01:56 PM »
I worked on a 230 TJ a while back that a guy put a rotor and caliper off of a Ford escort. Looked professional and didnt require much modifying to make it work. He said the rotor bolted up but he had to machine the center of it out a little.
Husky 372's-385's,576, 2100
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #3 on: July 08, 2012, 08:44:17 PM »
I'm currently converting my 201B to a disc brake system.I am using a rotor and caliper off of a dodge dakota 4x4.I was taking pics as I go so I can put it on here when I'm finished but I had to stop my progress because I had to rebuild a 353 and just as that one went out the door another buddie lost his skidder engine so now it's another 353 to do.Is your transfer case a Rockwell or a New Process?
Offline EricR
« Reply #4 on: July 09, 2012, 08:18:16 AM »
Thanks for the replies.  Bushmechanic some photos would be great.  As fas as what tranfercase I have maybe you can help me out with that.  There are some numbers cast into the pto housing but i cant get my head in there to read them.  The only thing i can read is a tag that say timberjack rebuilt part   Any help would be great.  Im new to skidders.
« Reply #5 on: July 09, 2012, 08:04:26 PM »
Hey EricR that is a New Process transfer case,they were popular in all the 200 series skidders right up to when the Eaton gear started showing up in the 80's.Those brakes are notorious for trouble and it seems that the disc conversions seem to work better.As for crossing up the parts to automotive I can't help you there I always got new parts from Timberparts in New Brunswick,they always had what I wanted in stock,sometimes it was a bit pricey but you can't make money with a parked machine!Now my old skidder is only used for snow clearing so I can wait to "get er done". :D
Offline rvolek
  • "It is what it is"
« Reply #6 on: July 09, 2012, 09:14:57 PM »
Hey EricR, Im not sure where your located but I'm in Western Pa. I am fortunate to have a skidder repair shop 50 miles from my home. I purchased a master cylinder and all the brake hardware in the drum for a total cost of $393.
I didn't think it was to bad of a cost considering the great feature it gives a skidder. Oh, and I had a new brake hose made that goes from the brake lock lever to the drum for $29. If you don't need the master cylinder than minus $137. I checked my local NAPA store and they had nothing of the sort. If you go through a John Deere dealer you will pay way more.
74 Timberjack 230D
JD 450 Dozer
Husky 570, 372
Offline mog5858
« Reply #7 on: July 16, 2012, 10:52:08 PM »
well let me know how this works out cus it's on my to do list with my 201 it has no brakes right now. i was thinking about a 1/2 ton truck disk brake. i bean told that the drums never work great from day one. so convershion might be a better. if you are any near me southeast sask southwest man. i have full machine shop to get her done in if you need a little help making something fit.
Offline Atlantic Trader
« Reply #8 on: July 17, 2012, 07:41:11 AM »
Eric
Just a comment i just bought my first skidder it is a timberjack model 200H, iam trying to figure out the year? My serial # is 00300, is this anywhere near yours and do you know what year yours is? It might help me figure it out. Thanks and good luck with the brakes,
p.s. this is a great forum an already i have learned alot about timberjacks
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #9 on: July 17, 2012, 01:56:49 PM »
If you happen to run in to a junk S8 IH  get the rotor, caliper, master cylinder and the caliper mount off it.
The S8 IH had a disk brake off the tran and one on the rear drive shaft in front of rear hosing, both had the same parts, double disk brake system.
My dad put one on his C5, off the transfer case, you can weld or bolt the caliper mount on.
Offline EricR
« Reply #10 on: July 17, 2012, 09:42:52 PM »
Atlantic trader.  I alsohave  200h but like you i have no idea what year its from. If you figure it out let me know.  Thanks, Eric
« Reply #11 on: July 18, 2012, 04:22:19 AM »
Eric, thanks once i get 4 posts i will try and put  pictures on, luckily ehe brake still works, but it is good to know you can convert over to a disc.
Offline Retired-Jack
« Reply #12 on: August 21, 2012, 03:13:47 PM »
I removed the drum brakes from my TJ 201 many years ago.
 Recently I adapted and mounted a Honda rotor and caliber on the rear drive shaft and it brakes really well. The atco lever is my parking brake.
Tj 201 Patu loader SMG Sawmill
Offline Ken 45lc
« Reply #13 on: August 21, 2012, 03:54:34 PM »
This looks  like the same setup as on a 240D I had. I think it was a 58 ford 3/4 ton wheel cylinder, but you still have to use your old cups. Had the brakes re-lined at local brake shop. That plate should unbolt so you can put it all back together at the work bench instead of standing on your head to do it.
Oh, an be sure to have the lower adjuster adjusted up prior to install, that way you can adjust the top one after everything is back together (easy one to reach).
As small as those brake shoes are, no wonder many people say they don't last long. They seemed to last ok for me, but I don't use the foot brake very often on a skidder.
Offline skolvek
  • Member*
« Reply #14 on: November 06, 2018, 06:12:50 PM »
Hi,  I have a 1978 timberjack 230D, missing all of the internals to the old disk drum brakes.  (I am getting a price of like $500. for all the internals including the caliper).    I would LOVE to see photo's of your conversion to a disk braking systems and what I have to do to make it happen.   I really would like to convert it to a disk braking system.   Any help is really appreciated.   I am especially curious how you were able to mount the disk caliper to the trans.  Thank you in advance!!!  Scott
Offline Mountain_d
« Reply #15 on: November 06, 2018, 08:45:06 PM »
Did anyone ever do the disc conversion then add a micro lock valve to the line to act as the park brake?  Would that work? The micro locks look interesting but I have not used one on anything yet.
Mountain
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #16 on: November 06, 2018, 10:25:04 PM »
Never trust a mico lock. Well never trust any parking brake but especially the mico lock they have been known to leak off.
Offline barbender
« Reply #17 on: November 06, 2018, 10:33:35 PM »
My Pettibone has a disc brake, and a MICO lock on it. However, the MICO has never worked, so I can't say how effective it is. The machine came O.E. with a disc and lever parking brake, butit was disconnected by a previous owner.
Offline Mountain_d
« Reply #18 on: November 07, 2018, 08:38:07 AM »
OK, thanks for the info, lads.  When the disc conversion is done, what is used for the parking brake?
Mountain.
Offline mike_belben
  • Pulp Friction
« Reply #19 on: November 07, 2018, 09:22:18 AM »
Build a pinion brake conversion using rear caliper off a cadillac eldorado or ford explorer with 8.8 rear.  They both had hydraulic disc brake with a cable actuated cam clamp.  Just set up your manual parking lever.  If you ever rip a line youll still have mechanical emergency stopping.  I recommend one on each pinion and a habd brake off a cab abd chassis truck is probably the longest cables you'll find.  You can always make them up by soldering metal slugs or trimmed off bolts to aircraft cable.  Steel brakeline works fine for a housing but i cut a few saw slits in it at the low points for water drain and fill em full of gear oil.  Oversize for a loose cable fit inside or theyll jam up.
  For sleeve adjusters i weld a nut to a plate and bore a thru hole in a short bolt, then a blind hole register in the head for the brakeline to seat in.  The bolt threads in and out of the plate to fine adjust the housing length.  Welding a baby vice grip to the other end that needs to be actuated has worked fine for me on redneck solutions.  Stick cable tail into vice grip jaw and chomp down.
Rock auto is about the cheapest youll find either caliper.  Theyre spendy
Revelation 3:20
question
Brake Job on Timberjack 230E?
Started by timberlinetree on Forestry and Logging
Last post July 03, 2012, 09:23:00 PM
by lynde37avery
Timberjack Brake Service
Started by Mooseknuckle on Forestry and Logging
Last post February 24, 2015, 05:44:25 PM
by so il logger
Timberjack external brake
Started by madmari on Forestry and Logging
Last post July 24, 2011, 09:14:43 PM
by madmari
Timberjack 217 Parking Brake Lever
Started by Watkins1 on Forestry and Logging
Last post July 04, 2019, 04:45:53 PM
by Maine logger88
