Author Topic: Bridge Construction  (Read 5366 times)
Offline Maine372
Re: Bridge Construction
« Reply #20 on: September 10, 2012, 08:21:43 PM »
old highway flatbed trailers work.
old railroad flat cars work.
old platform log bodies work.
start calling truck dismantling places and junk yards around you, somebody has got to have something. hemlock logs for abbutments. pick a tree on the other side of the river to set a pulley up in. run a nice long rope or cable from the bridge to the pulley, then back across the river to a vehicle.
we have used this technique for log bodies and timber bridge panels.
Offline JohnG28
« Reply #21 on: September 13, 2012, 11:36:15 PM »
I have no idea what regulations may be in your area, but knowing just some of the regulations in NY would make me want to find out what is allowable first. From there the most cost effective or just effective bridge can be built.  JMO though.
Offline JoeB
« Reply #22 on: September 14, 2012, 09:06:08 AM »
Good Day, another idea that we have used was we demolished an old quarry, and recycled the scale and skelton under neath it. Turned out good as i think it was 53' long. HTH, JoeB
Offline Sixacresand
  • John and Nancy
« Reply #23 on: September 15, 2012, 01:13:36 AM »
For a permanent streaming crossing, plastic culverts covered with fill are a good option.  Galvanized will eventually rust and cave in.  Also run a hydrology study to size the pipes to handle the flow including a emergency over flow to handle big storms.  A culvert crossing with fill dirt is the same as the dam of a pond except you are not storing water with a stream crossing.   Bigger  or more pipes may seem like an over kill, but it will prevent an washout during a 50 or 100 year storm.  And do get the blessings from all your environmental agencies.
Offline KyLogger
  • Loggin' for a livin'
« Reply #24 on: September 15, 2012, 06:53:45 AM »
I appreciate all the responses! Environmental agencies aren't a concern. I live in E. Ky where there is no zoning, and 1/4 of the "septic systems" are still run "over the hill" ;D  I think that my ADS culvert would be my mist cost effective means. With the price of scrap around here any large piece of metal is either higher than groceries, or already chopped up and gone to the scrap yard.
I only work old iron because I secretly have a love affair with my service truck!
Offline Sixacresand
  • John and Nancy
« Reply #25 on: September 15, 2012, 10:02:04 AM »
Amen to a "very understanding spouse", KYLogger
covered bridge construction?
Started by hackberry jake on Timber Framing/Log construction
Last post November 05, 2011, 10:40:58 AM
by jdtuttle
moved
MOVED: covered bridge construction?
Started by Jeff on Sawmills and Milling
Last post November 04, 2011, 12:59:17 PM
by Jeff
Outdoor Bridge and Camp Construction
Started by Stan P on Timber Framing/Log construction
Last post November 18, 2005, 03:02:32 PM
by raycon
Small temporary bridge - timber or log construction?
Started by ChugiakTinkerer on Timber Framing/Log construction
Last post May 14, 2018, 12:16:58 PM
by ChugiakTinkerer
