timberjack 660d anyone?
Started by poorfarm, August 21, 2012, 04:59:11 PM
poorfarm
does anyone on here have one? this winch i want to buy came off 1999. question i have is what direction does it turn? is it live all the time and cable or hydrolic actovated?/  want to put it on 1980 380 thanks
Autocar
Theres guys on here that know better then I but I have never heard of a 660 Timberjack. Iam sure your get a reply from someone about it  ;)
Bill
lumberjack48
They make-em  8.31 Cummings, 207 hp, big horse
bushmechanic
Wait for Kiko to weigh in I think he is the most knowledgeable on the newer skidder gear,or pm him.
treefarmer87
a guy who contracts with meadwestvaco has one around here. it is the only skidder he runs. he does plantation thinnings.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
poorfarm
I know they make them!!!!!! I ran one back in 02 for a couple months..
lumberjack48
Quote from: treefarmer87 on August 22, 2012, 08:55:07 PM
He must have put some skinny tires on it, to get though a thinning job.
Some have a 270 hp JD motor, thats a big horse to feed.
poorfarm
so winch is new take off so i have no idea witch way it turns.. would be a huge help if someone knows
lumberjack48
Sorry for wondering off the subject at hand.
The 660's i've been looking at have a duel drum winch.
Do you know the name and model ? I found its  T60 Force, 27 ton, if thats the one, now try to find which way it turns.
snowstorm
Quote from: poorfarm on August 23, 2012, 03:52:13 PM
was it the one in uncle henrys? isnt that a john deere winich? call nortrax
lumberjack48
kiko
The 660 Jack came with a Cummins engine. When Deere came into the picture it was labeled a 660d and had the 8.1 engine. It was produced as a 848g Deere as well. As far as the winch  goes ,it will not work in this application because winch clutch pack is located in the transmission. The winch prop shaft only turns when the winch is engaged. T 40  or t60 were the winch options. Poor farm,you need a Deere 4000. Me and my guys have stretched out this summer,15 to 18 hours a days and often seven days a week, I will make it a point to follow up with you.
kiko
On the JD 4000 looking at the winch input yolk rotation is clockwise.
lumberjack48
The winch your looking at poorfarm turns clockwise
kiko
Just to make sure what i was spouting about the t40d vs. 4000 winch was accurate; I looked it up this morning on jdparts.com. The t40d does not have an input clutch and is direct drive meant for intermitant input. The 4000 winch has a clutch pack on the input shaft of winch, so with a prop shaft turning constantly the complete drive in the winch is not turning untill the clutch is locked in. Looked up the t40d under a 660d and the 4000 under a 648gIII.
poorfarm
Quote from: snowstorm on August 23, 2012, 05:29:27 PM
its off timberjack 660D
poorfarm
kiko you are right. went and looked at  jd548 and 450 tj.. jd turns constant
