Arborwear
Author Topic: hauling logs  (Read 6964 times)
Offline steve phillips
  • I'm new! but old as the hills lol
hauling logs
« on: July 10, 2012, 09:05:31 PM »
howdy all
i was just wondering  , i want to use my trailer to haul logs . any thing i need to do before i start this. im thinking winch , winch holder (lol) ramps .  any input is welcomed
if its not broke dont fix it !!!!
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: hauling logs
« Reply #1 on: July 10, 2012, 10:12:44 PM »
My setup.
Load um up.
Loading a bigun.
This is gonna hurt.
A valid suggestion was made last week about adding a couple of old tires in the trailer to soften the blow.  This Red Oak log had a 42" butt.
Offline Brad_S.
Re: hauling logs
« Reply #2 on: July 10, 2012, 10:42:00 PM »
Use the search engine and research the Dang-Deadheader log loader.
Here is a link to a follow up thread but I am pressed for time and didn't find the original thread on the loader.
http://www.forestryforum.com/board/index.php/topic,17613.0.html
Offline kelLOGg
  • Still learning more than I'm teaching
Re: hauling logs
« Reply #3 on: July 11, 2012, 06:24:01 AM »
Mine is similar to MM.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, tandem trailer, log arches, trailer, tractor, hammer
Offline Chris Burchfield
Re: hauling logs
« Reply #4 on: July 11, 2012, 07:12:06 AM »
I have a two tier trailer hitch.  Lower is for the trailer, upper is for the Warn 9500TI winch.  Loader (similar to Dangs) mounts on the ramp pins.  I use a log chain to stop it when it's hanging off the back.  I come off the winch, through a snatch block on the loader then down to the log.  When I retrieve the log.  The end of the log will lift till it contacts the loader.  At this point the loader will rock forward.  When the loader hits the down legs as forward stops, I lower the end of the log to the trailer.  I can then get another bite and bring the log on up.  I have two steel farm equipment wheel I can use in the pivot holes at the back, a swivel wheel on the front and a cross bar I can lift the end of the log.  By lifting one end of the log I can drag the log to the trailer.
Woodmizer LT40SH W/Command Control; 51HP Cat, Memphis TN.
Offline crtreedude
  • A proper coffee break...
    • Finca Leola Reforestation
Re: hauling logs
« Reply #5 on: July 11, 2012, 07:34:55 AM »
Much of our moving of logs is done with a team of oxen, complete with horns. Logs up to 20 inches in diameter are lifted by the oxen with their horns - the first time you see it you really are amazed.
We have one yoke of oxen right now, I do need another pair is a year or so. I bought my first yoke for 2,000 dollars, and they are into their 3rd yoke, which might be the mature one - they grew out of the other two.
I have seen that yoke of oxen move logs that a tractor couldn't.
So, how did I end up here anyway?
Offline bandmiller2
Re: hauling logs
« Reply #6 on: July 11, 2012, 07:56:00 AM »
I seldom move logs because I don't have to.I have a single axle tilt bed steel trailer with a beefy headgear,just pull them on with a comealong.Handy tip,lashing logs down for transport is sometimes a problem.I took four square top truck "U" bolts that straddle the trailer frame with a bar on the bottom.The bolts drop down flush when not needed then pull up to chain and bind the load. Frank C.
Offline kelLOGg
Re: hauling logs
« Reply #7 on: July 11, 2012, 07:57:19 AM »
Got pix? That would be interesting.
Offline rmack
  • Woodmizer owner
Re: hauling logs
« Reply #8 on: July 11, 2012, 09:07:56 AM »
how about unloading the logs when you get home?
just tie them to something solid and drive out from underneath them?
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
Offline Bogue Chitto
Re: hauling logs
« Reply #9 on: July 11, 2012, 09:15:17 AM »
If you don't have sides or fenders on your trailer you can roll them off the side.  I park on the side of a hill, release the binders and let them go.  But, be careful, get far out of the way.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: hauling logs
« Reply #10 on: July 11, 2012, 09:19:43 AM »
When ever I haul logs, no matter how large or small.....I always and ALWAYS have a 4x4 under the front and back of the log. This gives me room to get a chain or strap wrapped around the log to either lift it off the trailer or to tie it off and drag it off the trailer.
I have customers to this day that still PACK their trailer with logs, wedging them down between the side boards making it impossible to to get a strap around them because the logs are flat on the trailer floor. Even if I used TONGS it would be hard to get a bite on these wedged logs.
I have sometimes got so DanG frustrated, I just hook the trailer to the backhoe bucket, pick the trailer up in the air and shake it like a rag doll until the logs come loose.
Grrrrrrrrr.......No what I mean?  :)
Where's the Spoon?
Offline Slingshot
Re: hauling logs
« Reply #11 on: July 11, 2012, 09:26:24 AM »
   Here is what I use:
______________________________
Charles sling_shot
Re: hauling logs
« Reply #12 on: July 11, 2012, 09:42:24 AM »
I like that Charles.  Good idea.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: hauling logs
« Reply #13 on: July 11, 2012, 08:11:42 PM »
OK, so I cheat when unloading.   ;D
That old Oliver cost less than 4K and has been so handy that it makes me think that I  am ridin' a gravy train on biscuit wheels.   :)
Offline Woodey
Re: hauling logs
« Reply #14 on: July 12, 2012, 12:01:21 AM »
I started out rolling them over the side like magicman. Then I busted out my trailer floor when the logs hit. Before I had the proper equipment to unload them I tied a chain to one end and the other end to a big tree and drove forward. That worked good but I did not put anything under them and pull the back end out of my trailer.
Now I installed a set of gym poles on the back of my lowboy trailer and winch them up on the trailer. Works good. When I get them to the mill unload them with my forklift.
WOODMIZER LT40HDD34CAT w/accuset
6036 JLG SKY TRAK
NYLE L200 KILN
BAKER M412 MOULDER
Offline MHineman
Re: hauling logs
« Reply #15 on: July 12, 2012, 01:02:58 AM »
  I've got a gooseneck flatbed trailer.  The flat part is 20 feet with a 4 foot dovetail.  The ramps are standup so they do not get in the way of the logs.
  I load small to medium size logs with my tractor forks.
  For bigger logs I use the ramps I made.  The ramps are 2" by 4" 3/16" thick steel.  I cut the steel at 8 feet with an angle to match the rub bars to the ground at 8 feet out, then welded two 5/16" chain hooks.  The hooks slide on the rub bars.
  I pull the log along side the trailer, then move the tractor around and push it up the ramps.
  I have 4 by 4 cants on the floor to allow the logs to roll easy and get forks under to unload.
  I also made stakes to go in the stake holder out of 1 1/2" by 3" steel.  I think it is 11 gauge.  A piece of metal pipe is welded about 6 inches from the bottom to keep the stakes from sliding through.
  I've loaded 20 foot by 30"+ logs with a 40 hp tractor this way.
  I get home, remove the stakes on the downhill side, put a 4 x 4 in front of the logs to control it's exit, take the chains off, then remove the 4 x 4 with a stick or rope.
1999 WM LT40, 40 hp 4WD tractor, homemade forks, grapple, Walenstein FX90 skidding winch, Stihl 460 039 saws,  homebuilt kiln, ......
Offline kelLOGg
Re: hauling logs
« Reply #16 on: July 12, 2012, 06:43:17 AM »
   Here is what I use:
What size ram is that?
Bob
Charles sling_shot
Offline Slingshot
Re: hauling logs
« Reply #17 on: July 12, 2012, 10:46:52 AM »
      The ram on the boom is an 8-ton from HF.
 The winch on top is a 3700 lb Warn, also good for
 dragging logs to the trailer.
Charles
Offline sandhills
Re: hauling logs
« Reply #18 on: July 12, 2012, 11:03:51 AM »
crtreedude I'd also like to see pictures, a video would be really cool  ;).
Offline Indiana Robinson
  • I'm new! No I'm not. I'm too old to be new :-)
Re: hauling logs
« Reply #19 on: July 12, 2012, 01:21:52 PM »
I would absolutely kill to have my old wrecker back for snaking and loading logs...
Lifetime farmer.
Lifetime sawdust lover.
Old Tractor lover.
 Have worn a lot of hats.
Once owned a Kasco mill that would saw a 30"x24' log. Now a new little LT-10 Woodmizer for my own lumber.
And yes, my woodshop is seriously infested with Shopsmiths.
Old geezer trying hard not to be one. :-)
Logs for the Hauling
Started by tnvanman on Sawmills and Milling
Last post August 28, 2003, 10:01:54 PM
by Frank_Pender
Hauling logs ....
Started by TexasTimbers on Sawmills and Milling
Last post May 11, 2005, 09:18:56 PM
by FiremanEd
question
Hauling logs
Started by Grandbuddy on Sawmills and Milling
Last post October 14, 2015, 10:55:13 PM
by Kingmt
Hauling Logs
Started by smwwoody on Forestry and Logging
Last post July 04, 2011, 07:26:58 AM
by Norm
