Tally-I/O
Author Topic: Hydraulic De-barker motor size?  (Read 766 times)
Offline Cutting Edge
    • Cutting Edge Saw Service, LLC
« on: July 22, 2012, 11:21:17 AM »
Hello All,
I'm trying to figure out what size hyd. motor I need to run a debarker.  The motor will drive an arbor/shaft via v-belt turning a 6" blade.  This will allow it to be geared up or down, so there are more hyd. motor options.  De-barker motor will run off the "Excess Flow" port of the flow control valve.  "Controled Flow" runs the carriage drive/traverse motor.  I'm unsure of required hp, rpm's, etc. requirements to run one properly.
Pump - 6.67 gpm @ 3600 rpms
Carriage hyd. motor - 4.5 cu. in disp./rev. - operates at about "3" on the scale of 1-10 on flow control valve.
De-barker hyd. motor - ???
Thanks in advance
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
 - Sharpening Services
 - Portable/Custom Milling and Slabbing
 - On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Re: Hydraulic De-barker motor size?
« Reply #1 on: July 22, 2012, 10:32:03 PM »
Maybe a better questions to ask:
What are the specs. (rpm, hp, etc.) for y'alls mills with hyd. motors, or elec., running the de-barker/mudsaw.  Maybe with that information I could work backwards to figure out mine.  :P  Thanks
Ph- (304) 878-3343
Band Wheel Size VS Motor Size?
Started by skocienski on Sawmills and Milling
Last post March 07, 2012, 09:43:25 PM
by pyrocasto
Motor size
Started by furltech on Sawmills and Milling
Last post August 04, 2014, 06:19:58 PM
by furltech
Motor size & type
Started by jrokusek on Sawmills and Milling
Last post March 09, 2005, 05:42:25 PM
by Doc
Pulley size for motor
Last post March 24, 2005, 09:35:46 AM
by jrokusek
